Hi, I've an AC/DC premium and of late it's been subject to bad flicker on the GI and lamps.
I was looking through diagnostics today and found that the flicker is only apparent when RGB lights are on, so I can assume that aspect of the circuitry is faulty - or anyone else have a clue?
If you go to DIAG and then to ACDC then to RGB test. If your machine flickers, it will do so now, if you set all RED GREEN BLUE values to 0 then the flicker will stop (but you lose RGB lamps).
I also have a couple of led lamps on in the flame plastics just next and down from the group "animation" panel. I don't know if this is related.
