(Topic ID: 27253)
A very WMS mistake on MB Frankenstein assembly : 02-5443 HELP NAMING PART :)
By Guerrefroide
9 years ago
  • 25 posts
  • 12 Pinsiders participating
  • Latest reply 8 years ago by jtaudio
#1 9 years ago
Hello Guy,
I pray God that someone could help me.
I had a broken piece on my MB pinball, it's a little steel part for the Monster Bash Frank mech assembly.
Problem is, inside the manual :
On the manual, the part is called : 02-5443
But on marcospecialties, or others, I ordered this part ( I was thinking maybe it was a generic image and I woudl receive the good one).
It's a rectangular thing, not a cylindric piece.
Even a danish guy asked about this, or I think he had, if someone could read danish.. ?
http://www.svenskaflippersallskapet.com/forum.php?action=showt&t=10109&p=0
Any help for having the good part of MB ? ?
Thanks a lot in advance for everything..the MB without the Frank is.. useless!
[URL=http://www.uplood.fr/visu.php?url=http://img2.uplood.fr/free/h0c3_02-5443.jpg][IMG]http://img2.uplood.fr/free/h0c3_02-5443.jpg[/IMG][/URL] 02-5443.JPG A.jpg B.jpg
#2 9 years ago
Just in case.. the part below in the picture is the good one, but it's shorter because it's broken. I am looking for this part below..
thanks!
Mathieu
#3 9 years ago
nobody ?
#4 9 years ago
I can't help - slight bump yes - a website that always finds me the really odd stuff why I can do that as well http://www.pbresource.com
#5 9 years ago
how the hell did that snap off? If you know someone who can weld, you should be able to fix or fabricate that piece to be like new again.
#6 9 years ago
Can't help directly, but I would contact pinballlife, marco and bay area and see if one of them can help.
6 months later
#7 9 years ago
Got my part from Marco today - same problem.
Did you successfully resolve the issue?
It looks like you may be able turn the square cross sectioned part to make it round (apart from where it's meant to be square for the rotating cluster).
What do you think?
Cheers!
Goz
#8 9 years ago
A machinist can easily alter the square part to cut it to length and make it round.
#10 9 years ago
Wrong part. This is the other shaft without the square cross sectioned part.
But I bought a 02-5443 from PSP in Australia - waiting for it to arrive....
Cheers!
Goz
2 months later
#11 8 years ago
Hello,
i'm searching for the same part for my CC (for the mine, it's the same hardware) and same pb than Gozzle, after PM him I just would like to advise you that for the CC it's also the round part...
Now I've got a rectangular one to sell
I just have to order the round one in Australia now...
#12 8 years ago
Just to let you know, I received the correct part from PSP in Australia and fitted it in. Perfect.
The square shaft can't be turned to make the rounded shaft, as the necessary square cross-sectioned area (for the non-slip cog) is too small.
Finally in fairness to Marco, they refunded me the part - no further questions asked.
Cheers!
Goz
#13 8 years ago
so what part number is it
#14 8 years ago
02-5443 = the drive shaft
#15 8 years ago
well the williams print for 02-5443 is not that part
so we still have no idea what it is.
PSP might sell it as 02-5443 but thats not what it is
#16 8 years ago
I don't understand your input. What's the "Williams print"?
The drawing included in this thread shows the part number of the drive shaft as 02-5443, and is the same part which PSP supplies.
#17 8 years ago
a Williams print is the original drawing of the part designed by Williams Engineers
The original drawing with that part number looks like this
http://www.planetarypinball.com/mm5/merchant.mvc?Store_Code=PP&Screen=PROD&Product_Code=PPS-02-5443
#18 8 years ago
Mmmm...Danish....
#19 8 years ago
Gozzle, Nobrain, and Guerrefroide are correct. The shaft 02-5443, as shown here:
or
http://mrpinballa.cart.net.au/details/713433.html
will not fit into the gear assembly on CC and MB.
The correct part is shown here at PSPA.
http://www.pinball.co/Products/3272-02-5443.aspx
Wally
#20 8 years ago
Quoted from Ballypinball:
Then the "Williams print" is wrong. There's no way that shaft could work in a gearing environment.
In fact, if you look at the drawings above, the part is correctly marked and correctly drawn and isn't square on its entire length as with the shaft in your posted link.
Cheers!
Goz
PS as this gearing is duplicated in the Monstaer bash, a quick look at the working gearing also confirms the obvious.
#21 8 years ago
It is called a "shaft drive" or "drive shaft" not sure why part number is not enough?
in stock at planetary
best of luck
slow today Unsure what the real part number is but link above is available. marco has the wrong part in stock.
#22 8 years ago
people are saying that part is wrong
#23 8 years ago
Hello,
I just get 2 off this parts :
http://www.pinball.co/Products/3272-02-5443.aspx == the good one for CC
http://www.bestofpinball.de/catalog/product_info.php/products_id/4465 == not the good one (they admit it and make me a refund)
Now my CC can work correctly... finally when I get back my plate
#24 8 years ago
Quoted from Shoot_Again:
best of luck
No, no, no. This is a picture of the wrong part. It is completely square in cross section and therefore CAN NOT work.
Honestly!
Goz
#25 8 years ago
Shaft from MM is the correct one for MB that is incorrectly listed in the manual. This is it:
http://www.marcospecialties.com/pinball-parts/04-10988.1
$ 9.95
