Quoted from oga83:Thanks. Do you know the version of your Sam prom ?
It's version 3.1
It's version 3.1
Quoted from goalzzz:It's version 3.1
Ok, that's normal : this version is game independant but does not check the crc
My AC/DC has a v1.0 prom that seems more recent (but game specific, I assume) : it checks the crc
Okay, thanks. Doesn't really bother me. Have to redo a few settings, and my "brilliant" highscores are gone, but it's just fantastic being able to mod the machine. And I'm probably done for the moment, changed every piece of music on my Tron, so I'm happy now.
Quoted from goalzzz:Have to redo a few settings, and my "brilliant" highscores are gone
There might be some good news about this in the next coming days...
Quoted from goalzzz:changed every piece of music on my Tron, so I'm happy now.
Don't forget to use macros to record all your changes
Quoted from oga83:Can anyone confirm that, on the following games, there is no "Update failed - Error code 8" at the end of the firmware update (with a patched firmware of course) ?
- FG
- POTC
- WOF
- SHREK
- CSI
- 24H
- SPIDER-MAN
For all other games, the update process should end with this error.
Thanks in advance.
I can confirm there was no error on POTC. I had updated it with an 3.1 version EPROM recently, so that's what version of the EPROM I have.
Quoted from oga83:There might be some good news about this in the next coming days...
That would be a killer feature! Could be used even for 'no mod' code upgrades...
1) Backup on stick
2) Export settings and scores macro
3) apply macro to new code
4) update version
Mhh..... This implies that these settings get saved in the backup, which I did not know about. If so, what has Stern waited for all this long to provide a similar tool. Does nobody care about keeping scores?
Quoted from astaroth:That would be a killer feature! Could be used even for 'no mod' code upgrades...
1) Backup on stick
4) update version
What I'm currently testing is a version of Pinball Browser that is connected to the pinball : you just have to modify an adjustment in Pinball Browser and that's it, it's immediately into the pin No stick, reset or upgrade needed...
It should also work for high scores but I'm still working on it.
As an example, I'm using this macro to reconfigure all my adjustments (language, volumes, free play, radio mode, ...) in a single operation :
-- Pinball-Browser Macro for AC/DC v1.65
CheckVersion,"AC/DC",0x165
Adjustment,0x3C,CurrentValue,1,,
Adjustment,0x22,CurrentValue,1,,
Adjustment,0x7,CurrentValue,0,,
Adjustment,0x3,CurrentValue,1,,
Adjustment,0xAC,CurrentValue,2,,
Adjustment,0xBA,CurrentValue,1,,
Adjustment,0xBB,CurrentValue,0,,
Adjustment,0xBC,CurrentValue,-5,,
If anyone is interested in testing this new feature, please PM me. You just need a cable like this one http://www.amazon.com/StarTech-com-Modem-Serial-Adapter-ICUSB232FTN/dp/B008634VJY/ref=sr_1_9
and a Pinball-Browser-compatible pin (that is not AC/DC because it's already being tested on this one).
Quoted from pinball-fan2002:Hi there,
I tried the tool (by the way - it's awesome) with the Pirates of the Caribbean potc0600as.bin and did found the sound samples and game musics from the game.
But there is no voice. Where are the voices, like the pirates you have to fight or the girl which says that you are
the worst pirate I have ever seen and so on?
Thanks for helping.
+1, What is the answer to this? I was fussing with the music and have been updating it, but I didn't find voice clips either.
Quoted from oga83:If anyone is interested in testing this new feature, please PM me. You just need a cable like this one amazon.com link »
I have this or other brand serial-usb cable. Just hope it's null modem. Why has has the usb type be only crosswired and not interchangable, i don't know. Anyway... When i finally get my STLE delivered I will test it. Male port on SAM?
- FG
- POTC
- WOF
- SHREK
- CSI
- 24H
- SPIDER-MAN
Thanks in advance.
So when I attempted to patch my Met pro tonight with modified version 1.22, the code 8 error is normal and was supposed to happen and the game would have been playable?
Quoted from DeathHimself:So when I attempted to patch my Met pro tonight with modified version 1.22, the code 8 error is normal and was supposed to happen and the game would have been playable?
Yes, it's explained in the OP :
When you flash the patched firmware, do not verify the image; The upgrade process will end with a message saying that there was a problem ("Update Failed - Error code 8"). This is normal and it works.
- FG
- POTC
- WOF
- SHREK
- CSI
- 24H
- SPIDER-MAN
Thanks in advance.
Spider-Man has no "update failed - error code 8" although i have not tried your latest Pinball Browser Versions.
Ed Z
Quoted from ezeltmann:Spider-Man has no "update failed - error code 8" although i have not tried your latest Pinball Browser Versions.
Ed Z
It does not depend on Pinball Browser; it's only because of the prom version.
Quoted from oga83:What I'm currently testing is a version of Pinball Browser that is connected to the pinball : you just have to modify an adjustment in Pinball Browser and that's it, it's immediately into the pin
It works with adjustments :
And also for high scores :
Quoted from oga83:Yes, it's explained in the OP :
Yep, did it again this morning and it worked like a charm including custom songs/images. I liked it even retained the current high scores. Awesome stuff, thanks!
I don't want to break any rules here... But is there a place that macros are being shared? I'm looking to test out Ac/DC, Tron LE, and metallica LE.
Bsl
I started a separate thread regarding my work on POTC music, but it's not getting much activity, so I'll just link it here and then post any other info in this thread since it is the biggest thread on the topic.
Post:
Short video:
"AC/DC, Avatar, Tron... : Play and modify dot matrix images or sounds"
The name of this thread was set at the very beginning of Pinball Browser.
It is no longer specific to AC/DC, Avatar and Tron, and I think that this subject is too restrictive.
Any idea for a better name ?
Quoted from oga83:The name of this thread was set at the very beginning of Pinball Browser.
Pinball Browser for Stern S.A.M system games: Browse & modify DMD images & sounds
v3.10 can be downloaded (see OP for download link and change log)
IMO, it's a major improvement : Pinball-Browser can now be connected to your pinball with a RS232 cable.
It opens a new field of possibilities...
This version allows you to modify your adjustments and your high scores in a jiffy : just click on 'set', and that's it, your modifications are immediately stored into your pinball
I have also modified many explanations in the OP.
Let me know what you think of this version !
Quoted from oga83:v3.10 can be downloaded (see OP for download link and change log)
First, quick question before even trying the new version. What is the comm103.hex file and where does it need to be? It seems that more and more files are being added to the zip and I never know if they need to stay in a folder with the exe or if they are just support files for a specific purpose of pinball browser?
I was also wondering if hooking pinball browser directly to a game is required to use the new "High Score" tab? Can high scores be modified in the ROM before flashing to a game via USB?
Quoted from DugFreez:First, quick question before even trying the new version. What is the comm103.hex file and where does it need to be? It seems that more and more files are being added to the zip and I never know if they need to stay in a folder with the exe or if they are just support files for a specific purpose of pinball browser?
I have added a description of each file in the OP, just after the download link
Comm103.hex is a patch for the pinball, to enable communication with Pinball Browser.
If you don't plan to use this feature (adjustments and high scores real time modifications), you can delete it.
Quoted from oga83:Pinball-Browser can now be connected to your pinball with a RS232 cable.
Simply amazing!!!
Why didn't Stern provide this? It's so much easier to do all these setting from my PC, especially since all settings are erased when upgrading the SW. Not to mention the High Scores...
This sounds really cool! would it be possible to use some sort of wireless connection, so you wouldn't have to remove the BG to connect? It would be really cool to be able to use your laptop or tablet to connect to any game and modify it's settings on the fly. Dreaming, I know.
Either way, simply awesome job oga83!
Quoted from gabegabegabe:This sounds really cool! would it be possible to use some sort of wireless connection, so you wouldn't have to remove the BG to connect? It would be really cool to be able to use your laptop or tablet to connect to any game and modify it's settings on the fly. Dreaming, I know.
My serial cable is passing through one of the existing holes at the rear of the pinball : I can connect my laptop without removing the BG. But I agree, having a wireless connection would be better.
Quoted from gabegabegabe:would it be possible to use some sort of wireless connection, so you wouldn't have to remove the BG to connect? It would be really cool to be able to use your laptop or tablet to connect to any game and modify it's settings on the fly. Dreaming, I know.
This looks like a nice solution:
http://www.benl.ebay.be/itm/MODULE-CONVERTISSEUR-RS232-VERS-WIFI-SERIAL-TO-WIFI-ETHERNET-HLK-RM04-/321270436344?pt=FR_YO_MaisonJardin_Bricolage_ElectroniqueComposants&hash=item4acd35d1f8&_uhb=1
Haven't tried it myself, but it should work...
well you need to hack the game code to add drivers for usb WIFI and hope that the system has the cpu power / ram to run it.
v3.11 is a small fix for high scores (only needed if you use a serial cable connected to your pin)
See OP for download link.
If anyone wants to try some alternative songs on their Tron machines, let me know and I'll PM you a download link. You won't here me say they're better than the original ones, but if you'd like to experiment a bit...
All songs are exactly the same length as the originals, most are snippets taken from the Reconfigured album. I only left the Gem and SoS songs in there, because I like those.
Many thanks to Tatanka1961 who did a lot of tests on intermediate versions of Pinball Browser .
The "Adjustment and Highscore real-time modification feature" is now confirmed to work fine on STLE141 with Pinball Browser v3.12.
Very late to the party but Just started to monkey around with my Tron. It always irritated me that the Splash screen of "Tron Legacy" had the city garbage under and in the word legacy. After a few hours of getting rid of the extra pixels from each frame I now have a good looking splash screen graphic. Thank you to the creator of this amazing program.
Anyone that has played wih MET code in PBbrowser, please see my question here about trying to find where he Sparky Multiball music is populated:
https://pinside.com/pinball/forum/topic/pinball-browser-metallica-code
Thanx for this awsome tool.
What I really would like to see is a possibility to edit the switch matrix.
This would be amazing. Maybe in one of the upcoming versions ?
I know there's always talk about the newer games working (USB supported games)....without scrolling through 21 pages, can anyone tell me if older Stern games work (specifically RCT)? I have been successful in changing my Ironman and working on Tron and Avatar, but was wondering about the older RCT? Can the new image be burned on a chip and swapped out?
Quoted from Max_Badazz:I know there's always talk about the newer games working (USB supported games)....without scrolling through 21 pages, can anyone tell me if older Stern games work (specifically RCT)? I have been successful in changing my Ironman and working on Tron and Avatar, but was wondering about the older RCT? Can the new image be burned on a chip and swapped out?
No, it won't work with RCT :
Pinball-Browser only works with S.A.M. system games
Quoted from Dipsy:Thanx for this awsome tool.
For what purpose ?
Anyone else is interested ?
This tool was awesome was able to get it working on STLE code 1.41 and change up the sounds... Keep up the great work!!!!
Personally, I'm a bit afraid of live modification. I like the comfort of making edits on my computer with the knowledge that I can flush my changes at any time with no impact to the pinball machine. I think this capability is looking for a "killer" reason.
Quoted from oga83:For what purpose ?
They are probably wanting to modify the switch matrix to be able to install the LE software on a Pro machine. I still don't think it will work.
Currently I run the Avengers firmware on my Spiderman
I can fight Thor, Hawkeye, and Captain America. Ironman, Hulk
and Black Widdow are missing because there are a lot of switches
at the Spiderman playfied that are not used at Avengers and vice versa.
If I would be able to reorganize the switch matrix, this would be much more
fun
Quoted from oga83:Has anybody tested the new "live modification" feature ?
Got my STLE at latst. As soon as I can figure out where my cable is I will text it out.
Quoted from nosro:Personally, I'm a bit afraid of live modification. I like the comfort of making edits on my computer with the knowledge that I can flush my changes at any time with no impact to the pinball machine. I think this capability is looking for a "killer" reason.
Firmware modifications and live modifications are 2 different feature of Pinball-Browser :
1- Firmware modifications : you can modify a firmware on your PC to change static settings only (songs, images, default adjustments, ...)
2- Live modifications : you can read/write your current adjustments and high scores. In particular, you can backup your current configuration and restore it later. For example, when you upgrade to a newer version, all your high scores are lost; with this feature, you can set them back
This page was printed from https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/21 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
