Quoted from sirlonzelot:For those who play without playfieldprotector: How’s the playfield holding ? Are there lot of dimples noticeable or any ghostings ?
Greetings
I've got the dimples that you'd expect, but no ghosting after a month of playing it. FYI: I installed a playfield protector which required taking almost everything off the playfield. Once I was done, I could not keep debris from getting under the playfield protector as I reinstalled stuff. This included some sawdust that might have been in between the lower playfield window and the window mounting pocket, left over from machining the window pocket. I suspect the static in the playfield protector plastic possibly pulled some small particles of sawdust up. Anyway, I kept having to try to reach under the playfield protector to get debris out, and the playfeld protector ended up getting scratched on the BOTTOM side from me doing this, and the scratches were super noticeable, so I got pissed off and cut the playfield protector out of the machine with scissors. I guess I'll play without one.
