(Topic ID: 231386)
Abra-Ca-Dabra - Strange issue!
By ibis
1 year ago
  • 29 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by ibis
#1 1 year ago
So this game came to me non-working and it was pretty busted up. Its been completely shopped and all switches have been inspected/gaped/cleaned. Score reels have also been disassembled and cleaned. Once I had the game all put back together I did an initial start-up to work out any other closed contacts, bugs, or issues. First I added some credits manually as the coin mechs do not work. Then I plugged it in and I push the start button. Heres where it gets wonky....the game accepts the credit-boots-goes dark.... then takes another credit-boots, goes dark and....continues to do this until there are no more credits.
Ive never seen this before. If anyone has seen this symptom before, any help on where to inspect first would be greatly appreciated.
#2 1 year ago
when you say ot goes dark, you arent talking about a tilt , maybe with a tilt lite that isnt working?
By the way ,Merry Christmas and Happy Channukka [sic} my friend and to all here.
#3 1 year ago
There could be a too closely gapped tilt switch. When the drop targets re-set there is that louder 'Cha-Chunk'. That re-setting could be triggering the one tilt switches that put the game into tilt.
#4 1 year ago
Hey Weeze! Happy Holidays to you too! I guess when I say it 'goes dark', the game just keeps resetting. Heres something even weirder....if the ball isn't in the trough, it will do it ONE time. If the ball is in the trough, it repeats the reseting over an over.
As for the tilts, they should all be open correct? In other words, not making contact? I have seen some making contact like on the coin door.
#5 1 year ago
Quoted from ibis:
Bridge rectifiers? You knew you had that coming. LOL
#6 1 year ago
Quoted from tktlwyr:
LOL yes I did!
#7 1 year ago
Quoted from Darcy:
I checked all the tilt switches. All are closed in the head, coin door, on the lower unit. Except for one on the play field which is open.
#8 1 year ago
How is the pendulum tilt and the ball roll switch? They should be open.
#9 1 year ago
Quoted from D-Gottlieb:
There is no pendulum, its missing. The ball roll tilt has no ball, Ill inspect if the actual switch is open or closed and report back tomorrow.
#10 1 year ago
When you reset the game, the Hold (R) relay should activate and stay on. Is it doing that?
#11 1 year ago
Conventional tilt switches are normally open; slam-tilt switches are normally closed. Relay R stays on through slam-tilt switches. You *do* have a schematic, don't you?
.................David Marston
#12 1 year ago
The hold relay R is NOT staying on.
All slam tilt switches are now closed(the one on the PF was not closed, it is now)
Roll ball tilt switch is open(not a slam tilt switch so I assume it is an open switch)
And yes I do have a schematic.
#13 1 year ago
Quoted from ibis:
Playfield one should be open, coin door, motor board and backbox closed.
#14 1 year ago
Ok, I gapped the slam tilt open on the PF and double checked that the motor board and backbox and coin door switches are closed. The roll ball tilt is also open. No change in the symptoms.
If this symptom is indicative of a tilt issue, should I just take all the tilts out of the equation? Ive never had this symptom before so I have little to add to the troubleshooting being discussed here.
#15 1 year ago
That certainly would determine if it is indeed a tilt circuit issue.
#16 1 year ago
Quoted from ibis:
Here's the circuit that should make the Hold (R) relay stay on.
#17 1 year ago
Howard, thanks for highlighting the circuit in question. I will take this and hunt this down in a few days, Im leaving on business tomorrow morning. I will be certain to report back as soon as I can! Thanks guys!
#18 1 year ago
Ok, I have an update.
I attached a clip on the slate/green side of coil R. If I follow the schematic, there is:
- continuity from there to both of the closed back box switches
- continuity to blue/white/red on the "T" lug
- continuity to the blue/white/red on the "R" lug
- continuity to the other side of "R" on the blue/white/red
- continuity to the closed motor board tilt switch
- continuity to the red/white coin door switch
- continuity to the red/yellow 15amp fuse
So, the R relay switch is showing continuity on the meter but according to the schematic its an open switch. So does this mean there is a short? All the lugs appear to have space between them.
#20 1 year ago
The schematic is showing the status of relays after resetting a game and pulling the plug. Are you checking continuity with the machine on? Is the relay adjusted?
#21 1 year ago
I am using alligator clips, one on my meter, the other on the point of contact.
The game is off when I am testing for continuity. Should I have the game on??
#22 1 year ago
Quoted from ibis:
No, you are doing it correctly.
#23 1 year ago
So is it safe to say I have a short some where? There should be no continuity after the "R" switch on the schematic, correct?
#24 1 year ago
According to the schematic and what you are reporting, it appears that contacts of the R relay are closed when they should be open. Pull the small cotter pin on the relay, remove and examine it. If good, then check the wiring for a pinch or old repair.
#25 1 year ago
Quoted from ibis:
How many ohms are you seeing across the switch on the R relay? There are multiple paths that could provide continuity across that switch. Here is one of them.
#26 1 year ago
The "R" coil is reading 24.9 oHms
I must have done something cause I have nothing but backbox lights now and a hum on the motor board. Cant get it to cycle like it was doing earlier.
#27 1 year ago
But the coil on the coin door does activate when turned on.
#28 1 year ago
Quoted from HowardR:
Quoted from ibis:
That's not what I asked you.
Quoted from ibis:
If the Replay Button doesn't activate the Start (S) relay, inspect and diagnose this circuit with Alligator clip jumper wires.
#29 1 year ago
Hi Howard, I tested the switch on "R" and it read a little over 25oHms.
Ill have to digest that next circuit you posted, I know where some of those items are, but not all of them. Ill report back when I can, got a lot of stuff going on the next few days due to the Holidays!
Apparel - Unisex
Pinball Wheezer
$ 54.99
$ 4.49
$ 8.00
Cabinet Parts
$ 12.99
Medisinyl Mods
$ 79.95
$ 229.99
$ 40.00
Arcade Arts
Music City Pinball
$ 54.00
$ 154.00
Id Rather Play Pinball
$ 53.00
$ 89.99
$ 10.95
$ 9.99
$ 235.00
RS Technologies
$ 76.95
$ 28.75
The MOD Couple
