I have a Luci edition that has an issue. The right top rollover LED works fine in test mode but not in gameplay. What can it be? Changed LED and Driver board.
I don't recall on that connector but can you install it 1 tooth off? If so, give that a try and see if the issue moves to a new insert or if it stays with the current insert. If it stays with the current one then you know it's something with that Light or wiring going to it. If it moves to another light then you know the issues is either the connector or something on the board still.
That's how I found the issue with a switch issue on my MET after trying everything so it may help here as well but that is just a shot in the dark.
I don't really want to install plug in wrong. Board cost $135+. Don't need to buy another. Any other ideas?
Does anybody else have any ideas what could be causing this? Remember, RGB work fine in test mode, just not in game play mode.
This page was printed from https://pinside.com/pinball/forum/topic/ac-dc-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
