(Topic ID: 50742)
Pinball-Browser : Customize your game !
By oga83
10 years ago
  • 5,426 posts
  • 745 Pinsiders participating
  • Latest reply 2 days ago by oga83
  • Topic is favorited by 857 Pinsiders
17 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 5,426 posts in this topic. You are on page 96 of 109.
#4751 1 year ago
If we had a license do we need to donate again for version 8? I press the "Register" and it says "Your license has been correctly registered" but when I restart it just ask the same thing again. Previous version just pulled my license in.
#4752 1 year ago
Quoted from daphishbowl:
Same here. Was just going to donate again.
#4753 1 year ago
Quoted from PoMC:
I believe there is now a one year expiration on the license, can't find that post but if you bought it over a year ago pretty sure you'll need to reinvest to use new versions.
#4754 1 year ago
Quoted from PinballHaven:
Thanks man sounds good. Just wanted to make sure it wasn't a glitch.
#4755 1 year ago
Correct. It's in the version 8 announcement, found in the key posts.
https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/94#post-6653110
Well worth buying a yearly license. The program is extremely useful and well maintained.
#4756 1 year ago
Quoted from cleland:
It does with the pro but not the LE/Premium image.
Thanks, luckily I have a Pro. Where do I download Pin Browser? The link on page 1 of this post is not working and I have cleared my cache and all other necessary steps.
#4757 1 year ago
Quoted from flipperstick:
The link is currently working.
https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images#post-872012
What browser, version, and are you getting an error message? Any other details you can provide?
#4758 1 year ago
Quoted from YeOldPinPlayer:
I am using the latest version of Chrome, and tried with Firefox, and I am not receiving any error message. Nothing happens when I click the link. I also have .NET Framework 4.0.
I have cleared my cache and history.
I will try with IE next and then update this post.
Update:
It worked with IE; however, now my computer is warning me when I attempt to open it.
#4759 1 year ago
Is there a Avengers IQ sound mod available?
#4760 1 year ago
Update:
To get it to work in Chrome, try this:
Right-click on the link and select "Open link in new window".
That window will come up blank.
Hit the Reload button.
File should start downloading.
#4762 1 year ago
The objections of licensors is probably the biggest reason Stern keeps changing their code in a way that makes PB ineffective on some new releases.
Also, same as any other data you want to keep, back up your data. If the next code release isn’t to your liking and you have no backup it’s more difficult to revert to the last version you liked.
#4763 1 year ago
I don't have a "real" Stern yet but I hopefully should soon. So far I've only used Pinball-Browser to update songs & associated text on AC/DC and Metallica for virtual pinball.
I'm guessing for real machines it would be a good idea to have 2 or 3 SD cards with modified code, official code, and maybe the prior release in case of issues. Or at least have the images backed up so they can be re-written. Is anybody using a SD card switcher to be able to more easily switch between different code?
#4764 1 year ago
Quoted from KSP1138:
I have at least 6 different SD cards for my Aerosmith video code. I just pop in whatever version I want to use. Last week I made a Led Zeppelin playlist for Aerosmith, so have a separate card just for that.
#4765 1 year ago
Quoted from PoMC:
Thanks, it will probably be a while before I would need to worry about swapping cards with Mandalorian. And I guess there might be some insider connected related "issues" to figure out.
#4766 1 year ago
I go to Stern’s website now and then and download an image. Save them on my pc. If one were a skilled coder they could probably automate that process.
https://sternpinball.com/support/sd-cards/
#4767 1 year ago
ok, I might be stupid, but I'm not finding where to dl the soft?
#4768 1 year ago
Quoted from Nihonmasa:
http://download.pinballbrowser.com
#4769 1 year ago
Thanks, done!
So next newb question:
I tried with Aerosmith, but the latest image from Stern's website does not seem to work with the tool.
Same Issue with Maiden.
Is there a way to find the old ones which might work?
edit: trying the dl from within the app
edit 2: it opened the file that way. Installed the video codec, but no video reading; there's no error message but nothing appears.
For the sounds I have a "cannot play file".
using the latest aerosmith prm code
edit 3: l'export de videos marche
#4770 1 year ago
These newest game codes can't be opened with Pinball Browser 8.03:
Batman 66 1.06 PRE/LE
The Mandalorian 1.02 PRE/LE
The Munsters 1.11 PRE/LE
#4771 1 year ago
Thanks, done!
I can send you a link to my file but it contains video and song changes already. You can use this as a starting point. Are you using the SD image file from the Stern site?
#4772 1 year ago
Quoted from pinballjah:
yes please, that'd be great
Yes I am using the SD image, the other code just won't open
#4773 1 year ago
I have a few questions for those of you updating songs in Spike 2 games using Audacity to prepare before importing into Pinball Browser.
What is your project rate set at? 24000hz?
Are you doing any compression?
Are you exporting as .wav or .mp3?
I updated some songs in Iron Maiden and they sound okay, but I'm just trying to get as close in quality to the other tracks as possible. Thanks.
#4774 1 year ago
Quoted from mbott1701:
I been using WAV, no compression and don’t touch the preset rate.
#4775 1 year ago
Thank you!
#4776 1 year ago
I am trying to update some audio features but am having issues with ffmpeg running after downloading the file. After running it through 7zip and trying to run the executable for ffmpeg, I just receive a flash of a popup window and nothing happens. I am attempting to run in on a PC.
Any advice?
#4777 1 year ago
I am a new user and having the same problem.
#4778 1 year ago
Quoted from Crispy77:
I'm sorry about that.
It's not exactly the same problem because you already have a v8 license but it won't register correctly.
Most often, this happens when Pinball Browser is started from a readonly directory (or from the .zip file), or is used on a Windows XP system.
Pinball Browser needs write permissions to the Pinball-Browser.xml file.
#4779 1 year ago
Quoted from oga83:
Same problem for me. It just goes into a loop asking to register everytime I start.
Running on win10, started from a directory where everyone/all users has full control on the directory and the xml file is getting updated.
#4780 1 year ago
Quoted from monkeybug:
If your Pinball Browser v7 license is older than 1 year, it won't work with v8.
More information here
Otherwise, PM me your token id and I'll check what's going on.
#4781 1 year ago
Do you expect the Rush code will work with PB when released or will we need to wait for an update? Looking forward to playing with the code once released. Thanks.
#4782 1 year ago
Unfortunately, I doubt is as the most recent firmwares for Munsters and Mando don't work with PB.
#4783 1 year ago
Quoted from oga83:
Ok, thanks. Is that something you plan to remedy in the near future?
#4784 1 year ago
Has anyone had any luck changing out the text for the song names in Led Zeppelin? See below image as an example. They seem to be controlled by Request #5 but I had no luck when I updated the Song name text. Was able to change out two songs and like to be able to get the text to change as well.
Maybe even the announcement of the song name. Thanks for the help! [quoted image]
I got pretty far with it. There one image for an album cover in my case for one album cover other than that Im happy with results. I kept it zeppy just songs li liked better. I also changed all the high score names and such to reference the respective titles. It was very easy.
#4785 1 year ago
Quoted from oga83:
You can't.
Download an SD card image from Stern's website here :
https://f002.backblazeb2.com/file/gamecode/can_crusher-1_01_0.is
You can't.
https://f002.backblazeb2.com/file/gamecode/can_crusher-1_01_0.iso.zip
Finally made all my updates, but when I save the new file (same name) to an SD card, the game will not boot up. Any advice?
#4786 1 year ago
Quoted from gameroompinball:
After you make your changes, close the firmware. Now open the SmartDMD tab, open the firmware, insert an SD card and write to that SD card drive letter.
#4787 1 year ago
Rush Pro code out on Stern site. Who wants to crack this bitch!
#4788 1 year ago
Absolutely love to change out some songs. Following
#4789 1 year ago
Reminder that Pinball-Browser would need to support it before anyone can start tinkering with the audio/video callouts. (I don't see any versions of gamecode for Rush on the supported code list yet, and due to the new Internet-Connected code, might not get added very quickly).
#4790 1 year ago
each future code update may break the functionality of Pinball Browser. Even if fixed now it would make sense to wait until codes gets around version 1.00 and updates do not happen that often any more. but i understand to urge to play around with it
#4791 1 year ago
UP ^^
-1
#4792 1 year ago
I cannot for the life of me be able to get the latest Whoa Nellie .spk file to open in the latest Pinball Browser.
I downloaded the latest version of the firmware through the Pinball Browser software - but no matter what I do, I can't open it and it keeps saying Unrecognizable Firmware.
Can someone walk me through the process?
I have read every post on here and can't seem to get .spk files to open - and unfortunately - that is the only format available.
#4793 1 year ago
Quoted from HiRez00:
Whoa Nellie – V1.55.0 SD image https://f002.backblazeb2.com/file/gamecode/WN-1_55.iso.zip
It's on sterns SD Card image page https://sternpinball.com/support/sd-cards/
Image opened fine for me
#4794 1 year ago
Pinball Browser can't open .spk file anymore since v7.x
See the here and here for more information.
#4795 1 year ago
patiently awaiting the next update to open the rush image
#4796 1 year ago
Quoted from j_m_:
Like to update Subdivisions to the original video. Too much concert footage IMO. Maybe some of the black and white footage to 80s concert footage.
#4797 1 year ago
Sorry for the noobish post- I read the key posts about macros but don't fully get it yet.
I had edited a ton of sound effects and videos on SW Pro 1.05 in the past but I never saved any macros at the time.
Does that mean there is no easy way to identify which files were changed, for exporting and importing into the 1.10 code?
#4798 1 year ago
Has anyone had success swapping in new animations for the Ecto goggle on GB RE/LE? I think that the cat at a minimum can go.
#4799 1 year ago
Hi !
I'm working on changing the sounds of my pinball machine, and I am also looking to change the startup image of the game.
I found a GameLogo.png file at /dev/sda2/gamename/assets/lcd/, I tried to replace it but it shows a black screen instead of the game logo. And if I replace my new file with the original file still black screen.
Has anyone ever managed to do this?
#4800 1 year ago
Quoted from Furtys:
Hi !
have you tried to delete the file first then import it again?
name needs to be the same, as dimensions and file type. But i have to admit i have never done it.
maybe recreating the file is better than overwriting, could be a solution.
Flashinstinct
Decals
This page was printed from https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/96 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
