(Topic ID: 50742)
Pinball-Browser : Customize your game !
By oga83
8 years ago
  • 4,644 posts
  • 657 Pinsiders participating
  • Latest reply 1 day ago by pinballjah
  • Topic is favorited by 764 Pinsiders
14 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 4,644 posts in this topic. You are on page 35 of 93.
#1701 6 years ago
Quoted from RobT:
I love the "yet" followed by the winkie!
I can't tell you how important Pinball Browser has become to me. Between Mustang and TWD, I have to say I seriously doubt that I would own either pin if it wasn't for the ability to add/modify sounds with this software.
Agreed!
I think stern should hit the 'contribute with paypal' button!
#1702 6 years ago
For the record , there is no way i would have bought nib metle and twdle without pinball browser.
It's the modern age, consumers want more from their products.
thanks OGA!
#1703 6 years ago
I agree.
This software is huge for TWD.
I also liked it for AC/DC.
I don’t think I would have bought TWD without it.
#1704 6 years ago
Is there video of someone's TWD with altered call outs? (Yes I'm too lazy to search atm)
#1705 6 years ago
Quoted from Eskaybee:
https://pinside.com/pinball/forum/topic/walking-dead-le-sound-replacement-v-09
cheers to laziness
#1706 6 years ago
Is there a video out that explains how to change the songs?
#1707 6 years ago
I have pinbrowser set up at my office for quick checking of things and tried to play an audio file. It just tells me it can't play the audio file. What would cause this?
Im running 4.13 here.
#1708 6 years ago
Quoted from KingNine:
It can happen on old Windows versions.
Try another sound engine (advanced tab).
#1709 6 years ago
Quoted from oga83:
Thanks, that did the trick.
14
#1710 6 years ago
Spike is coming
Some more :
#1713 6 years ago
Quoted from oga83:
Spike is coming
Some more :
Awesome! Will you be able to display the LE's LCD footage?
#1714 6 years ago
Oga83.......You my friend make me so happy, I could seriously cry. You have done more for pinball than anyone individual I can think of. The ability to customize your machine to your liking is huge........I cannot thank you enough. Nick
#1715 6 years ago
Did anything more happen with the Whitestar system being supported in this software?
#1716 6 years ago
Quoted from oga83:
If you have saved your macros, you can adjust them when a new firmware is released by adding "ShifId" lines.
The syntax is as follow :
ShiftId,[Type],[OldId],[NewId]
where :
- [Type]=0 for images, 1 for sounds scripts
- [OldId] is the first object to be shifted (all the following ones will also be shifted until a new ShiftId tells otherwise)
- [NewId] is the corresponding new id. The keyword "ignored" can also be used to tell that the specified object (and the following ones until a new ShiftId tells otherwise) does not exist anymore.
For example, a list of macros designed for AC/DC LE can be adjusted for AC/DC Pro by adding the following lines at the beginning (to keep it simple, this is only for images, some lines would be needed for the sounds) :
ShiftId,0,0x5a1,ignored
ShiftId,0,0x5ab,0x5a1
The first line means that the image 0x5a1 (and the following ones) in the LE does not exist in the Pro
The second line means that all images starting at 0x5ab in the LE are at position 0x5a1 in the Pro
This is Walking Dead LE 1.24 and 1.19 side by side. New sound positions are on the left and the Millhouse TWD version is on the right. Personally, i cannot see a "shift" pattern that makes sense, but i don't know a lot about how these things work. Is this a simple shift or have they changed sound script positions to the point of having to examine everything line by line again.
Just one example of many script position changes i am hoping look simple to a smarter person .
Hoping to come up with a re-mapping solution.
#1717 6 years ago
Quoted from ezeltmann:
First of all, you should sort the list by "sound scripts", like this :
It is easier to see where new sound scripts have been inserted (or older sound scripts deleted).
I have squared the new sound scripts on the right.
The corresponding macro is :
ShiftId,1,0x30,0x32
ShiftId,1,0x31,0x34
This is only an example and I did not check the other changes further in the list (536 scripts have been added between those 2 versions !).
#1718 6 years ago
Quoted from thedarkknight77:
I agree. My Metallica Prem and ACDC Prem would not be in my collection if not for this man. THANK YOU!!!
#1719 6 years ago
Quoted from oga83:
ShiftId,1,0x30,0x32
ShiftId,1,0x31,0x34
thank you .. i think there is a lot of shifting to be done. doh!
#1720 6 years ago
Pinball Browser is currently being modified and tested for WWE
#1721 6 years ago
Just sent a PM about helping with WWE!
#1722 6 years ago
Pinball Browser will be able to display/replace videos
#1723 6 years ago
thats GREAT!!
cant wait to see this for AC DC
#1724 6 years ago
YouTube link coming shortly to show custom videos actually playing on the LCD screen! I've created a few classic replacements which fit the Legends theme beautifully.
The video files are 320x240 at 20fps. The trick is getting the 20fps as Premiere doesn't support that format, so you have to get creative and export at either 15 or 24 as a JPG sequence, manually delete or copy some of the frames, then import the sequence into After Effects. After Effects actually does allow export at 20FPS into the final video file, which is great because I've built 3D logos and text to overlay on some retro VHS video clips.
This is really exciting and I can't thank oga83 enough for both allowing me to assist and test the software, and having developed a tool that gives us the ability to import our own content! The possibilities are endless for a game like WrestleMania, especially those of us with the LE and a love of classic pro wrestling!
#1725 6 years ago
Quoted from TheKreator:
I can't wait to see the videos !
Pinball Browser can convert the resolution but not the fps. You can import any video format supported by 'ffmpeg'. The result is better when the resolution is a multiple of 320x240 (like 740x480).
I tried to keep it easy to use : Just open the .spk file, import new videos and use the .spk file to upgrade your pinball machine.
Replacing videos is even easier than modifying sounds on Sam games
Thank you for the tests you are doing !
As I don't have access to a Spike machine, it's not easy to adjust Pinball Browser.
#1726 6 years ago
Here's a quick video showing the two new animations to replace the spinning WWE logo and WrestleMania logo in the attract mode! I have also created a retro Royal Rumble animation. Both WrestleMania and RoyalRumble are 1991-style!
#1727 6 years ago
You mean new Videos for the WWE TFT ?!?
i thought you find a way to display real Videos at the smartdmd
#1728 6 years ago
This is fantastic TheKreator!!! Well done.
#1729 6 years ago
Quoted from kapsreiter:
It's on its way but I've been distracted by Spike
#1730 6 years ago
So Pinball browser will also be able to change out songs on the spike system too?
#1731 6 years ago
Quoted from oga83:
New 3D ultra HD dots
#1732 6 years ago
Quoted from Asylum:
Yes
#1733 6 years ago
i want to colorize a WPC game
#1734 6 years ago
Quoted from thewool:
Regarding sounds... I thought the sounds for all DE, Sega, and Whitestar games were all left in an unencrypted file format that you can import directly to a program like audacity (.wav) to view and modify those sounds. (Little Endian, PCM format 8000 hz.) If this is correct with Whitestar, why can't you just modify the callout sounds on the EPROMs to the ones that you want to play?
I just confirmed that this works by importing the TSPP U17 ROM into Audacity, and adjusting the playback slider to a X0.18 speed. Works fine. U21, U36, U37 contain the rest of the audio. There are some cool snippets in there that was never used, for sure.
Some cool stuff here I'm working on fitting in with a trial run... http://www.lardlad.com/sounds.shtml
and here: http://www.thesoundarchive.com/simpsons.asp
#1735 6 years ago
It looks like this is getting flagged as a virus again by google and can't be downloaded...
#1736 6 years ago
Quoted from jrobinso99:
You can download it, this is only a warning.
www.VirusTotal.com checks 57 virus databases and only finds 1 false positive ("Cyren").
I guess that's why Google Drive displays a warning but, unfortunately, there is nothing I can do about this.
[EDIT] I have filed a false positive report but I'm not sure they'll take it into acount
// Error: Image 418685 not found //
#1737 6 years ago
Hi Oga,
It cannot be downloaded anymore. This is what I get:
Sorry, this file is infected with a virus
Only the owner is allowed to download infected files.
Grtz. Ronald
#1738 6 years ago
It works fine here, just downloaded 4.42.
#1739 6 years ago
My false positive report has just been taken into account.
Virustotal.com (Google subsidiary) is now all green
Google Drive is working fine.
#1740 6 years ago
Works here too ! Thanks !
#1741 6 years ago
Someone reported to me that it is not possible to modify the "ABC" high scores on MTL with Pinball Browser.
The reason is that all these high scores point to the same unique "ABC" string into the firmware.
Thus, modifying the string for one high score impacts all the other ones that use the same string.
Unfortunately, there is nothing I can do about it.
The best method to backup/restore your high scores is to use the Backup/Restore functions in the "High Score" tab.
For more details, see the "Communication with your pinball" section in the original post.
#1742 6 years ago
I have a Met and I spent hours modifying the call outs using PBB, now Stern releases a code update. Is there a way to transfer all my changes over to the new code?
#1743 6 years ago
Quoted from ita47:
You can adjust your macro by hand (modify the callouts ids) or you can use the "ShiftId" :
https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/34#post-2330619
#1744 6 years ago
I noticed some sounds mute the background music on The Walking Dead and some play on top of it. Is there a flag that can be set per sound or somewhere so it stops muting the music and just plays sounds on top?
#1745 6 years ago
Can someone let me know the script number in 1.64 for the ramp "justice for all" music? Seems to be missing on my pinbrowser modification. Thanks
#1746 6 years ago
Has anyone else noticed the High Scores section doesn't work on Metallica 1.64? i am running version 4.13 of pinball browser.
#1747 6 years ago
Great product. Good news about spike. Kiss could use some song adjustment!
#1748 6 years ago
Quoted from gabegabegabe:
Do you mean this ?
#1749 6 years ago
Quick question....using Pinball Browser v4.42 for the first time. Running on a Mac OS X 10.10.4 via Crossover for Mac. No issues getting Pinball Browser up & running. Able to play different sound requests. Trying to swap out some songs on the MET v1.64 code. However when I try to import a song (24kHz-wav or MP3s) I'm getting this message.....
"This version of Pinball Browser does not have the Sound Edit features & it can only import 24kHz-Wav files! (If your file is a 24kHz-Wav, it will be imported with this version) Click on license in the main window for more informations."
When I click on Enter License button, all I see is an empty box for the License Key. So do I need a key to use Pinball Browser, and if so, how do I get one?
If not, I'm doing something wrong.
