Just to add more details to my earlier post.
The canon only loads when it is supposed to load. How do I know this? Well the yellow light on the playfield signifying the canon mode is lit and I just started noticing that the red light above and to the right of the canon is also lit when it loads. After the canon loads the fire switch is always lit up, The DMD gives instructions on what to shoot at , Steve Richie (SR) also chimes in to fire the canon.
Then the canon swings out to about the switch 62 position and automatically fires. About the same time SR is shouting fire or Come On x 4. After the canon autofires, it finishes its path out and back to the starting position. Once it has returned SR screams "Next time use the fire button stupid!" or "You Lose(might be "snooze" it is hard to tell) You Lose."
My understanding of how the canon is supposed to work is that the canon will swing out and back for you to fire the ball. If you do not fire the ball it will swing out again and autofire the ball at which time it tells you to use the fire button next time.
Based on the symptoms displayed by my machine I believe that for some reason it is skipping the first swing out and back. Something is making the machine think it has already made the first out and back pass so it is going right to the second swing autofire mode.
I have spoken with the CS at Stern and while they have said they will work with me on this the person I spoke to didn't have any ideas on how to fix it.
Any help is appreciated.
JtL
