New! Dark mode!
(Topic ID: 272135)
AC/DC will not turn on!
By pokerag2
4 months ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 3 months ago by Gunnut40
    #1 4 months ago
    My AC/DC premium vault just started not turning on. Once the switch is turned on the backbox fluorescent tube comes on (the one that lights up the translite) and the LEDs behind the rectangular plastic on the right side of the game about 2/3 of the way toward the back come on. That is it. This seems intermittent as this happens about 50% of the time. It just started Saturday. Sometimes the game will boot up like nothing is wrong. I checked all the fuses and they are fine. Any thoughts? Thanks
    #2 4 months ago
    Free bump and it may be helpful to provide what boardset this game uses; e.g. Spike, SAM or ?
    I heard they used both depending on the run (e.g. original vs reruns vs. vault); I am assuming this is a Spike game based on the description, but if you are asking for help try not to make people assume
    #3 4 months ago
    Quoted from BC_Gambit:
    All ACDC machines are SAM even the vault. I'd check all your backbox connectors and make sure that nothing is coming loose.
    #4 4 months ago
    Quoted from MikeS:
    Ditto what he said.
    #5 4 months ago
    Cool; I remember some ACDC's being seen with possibly Proto Spike boards years ago; I had ASSumed if they did that reissues would be spike
    #6 4 months ago
    It's a SAM operating system. I was unaware there might be 2 OS for this game. I'll check the connections. I have not done that. Thanks.
    #7 4 months ago
    Also post a picture of the driver board with the coin door closed. For every fuse, there should be a lit LED beside each one. I suspect a blown fuse.
    #8 4 months ago
    Ok, the connectors all seemed to be plugged in.
    I checked the LEDs on the fuses and F1-F4 LEDs are not coming on. All other fuse LEDs are coming on. Also there are indicator LEDs for the 50V, 20V, 12V and 5V. The 50, 20 and 12 are coming on but the 5V just goes on and off in unison with the LEDs under the one rectangular flame playfield plastic.
    #9 4 months ago
    Time to test the fuses for the voltages that are not lit. Again, make sure the coin door is closed. An open door will disable the 50v coil and 20 flasher voltages.
    For the 5v, I think you need to measure that voltage with a meter. Sounds like the 5 volts is low.
    #10 4 months ago
    Ok figured it out. Pinched a wire in the lockdown bar clamps. Weird but the LEDs adjacent to the F1-F4 still do not light???
    #11 4 months ago
    Well, do the fuses test good?
    #12 3 months ago
    I need to buy another voltmeter. So I'll check them after I do that. Thanks.
    #13 3 months ago
    Quoted from PinballManiac40:
    I have not seen a comment whether you have the coin door closed or open. If it is open, this will explain why they are off. If it is closed, will be looking for a 2nd problem.
    #14 3 months ago
    If it does not power on try flicking(like thumping someone ear) the large caps on your power board. I just did this on my CSI and it starting working.
    $ 26.50
    $ 19.00
    Chrome Candy
    Top-Notch Target Shields
    Cabinet Parts
    Ramp-O-Matic
    $ 84.95
    $ 12.00
    Meph's Mods
    $ 62.00
    The MOD Couple
    $ 38.99
    Lee's Parts
    £ 39.00
    PinballToys
    $ 99.99
    $ 209.99
    $ 159.99
    $ 29.50
    $ 7,599.00
    Classic Game Rooms
    $ 89.99
    $ 5.00
    Doc's Pinball Shop
    $ 99.00
    $ 48.00
    $ 95.00
    M&M Mods
    $ 100.00
    G-Money Mods
    $ 5,999.00
    Classic Game Rooms
    Back Alley Creations
    $ 189.99
