I just got a BIBLE several days ago. Great game, but I'm having a fairly annoying issue with the 5 bank AC/DC standups.
I put about a dozen games on it and realized when the cannon loads, the 5-bank doesn't pop up to allow a shot at the lightning bolt center drop target, for example. Sure enough, the next time I powered it on I got a service warning about that switch.
I manually hit all drops in test mode and the (A) and Bolt drops would never show as closed. When I placed the playfield in service mode, not all the way up, they would all register fine...getting interesting.
I powered down, removed the two opto boards from the bank (there's a 3 opto board and a 2 opto board), cleaned the optos, cleaned the interrupters on the drops, put everything back together, powered on and retested.
This time I noticed if I wiggled the wires on the opto board plugs I could get one of the switches to register as not closed even though the target was dropped, interrupting the opto. I could get this to happen on either board with the other unplugged, puzzling me. On the 3 opto board it was usually the Bolt switch and on the 2 opto board it was the C switch.
I inspected the wires and how well they were seated in each plug, they look/feel fine. I did notice both plugs fit kind of loosely, particularly the 3 opto board plug.
It doesn't seem like a power/ground issue, as only 1 switch on each board is affected at a time. Both boards share the same strobe wire (green/brn). The 2 opto board is the end of line for that strobe wire, it's daisy chained from the 3 opto plug.
What should I do next? I'm stuck.
Jerimy
