Quoted from oga83:This seems normal but I can't tell for sure from this information.
Try the same PB/FFmeg/Firmware on a different PC and see if it works.
I'm not aware of anyone else having this kind of issue.
Hey oga83 . Unfortunately as I mentioned I don't have any other PC to use, I've got to get this one working. I decided to reach out in the FFmpeg forum itself and a couple of helpful people have had me do some command line tests. In all tests they are saying that FFmpeg (ffprobe.exe specifically) seems to be working as expected. Here's our latest correspondence and their thoughts.
[FFmpeg Forum User] The first log entry appears to show how the app called FFprobe. You
could try to run that same command yourself from the Command Prompt:
C:\> "C:\PB_short_path_test\PinballBrowser756\ffprobe.exe" -v error
-show_format -show_streams -print_format xml "C:\Users\My
Name\AppData\Local\Temp\pbi2.mp4"
When you run that, what do you get?
Also, the final quoted entry in that command is the location of the file
being probed. Maybe try this again, but with you filling in the location
of the file you want to use.
Try posting the complete uncut command and output of those two experiments."
[Tim] Here is the command line output of both tests one after the other:
TEST 1:
C:\Users\My Name>"C:\PB_short_path_test\PinballBrowser756\ffprobe.exe" -v error -show_format -show_streams -print_format xml "C:\Users\My Name\AppData\Local\Temp\pbi2.mp4"
<?xml version="1.0" encoding="UTF-8"?>
<ffprobe>
<streams>
<stream index="0" codec_name="h264" codec_long_name="H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10" profile="Constrained Baseline" codec_type="video" codec_time_base="1/60" codec_tag_string="avc1" codec_tag="0x31637661" width="1360" height="768" coded_width="1360" coded_height="768" closed_captions="0" has_b_frames="0" pix_fmt="yuv420p" level="30" chroma_location="left" refs="1" is_avc="true" nal_length_size="4" r_frame_rate="30/1" avg_frame_rate="30/1" time_base="1/15360" start_pts="0" start_time="0.000000" duration_ts="236032" duration="15.366667" bit_rate="986381" bits_per_raw_sample="8" nb_frames="461">
<disposition default="1" dub="0" original="0" comment="0" lyrics="0" karaoke="0" forced="0" hearing_impaired="0" visual_impaired="0" clean_effects="0" attached_pic="0" timed_thumbnails="0"/>
<tag key="language" value="eng"/>
<tag key="handler_name" value="VideoHandler"/>
<tag key="encoder" value="Lavc57.15.100 libx264"/>
</stream>
</streams>
<format filename="C:\Users\My Name\AppData\Local\Temp\pbi2.mp4" nb_streams="1" nb_programs="0" format_name="mov,mp4,m4a,3gp,3g2,mj2" format_long_name="QuickTime / MOV" start_time="0.000000" duration="15.367000" size="1897367" bit_rate="987761" probe_score="100">
<tag key="major_brand" value="qt "/>
<tag key="minor_version" value="512"/>
<tag key="compatible_brands" value="qt "/>
<tag key="date" value="2018-11-08T21:49:34.493414"/>
<tag key="encoder" value="Lavf57.16.100"/>
</format>
</ffprobe>
TEST 2
C:\Users\My Name>"C:\PB_short_path_test\PinballBrowser756\ffprobe.exe" -v error -show_format -show_streams -print_format xml "C:\PB_short_path_test\123.mp4"
<ffprobe>
<streams>
<stream index="0" codec_name="h264" codec_long_name="H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10" profile="High" codec_type="video" codec_time_base="1001/120000" codec_tag_string="avc1" codec_tag="0x31637661" width="1920" height="1080" coded_width="1920" coded_height="1088" closed_captions="0" has_b_frames="0" sample_aspect_ratio="1: 1" display_aspect_ratio="16:9" pix_fmt="yuv420p" level="42" color_range="tv" color_space="bt709" color_transfer="bt709" color_primaries="bt709" chroma_location="left" field_order="progressive" refs="1" is_avc="true" nal_length_size="4" r_frame_rate="60000/1001" avg_frame_rate="60000/1001" time_base="1/60000" start_pts="0" start_time="0.000000" duration_ts="1577576" duration="26.292933" bit_rate="20046181" bits_per_raw_sample="8" nb_frames="1576">
<tag key="creation_time" value="2020-09-07T19:57:49.000000Z"/>
<tag key="language" value="und"/>
<tag key="handler_name" value="Core Media Video"/>
</stream>
</streams>
<format filename="C:\PB_short_path_test\123.mp4" nb_streams="1" nb_programs="0" format_name="mov,mp4,m4a,3gp,3g2,mj2" format_long_name="QuickTime / MOV" start_time="0.000000" duration="26.292933" size="66199052" bit_rate="20142006" probe_score="100">
<tag key="major_brand" value="mp42"/>
<tag key="minor_version" value="1"/>
<tag key="compatible_brands" value="mp41mp42isom"/>
</format>
</ffprobe>
[FFmpeg Forum User] What this seems to show is that FFprobe is installed, and runs correctly, giving reasonable output. That makes it more likely that the log entries you posted are noting a successful run of FFprobe, instead of a failed run. I think that puts the ball back in the PinballBrowser court. Is it getting the same result when it calls FFprobe? And that is a question for them, not for this list.
oga83 Does any of this help?
