I like your edits for the Star Wars videos fooflighter! Can you make some custom videos for Jurassic Park too?
Quoted from pinballfan2000:
Request 201 is the game over music
Thanks very much. If I replace the track, what happens if the replacement track is longer? As this track fades out, will it matter?
Quoted from pinballjah:
I’m a novice at this too, but I believe a recent changelog confirmed that PinballBrowser automatically trims the track, so it will just cut off
Game over track lasts 4 minutes, 48 seconds and 642 miliseconds. If you try to import track that lasts longer than 4 minutes and 48 seconds, it will be cut in order to be 4 minutes, 48 seconds and 642 miliseconds. Duration of music can't be changed in Pinball browser
Quoted from Rdoyle1978:
Yeah, if track you use to change music is longer than original, it will be cut to be same duration as original song
Thanks for the reply. So if I reduce song to be a lot shorter, it should work fine? I find songs after the game ends are better shorter so the music doesn’t bother others playing different games.
If you import track that lasts less than Game over track (4 minutes), there will no be music for remaining time. When you import track, you can also set start and end of track
I made a 2nd sd card with alternate music for my Iron Maiden a while back. Can someone point me toward how to find the images of the song titles? Thx
Quoted from Vader77:
I'll check now for you
Thanks for looking! They are stationary images much like wheels in front ends with videos behind them. Maybe there could/needs to be a tab for those?
I probably could but the style clash would be too apparant. Although come to think of it...I really don't like the missle shot missed or shoot again vids...
Let me look at it at see what i can come up with
You may have just given me a new project
Nice! If you need any ideas about replacing shoot again or missile shot missed videos, I have an idea for you
I have a little bit of and idea but I'm all ears
Okay, so if I were you, and when I would customize Shoot again video on Stern's JP, I would import Ball Save animation, but when ancelosaur kicks the ball with his tail at the screen, when screen is about to crack, instead of that, SHOOT AGAIN letters will appear (I would draw them in paint)
I don't have any ideas about Missile Shot missed video. I have never seen that video. Which script in PB is Missile missed video?
Cool, I honestly haven't opened up JP in pinbrowser so I'll have to search, don't know if missle vid is buried in there...
I'll take a look at the ball save animation also..I have a number of things i can add effects, sounds, overlays, particles so I'll try to come up with something
Found the missle shot missed, it's 0x42, the first part is awesome, just dislike the fuzzy screen shot missed portion...i think i can fix it
Is that clip one where helicopter drives off with dinosaur trapped inside box? Because for me, 0x42 script in JP is with
helicopter
I just downloaded the SD image from stern's site and I'm using that with the browser, it is the latest version..here's a screenshot of the vid and location
So I replaced Request 201 and it did work ok. But the track is starting from the middle of the song and it only plays for about 10 seconds. Request 201 is show a total time of 5 mins 59 secs. I think it is actually playing Request 200. Thanks.
Quoted from fooflighter:
I just downloaded the SD image from stern's site and I'm using that with the browser, it is the latest version..here's a screenshot of the vid and location[quoted image]
Oh, I was using .spk, and that's why my 0x42 script was different video
I'll download sd card too
BTW, is 0xF0 video script on sd card a ball saved animation? It should be ancelosaur kicking the ball at camera, then camera cracks, and says "Ball saved"
Now I know scripts for .spk and sd are different, I'm not sure if 0xF0 on .raw sd card is ball save
I just checked AC/DC code, and request 200 is 5 minutes long, yeah
I just tried JP Pro SD Card, and 0x42 is Missle Shot Missed for me too
I found out that 0xF0 is not ball saved animation
I'll find video script for Ball saved now
EDIT: 0x11B is the Ball Saved video in sd card file
I was just making a post and my internet went out I've got all the locations for the videos right now I'm comparing those with the time signatures for the audio files... I'll post more when I can... Corona virus got my Fiber line
**Update. I have the link working now.
Sorry it didn't have shared address rights.
It should work now!!
Playing with the ball save and missle vids....
I made the ball hitting the glass sound more distinctive compared to the original
For the missle shot miss, instead of the white static, messing around with something new..
Still works in progress but it's fun to play around with.
I just opened link, and for some reason, it says that owner didn't give me a permission to see link
My gmail is ofthecomiclifep@gmail.com . Can you approve my request for permission?
Sorry, it defaulted to link sharing off, it should be okay now!
Quoted from Arcade:
Here are the Song locations and length for each machine that you would need to change.
When you change this one file it does all the little snippets as well.AC/DC Pro
214 War Machine 3:07
I am looking to replace War Machine on my AC/DC Pro. As Request 214 only plays 7 seconds of the song and then Request 215 plays, do I need to replace 214 and 215 or just 214? If I replace 215 as well, do I need to delete the first 7 seconds as this part already plays in 214 first?
Currently I have replaced 214 and 215 both with the full song. The game will repeat the first 7 seconds of the track over and over again. Then once the ball is shot, it plays 215. Thanks for the help! Jim
Pinball Browser supporters,
I have some bad news. A couple days ago, Stern made some modifications to stop Pinball Browser from working. Again.
These modifications have clearly no other goal than that, and have no benefit for the user.
The nature of the changes are technical. New encoding techniques, changing how sound files work...actions that are specifically designed to make it difficult to modify a game. None of these changes are for the benefit of the owner of the game.
Stern is spending significant developer time on keeping their customers from modifying their games. Looking at these changes they've made, I'm actually surprised this is their focus, rather than features and game code updates that the players of the games really care about. From a risk/reward standpoint, they are also increasing the risk of introducing bugs in the code with no reward for it.
I still don't understand why they want so badly to stop PB.
I'm not their enemy, I've only played fair with them. I've always discouraged or made it difficult for copyrighted materials to be shared or distributed. I've never included functions to change things like the regional limitations (US/EU), to reset the lifetime audits, change the game rules or other things like that...
It is clear that it's easier for them to throw sand in the wheels of PB than for me to keep PB working. That must be their goal.
I have to warn you all that one day will come where it won't be possible to adjust PB and you won't be able to customize your games anymore. To prevent that, I suggest that all of you write to Stern about this unnecessary actions against PB. I would like to work with them! At a minimum, I need to understand what their issue is with a customer modifying their own machine. If a person buys a Ford, does Ford make all the bolts in the car tamperproof so you can't swap out a part? Is there some licensing issue that we don't understand?
Hopefully, they will engage directly with us on this.
Crap, does this mean that if they do any software updates they will cease to function with PB browser?
I'm not distributing this for sale...How is this any different than modding my machine?
Yeah, every time they release new code version, they implement changes so we can't modify the code
Really Hope they don't stop functionality of Pinball Browser
This is nothing more than a mod, and I'm not reselling these assets
I also hope they won't quit Pinball Browser. PB is great software
Once I'm done, you can PM me for the files if you'd like them for use with Pinball Browser
Sure!
Tell me when you are done, so I can PM you
Quoted from oga83:
Suspect it's a licensing issue.
Some IP owners require the licensees to take all action to protect and secure IP such that the product is only the approved product and can't be modified or that any artefacts they provide are kept secure, it could be this makes them take this action.
Neil.
