Hi,
I noticed that the flasher 31, located under the red dome on the right ramp is stuck on.
This flasher wasn't working anymore, so i did replace the bulb and it stays on all the time.
I checked the manual and saw it's driven by Q31.
I inspected the wires on the socket and followed the cables under the playfield and couldn't find a short or a damaged wire, so my guess is that the transistor (Q31) is bad.
Your advice please ? Should i replace this transistor ? Is there something else you would check or replace on the power driver board ?
Thanks in advance
