Lots of misinformation in this thread so I just checked my ACD 10,000 reel...
There are only two switches on the reel:
1) A runout switch that is closed only in positions 1 to 9
2) A reset switch that is closed only in position 0
There is no EOS switch on the "Ten Thousands" unit.
This is what the switches look like in the 0 position:
The picture below shows the switch state for positions 9. Note that in positions 1 to 8 the switches are in the same state just not pushed over as far as in position 9:
Here's the relevant section of the ACD schematic and I just noticed there is an error! As originally drawn, both the 1,000 and 10,000 unit coils will operate together whenever the L (1000 point) relay operates. There's a switch missing from the schematic and so I have added one (marked in red) that should be labelled "9th Position 1,000's Unit". The 10,000 coil then only gets a pulse from L when the 1,000 unit is in the 9th position. There is no EOS switch on the 10,000 coil as the EOS on the 1,000 coil cuts power to the L relay.
Hope that helps
