The 1 2 3 4 rollovers score correctly but when the switch is engaged there is an audible zzzzt sound coming from the 1 2 3 4 relay bank. Happens anytime you engage the switch--lit or unlit. If I hold down a rollover, it stays buzzing. Screws on the bottom of all the coils appear tight...in case it was a loose coil. Whole relay bank buzzes no matter which rollover you press...seems like whole bank vibrates. Doesn't appear that any of the armature plates are out of wack. Can't seem to pin down any specific area on the relay bank that the sound comes from...
Normal?
