Pinball-Browser : Customize your game !
By oga83
Stats
  • 2,730 posts
  • 450 Pinsiders participating
  • Latest reply 1 day ago by Arcade
  • Topic is favorited by 588 Pinsiders
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
There have been 227 images uploaded to this topic. (View topic image gallery).
24 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 2730 posts in topic. You are on page 51 of 55.
#2501 3 months ago
exactly that's why i'm finding it so strange
#2502 3 months ago
Have a question. After I download the Batman 66 update from Stern I have 2 files. After I unpack the files and make changes with PB I'm left with the 2 original files (.002), 1 large 3.80G file containing the altered code (.spk) and 1 dat file. I know not to bother with the .dat file. But what remaining file(s) should I being loading onto my USB for the code update? Just the larger 3.80G file? If there's updates to the node boards I want to make sure I'm loading them into my machine. Thanks!
#2503 3 months ago
Quoted from thundergod76:
Have a question. After I download the Batman 66 update from Stern I have 2 files. After I unpack the files and make changes with PB I'm left with the 2 original files, 1 large file containing the altered code and 1 dat file. I know not to bother with the .dat file. But what remaining file(s) should I being loading onto my USB for the code update? Just the larger 3.80G file? If there's updates to the node boards I want to make sure I'm loading them into my machine. Thanks!
I think this is answered in the faq
https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/38#post-2722290
#2504 3 months ago
Quoted from oga83:
Yes, this is possible.
More informations about SmartDmd here and here.
First, make sure that the demo version works on your Raspberry version.
Thanks, now that i know that is possible, i try
#2505 3 months ago
It's been a LONG time since i used Pinball Browser, and i did buy the license at that time; But, is there a way to export sound files from spike games? I only see an import option. Im running v5.76.
#2506 3 months ago
To continue my topic above..
I figured out that the filled G-E-A-R-S letters (0x85F-0x863) are not what is being picked up when the targets are hit. It is actually pulling the completed letter from an alphabetic list: G is 0x1289, E is 0x1287, A is 0x1283, R is 1294, S is 1295.
The question is where do I find what is pointing to these location so I can change it to my new letters?
#2507 3 months ago
Following up: I edited the images (G is 0x1289, E is 0x1287, A is 0x1283, R is 1294, S is 1295) the to be the ones I wanted. Good news/bad news: my filled in letters show up correctly for hitting the GEARS targets, bad news the end of ball "BONUS" and "REPLAY" that use the same letters are misspelled now.
Further testing: I started with the unmolested code and changed the text for BONUS and REPLAY in messages, uploaded the code and those 2 words were correctly changed.
Maybe I'm missing something. Can someone tell me what else to look for in the code? What do lines lines with things like this mean??
+%u GEAR%P1//S/%
GEAR%P1//S/%
+%u GEAR%P1//S//%
#2508 3 months ago
Quoted from gameroompinball:
+%u GEAR%P1//S/%
GEAR%P1//S/%
+%u GEAR%P1//S//%
That's interesting code there.
It's some kinda to string format code. My guess is that the code is pulling up that string, and using those commands ("%P1", "%u") to determine whether thedisplay shoudl show "x GEAR" or "x GEARS". Again, I'm just guessing, since I haven't actually seen the animation, that the +u% is going to be a number about how many you've collected.
#2509 3 months ago
Quoted from Coyote:
You got it right
#2510 3 months ago
Quoted from Eskaybee:
same question for SAM games - does anyone know a way to export sound files?
#2511 3 months ago
These images are part of a font. My guess is that there must be a string somewhere that points to the correct letters.
Did you try to modify the strings "GEARS TARGET", "GEARS:", "OBJ GEARS", "GEAR(S)" and some others ? ("Message" tab, "Search Firmware" button)
#2512 3 months ago
You have to use an older version of pinball browser 4.40 or earlier or 6.00 (corrected, thanks oga!)
Quoted from dmieczko:
#2513 3 months ago
This is possible with Pinball Browser v6
#2515 3 months ago
Quoted from oga83:
Worked like a charm- thank you!!
#2516 3 months ago
Quoted from oga83:
I believe I have tried modifying the text on all of those lines using the firmware search. I'll start from scratch tonight and report back.
#2517 3 months ago
I'm almost done tweaking my MET Pro v1.70 colorization, but cannot find the "Combo Champion" graphic anywhere to adjust. See the attached photo - has anyone figured out how to properly color this graphic? Where is it in the code - I cannot find it.
#2518 3 months ago
they may have used a single frame from the flaming eye animation and then flipped the animation and used a 2nd frame (like a camera double exposure)
#2519 3 months ago
I took a quick look and it appears they used 2 images.
Image-0x07C5 - the eye ball on the left
Image-0x07D6 - the flaming tail on the right
If you overlay both of these you get the image you posted. Not sure what would happen if you modified the individual frames, it probably would mess up the animation.
Quoted from j_m_:
#2520 3 months ago
Any chance we will ever see an apple compatible version of pinball browser? I've been using it with various work around applications but it is a real pain.
#2521 3 months ago
Quoted from luvthatapex2:
Pretty sure you are correct. What's weird is both those frames are colored correctly, using the same color palette, but this image is certainly shown using the wrong palette. Gotta figure out why...
#2522 3 months ago
Hi, new to pinball browser and was wondering about a couple of things. Want to upgrade my AC/DC code and keep my high scores. I can put in unique initials for grand champion, 1st place, 2nd place, 3rd place, and forth place. When I try to change the other high scores if I put initials in one, it changes all the high score initials to the same thing. Will the pay version of PB let me put in unique initials for each high score? When I open the .bin I got that has three changed out songs it asked me if I wanted to get bookmarks from the web. I answered yes here. Will this screw up my custom .bin file that has three changed out songs?
Disregard - oag83 answered these two questions for me...... Thanks!!
#2523 3 months ago
Still struggling with this - if anyone has been successful coloring a combined graphic, please let me know...
#2524 3 months ago
I have done this with the bonus multiplier animation of StarTrek and worked without a problem.
#2525 3 months ago
When connecting a PC to your pin via the serial port do you need to do anything special like flipping dip switch 8 on the CPU board? Or do you simply just plug in the USB end of the serial cable?
Thanks,
Tslayer
#2526 3 months ago
I thought that flipping dip switch no. 8 was to let the system know that you wanted to update it and to look at the serial port and/or usb port for a file with the proper name. if found, it's boot strap code starts the update process
#2527 3 months ago
Quoted from j_m_:
Ya, that is correct. Just wanted to make sure I didn't have to do that for the pinball browser pc connection to the pin....
#2528 81 days ago
I just realised I never updated my Ghostbusters with the most recent code from January this year. As the update is very small changes I wanted to keep my high scores, and I've been trying to edit the code with Pinball Browser for this purpose. Unfortunately I've run into a stumbling block - the scores I want to enter are ten digits, and it's only letting me save a nine digit high score.
For example, my GC is 4,638,160,150 - but if I enter this ten digit number in Pinball Broswer it doesn't change the value in the list when I click ok. If I enter that number without the 4 at the beginning it does change the value. Is there a workaround for this?
#2529 81 days ago
You crossed a 2^32 boundary. 2^32 - 1 = 4,294,967,295. I betcha that value works. Might be that stern is using a 64 bit value, and the pinball browser only supports a 32 bit value at this point.
#2530 80 days ago
Quoted from openpinballproj:
The idea that they need 64 bits for a pinball score is laughable. It's time to stop stroking the egos of guys that love score and ease it back. It's like measuring your dick in centimetres, it doesn't make it any bigger.
#2531 79 days ago
Ok, thanks for the explanation. Frustrating, but what can you do!
Quoted from Darscot:
I agree - the scores on GB in particular are insane.
#2532 79 days ago
I don't know how the pinball browser works, but you might be able to change a field just above it or just below it to fix it. So in your case, you would change the field above or below to 1, and then set the score field to 343,192,854. Since it is a 64 bit field you might be able to break it into 2 32 bit fields that the pinball browser will understand. So the upper 32 bits are simply 1, while the lower 32 bits should be 343,192,854. I'm not sure if you have access to each of those fields, but if you do, that should fake out the browser to write the correct values into memory for the pinball machine.
#2533 78 days ago
Not exactly.
It is true that high scores are stored as 64 bits values in NvRam (on recent firmwares).
However, what is modified here is not the HS in NvRam. It's the default HS adjustment (which you can find in the Adjustment system menu).
Unfortunately, the adjustments values are 32-bit long, not 64... That's why you can't enter a value higher than 2^32.
There is a value multiplier (x10 in most cases) that allows a 'big' adjustment values to be stored (divided by 10) but I was not able to figure out exactly how it works on all games untill now. See this post and the following ones.
BTW, Pinball Browser can also modify "realtime" 64-bit HS (as opposed to "factory default HS" above) : for SAM games, you need the communication patch, and for Spike games, you need to work on the SD card (not a .spk file). Please note that it is not available for all games.
#2534 74 days ago
Anyone able to run version 6 on a Mac using Crossover? I am attempting to work on Spike Roms now and I get an error "Unhandled exception has occurred"
Details seem to pertain to Jit Debugging or something like that? I have never had an issue running versions 4-5 but I don't think they handle Spike?
I'm still using my same "Bottle" Of Windows XP. Should I try using Windows 7 or 8 and 32 bit or 64 bit?
EDIT: By changing the sound output to "Legacy" under the config tab I am able to open and play KISS sounds, but not GOTG or Aerosmith.
EDIT: I am trying to load directly from code I've downloaded from Stern's website. Should I be trying to load from the SD card in the game?
#2535 73 days ago
Quoted from cleland:
Please PM me the details
This is required for XP but there are some limitations (for example, mp3 files can't be imported)
Yes, the result can be different
#2536 72 days ago
I zeppelinified #game_of_thrones yesterday and thought someone might appreciate what the song locations are. Anything not listed is a dupe of another location. The only one I haven't heard is 64.
28 0:16.948 Choose your house/ball in shooter lane
29 1:34.394 Ball 1
30 1:32.384 Ball 2
31 1:32.403 Ball 3
32 0:29.541 Choose your battle
33 0:44.802 Mystery
34 1:08.131 Targaryen I
36 1:16.244 Targaryen II
38 1:21.461 Targaryen III
40 1:38.403 Stark
42 1:23.619 Lannister
44 1:29.140 Baratheon
46 1:09.122 Greyjoy
48 0:59.992 Tyrell
50 0:57.882 Martell
52 1:00.001 Any two modes played together
54 0:25.274 Winter is Coming shot lit
55 1:29.605 Hand Of The King/Iron Throne lit
56 1:14.995 Winter Has Come multi
58 1:09.821 Iron Thone multi
59 1:33.914 Blackwater multi, brief attract music
61 1:14.321 Hand of the King multi
63 1:24.706 Wall multi
64 1:10.405 ??
65 0:33.882 Video mode
67 1:38.404 High score music
#2537 72 days ago
And here's what I have so far for #stern-guardians-of-the-galaxy in case you want to soundtrack it all up (it's sooo much better that way). I'm guessing on 55, 63 and 65 because they're not in the code yet.
31 2:01.929 Cherry Bomb
32 1:57.816 Hooked On A Feeling
33 0:15.157 ?
34 0:36.000 Mode pick screen
35 1:41.392 Sibling Rivalry & end of game
36 1:26.125 Escape Kyln
37 1:26.513 Knowhere
38 2:46.951 Quill's Quest
39 0:55.376 Yaka Arrow
40 1:09.717 Sanctuary
41 2:34.450 Pod Chase & Rocket double scoring
42 1:02.125 Antiquities Shop
43 9:15.897 Groot Multi
46 6:31.432 Orb Multi
55 0:35.616 ? Quill's Quest II ?
56 2:07.393 Knowhere II
57 3:11.956 Pod Chase II
58 0:52.983 Yaka Arrow II
59 1:23.708 Escape Kyln II
60 0:31.291 Antiquities Shop II
61 1:57.149 Sanctuary II
62 0:12.023 Sibling Rivalry II
63 4:44.071 ? Immolation Initiative ?
65 4:07.179 ? Save Xandar ?
#2538 72 days ago
Quoted from deeplennon1:
And here's what I have so far for Guardians of the Galaxy (Pro) in case you want to soundtrack it all up (it's sooo much better that way). I'm guessing on 55, 63 and 65 because they're not in the code yet.
Did you have to do anything different between changing GoT music and GotG as far as uploading, settings or modifying? Or is it the same ...edit a song to match the length of the existing song, add it to the file, save to USB, upload to machine
.... I've changed many machines pre-color screen with ease, but want to mess with GotG for a better soundtrack
#2539 72 days ago
Quoted from Max_Badazz:
I just changed the music. I did edit the files for specific length though I don't think you need to do that as long as they are longer as I imported in some without trimming them just to be able to find the specific song locations easier. It appears Pinball Browser will just cut them down to correct length without any issues with playback. I like to trim to the exact length and then add short fades to the end of songs for the final product though so there aren't abrupt endings during playback in the game.
Also I didn't upload via USB, I used new SD cards. I copied the original SD cards into Pinball Browser then put them aside in case their were any irreversible problems. I then wrote the modified versions to a new card. All of which is incredibly easy. This also allows you to easily swap in and out multiple different soundtracks. I'll likely be making a few different mixes of bands and such for GoT.
Definitely do it for GotG, it's a big improvement and works well with the game in how tracks play back etc. Less so with GoT as the songs tend to restart quite a bit, specifically the Ball 1, 2 & 3 tracks.
#2540 71 days ago
I zeppelinified Game Of Thrones (Pro) yesterday and thought someone might appreciate what the song locations are.
It would be great if you could share online bookmarks in Pinball Browser.
More informations in the "Bookmarks" section of the FAQ
#2541 71 days ago
Quoted from oga83:
Thanks, I was figuring there was a way to do that, I’ll check it out.
#2542 65 days ago
Pinball Browser v6.10 is now compatible with Spooky games
You can replace sounds or videos.
Just open the .zip file with Pinball Browser :
#2543 65 days ago
Many thanks to pinsider @hAbO for his help on this !
#2544 65 days ago
Waiting 2 years for version v6.
But still no wpc 95 game's
#2545 65 days ago
Quoted from oga83:
Many thanks to pinsider hAbO for his help on this !
I am not getting any sound bookmarks loading for RZ after checking online?
Edit: I was using a V023 beta file. Tried with the V022 official release and the bookmarks work.
#2546 61 days ago
Sorry if this has been asked/answered.
Am I required to pay again if I update the software? I updated to V6 and it wanted my key number... which didn’t work.
#2547 58 days ago
Anyone got a link for the last V5 plz ? cant find it anywhere on pinside
#2548 58 days ago
Quoted from Raknitz:
Only the latest version can be found on Pinside
#2549 56 days ago
Hi just picked up a new smartdmd setup. Hoping someone can share with me their ACDC premium file as pinball Mike no longer has it. Thanks Waldo dawaldo34@gmail.com
#2550 56 days ago
@waldo34
I had a file from mike for it but it was all messed up. it made me think that it needs to be re-colored from scratch
$ 29.99
Lee's Parts
$ 29.99
$ 11.99
$ 69.99
$ 8.95
$ 29.99
Cleveland, OH
$ 69.00
...redshiftLED
$ 24.50
$ 150.00
Professor Pinball
Colorado Springs, CO
Hookedonpinball.com
$ 92.95
$ 26.50
$ 380.00
Bright Lights Pinball
$ 45.00
$ 129.95
Hookedonpinball.com
$ 48.00
$ 5,699.99
Little Shop Of Games
Great pinball charity
Pinball Edu
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
