New! Dark mode!
(Topic ID: 42547)
ACDC lower playfield target
By ngg
7 years ago
  • 14 posts
  • 9 Pinsiders participating
  • Latest reply 6 years ago by CaptainNeo
#1 7 years ago
Over time i have noticed that the left eye target in the lower playfield never goes out; it stays lit despite repeated hits; was not like this in the beginning
Any thoughts or suggestions??
#2 7 years ago
It probably got wedged up against the post, and the switch can't register. You need to adjust it from underneath.
#3 7 years ago
+1, push it over and tighten it bit. Don't over tighten though.
#4 7 years ago
A friend removed his mini rubber rings that sit on the outter edges of the stand up targets and it really plays just fine with them removed. The other night I added cliffy colored sleeves to the front edges and really like how it looks n plays now.
#5 7 years ago
I had the same problem.
Undid a couple of screws, pulled out the switch, straightened it back up to normal...
Works like a charm!
#6 7 years ago
Quoted from Chambahz:
Works like a charm!
That works too but you'll be doing it quite a bit. I did it the 1st few times n got tired of having to adjust them.
#7 7 years ago
Quoted from smassa:
I had to adjust mine when I first got the game, but it's been fine ever since.
#8 7 years ago
Quoted from gweempose:
You must not be going to the lower PF as much as me. Bashing on the edges of those targets will make them shift over again.
#9 7 years ago
Quoted from smassa:
Did you remove the lower PF to fit the red posts? They look great.
#10 7 years ago
Quoted from Gorgar1:
I took the posts out with intention of switching to the standard posts like the ones you see on AFM and other BWM's games but the top of the post was too wide to fit into the hole at the top of the plastic. So I just took the existing posts out, wrapped some black electrical tape just enough so the cliffy sleeve wouldnt move around on the post and put them back it. Worked out great you can control the ball a little bit more down there.
#11 7 years ago
Quoted from smassa:
I agree : each time I re-adjust them, it shifts again after a few games only
Quoted from SealClubber:
It doesn't work for me. And it is really not easy to adjust : the targets shift by themselves when you tighten the 2 screws that hold them...
6 months later
#12 7 years ago
Quoted from smassa:
Ok, now one of the targets of my acdc stucks also .
Any news about the mod with cliffys sleeves?
I fear, if i remove the rubber rings, the lower playfield ball will be damaged..
1 month later
#13 6 years ago
I unscrewed the two little screws that hold the switch together not the screws the hold the switch to the PF and it worked a treat but I'm noticing it's starting to move back again
#14 6 years ago
i had to take mine out, and straighten all the blades. they shifted off of one another so the contact pads were not touching. once that happened, worked great ever since.
Filament Printing
Hookedonpinball.com
€ 25.00
YOYOKOPTER MODS
$ 54.99
$ 499.95
Pin Stadium Pinball Mods
