Undertale: Pinball Edition - Nearly Ready for MGC
(Topic ID: 213534)
By KellyCorcoran
12 months ago
  • 91 posts
  • 29 Pinsiders participating
  • Latest reply 14 hours ago by atrainn
  • Topic is favorited by 25 Pinsiders
    There have been 61 images uploaded to this topic. (View topic image gallery).
    There are 91 posts in this topic. You are on page 2 of 2.
    #51 4 months ago
    This is amazing - my son lost his mind when he heard the music in the other room, wondering, "Why are you listening to Underta... OH MY GOD ARE YOU BUYING THAT RIGHT NOW?"
    Definitely interested in heading up to MWGC 2019!
    #52 4 months ago
    Quoted from mystman12:
    I'm curious, why would you say designing the game in Future Pinball was a mistake? Do the measurements of objects in FP not translate to real life properly, or was it because FP allows you to leave out elements that with be crucial IRL? I've got some designs I made in FP that I think I'd enjoy building IRL if I ever find the time and resources, but I'm curious how much of a challenge that would be with them being FP blueprints.
    I can answer this - it's partly the first two, but also that the default FP physics are bobbins - there are too many elements that don't behave in a realistic way. I still use VP 9.9 as a design tool, with my own set of accurately-built custom objects, and custom physics routines in the script. It still isn't perfect of course - VP's physics timer runs on cycles that are long enough to eventually predict, and it doesn't allow for skips and air balls unless things go seriously haywire.
    At Heighway, when myself and SlamTilt would come up with intriguing ideas, or wanted to prove a concept, what would happen is one of us would build us something flippable in one engine, and the other would present it in the other engine - me in VP, him in FP with his own settings. Anything that after some tweaking flipped well in both versions, we could be pretty sure we had the best of both worlds and it ought to translate well to a potential whitewood. We built up a fair library of unused designs between us this way.
    #53 4 months ago
    Quoted from EalaDubhSidhe:
    You just hit the nail on the head right there. I still have an archive of old FP tables I designed years ago. Some of them have some nice ideas that I might reuse in the future, but the bulk of them would be either impossible to build, overly expensive to build in a way that works, or impossible to play properly because the layout depended on FP's wonky flipper physics.
    One of the biggest issues that I had was that FP's more realistic graphics and components give you a false sense of confidence that something can be built as designed. While the 3D features might have been nice to have for UT's design, I feel like VP gave me the advantage that I had to think more carefully about what I was designing and how everything was going to fit together.
    That said, I wish VP's saucer kickers behaved more realistically. The VUK in the upper left is so bloody impossible to hit that I am basically writing it out of the game rules. If I had thought to design that area differently (to soak up ball velocity instead of bouncing it straight back out), that would be different now.
    In other news, this project has been a very expensive electronics lesson about how not to avoid inductance loops and interference. Further software compensation to follow.
    #54 4 months ago
    Quoted from Gornkleschnitzer:
    They've got a new beta for 10.6 that's looking to grant your wish - they're adding a "playfield primitive" object that you can punch holes into with a 3d modeling program, and with some work on the kicker size/hit height, you can basically make a saucer that the ball can roll around and into/past.
    #55 4 months ago
    Quoted from LynnInDenver:
    Saucer-lipping has been part of my custom scripts on tables for years, as is drop targets sweep physics, magnets, impact-type captive ball brackets, vari-targets and spinning posts. That's the other advantage of VP over FP: the ability to read the velocity and position of every ball on the playfield in real time, and directly manipulate those values in the script to create realistic interactions with other objects.
    4 weeks later
    #56 3 months ago
    Well, I don't know what specific part of my wiring I messed up, but my controllers have been getting progressively less reliable due to what I strongly assume is electromagnetic interference.
    -The autoplunger sometimes pulses if you hit the flipper button too hard.
    -There were so many phantom switch closures that I had to modify the software to compensate.
    -PWMing the lamps to make them fade was making the game almost PLAY ITSELF by causing even more phantom switches.
    -An old controller crash bug has come back in spades, and controllers will stop responding after something as innocent as a random target hit, and won't come back until a power cycle.
    -Oh, and the knocker doesn't work. No idea why. Driver circuit is perfectly fine and tested.
    I realized a couple of weeks ago that it has gotten so bad that it's barely presentable. Have you noticed the lack of gameplay videos? I can barely keep it running long enough to record one.
    And thus, I have four and a half months to redesign the game's wiring, from scratch, to be more reliable in time for the Midwest Gaming Classic. This means pulling out all the electronics, chopping out most of the wire, and putting it back together like a real pinball machine is supposed to be.
    The first thing to go is this horrible backbox wiring. Let's see...
    -Bulbs are attached to the back wall, six inches away from the backglass. And they're only 5v instead of 6.3. You can barely tell the backglass is even lit.
    -Monitor is mounted to an irregularly shaped chunk of wood held in place with drywall screws. You have to remove the panel to reach the monitor's cable connections.
    -But you basically can't remove the panel, because the wires for the FIGHT and MERCY lights are soldered directly into the rest of the light circuit and are too short to effectively get the panel off. No connectors of course.
    -Plus the panel blocks too much light, so the fallen human children are only half lit up.
    -Wires for speakers and knocker are just weaved through the field of GI lights.
    Gutting the backbox was way too much fun.
    First order of business is to make a proper light panel, and a 1/2" sheet of plywood cut to 26x20 fit the bill. I took the basic method of marking holes - arrange GI bulb socket holes in Inkscape, print onto a few sheets of paper, tape them on, and drill through.
    It worked reasonably well, although I'll be adding a couple extra holes between the logo and ASGORE's head.
    Please excuse the monitor mounting holes, which somehow took me several tries to get right. Up next: sanding and painting gloss white, then mounting. Yes, I have already test mounted it and it's in the right place!
    Big electronics order arrives Monday, including -stranded- wire (not solid, which likes to break) in all the appropriate colors. Stay tuned!
    #57 3 months ago
    Was Napstablook in there, sneaking a quick go with the phantom switches?
    #58 3 months ago
    "oh....
    I just wanted to try the game once.....
    I didn't know....
    Oh.....
    I messed everything up.....
    sorry........"
    ~Napstablook
    I gotta hand it to you, that was a joke I didn't even think of!
    Last night I successfully built a prototype version of the brand new switch matrix. Super pleased with how well it worked. Going to look into building a lamp matrix next, then I can start properly rewiring this thing!
    #59 3 months ago
    Four months remain. Clock is ticking.
    Finished the new lamp panel, with all lamps installed including flashers. Yes, flashers have been added - most of the major characters have one. I will simply tie them in with the flashers on the playfield, plus a couple extra - now that I will have a few drivers to spare - for the characters that didn't have representation.
    When I wasn't getting my panel sorted out, I was working on the new circuit boards. I do have KiCad on my computer, but learning it - and getting PCBs printed - is going to have to wait until I'm not on a deadline. I bought two new breadboards and arranged them in the most sensible way I could. Picked up a solderless board as well so I could prototype them and hopefully not mess up the layouts this time. Indeed, I think it went well.
    The top two boards pictured are the solenoid driver boards from under the playfield, which will have a new home in the backbox as nature intended. Board 3 is the switch matrix controller. Off to the side is a 9V regulator (for the sound system) and the filter cap for the 18V lamp power. Still need to order a transformer for that! The last board is the lamp matrix controller, with an extra ULN2803A driver chip off to the left for direct driving the flashers.
    Tonight I got the computer mounted properly in the backbox. Contrast with the cabinet floor photo on page 1. Now THIS is how to mount the CPU! Plenty of space is left over for my playfield interface boards - and yes, there is clearance space to close the lamp panel without it hitting the power supply unit.
    Plugged in a 6V power brick to test backbox GI, and I am LOVING the brightness. Camera phone washed out the color a tad (and indeed the translite colors in general are not as bright and vivid when backlit, for some reason), but it's definitely more eye catching than the old lights.
    #60 3 months ago
    Demolition is WAY too much fun. Pulled the whole wiring "harness" - if you can even call it that - from the cabinet. This looks like the wiring on a homemade pinball machine. This is not how I want it to look!
    Cabinet is basically empty now except a bit of extra wiring and the fixtures that will stay. I finally cut the hole for the subwoofer, which ought to improve the game's bass response even further. Since taking this cabinet photo, I reinstalled the speaker with grille, and added in the ever-present duplex outlet that will provide power to the computer and (switched) playfield. Bonus will be that I can unplug either one and use it as a service outlet when needed.
    Backbox is taking shape. Added some cable management and my controller boards. All that remains here are terminations for cab/playfield harnesses, and the audio amplifier. And hopefully the knocker will work this time around.
    3 weeks later
    #61 71 days ago
    Three months. Clock is ticking.
    But the progress is so beautiful. Did some hardcore cord-cutting and eliminated 99% of the wires from under the playfield, then started from scratch. This is really my first time doing new wiring for a matrix, but I'm pleased to report that except for two lamps with backwards diodes, all controlled lamps and switches tested as perfect. Exceptions are a nonexistent switch (the VUK switch turned out to be defective - no wonder it was unreliable!) and the two ball trough opto switches, which will need to be wired up properly to a power supply in order to function.
    YES, I AM RETRYING THE USE OF THE OPTO SWITCHES. Can't give up on them just yet.
    And here's a manual page. I don't want to come back to this thing in six months with a problem, and not remember where the wires go! The lamp matrix polarity is backwards relative to the WPC/Sys11 design I copied, but it works fine as long as I pay attention to the diodes. Secondary wire colors do not, in fact, exist, but maybe someday I'll stripe them with paint or something.
    #62 71 days ago
    looks great - nice and clean
    #63 66 days ago
    I had been following along with this because of your plan to take it to MGC. Thought it was cool, didn't really get the Undertale theme.
    Picked up Undertale recently from Best Buy with some credit I have. Have played it for maybe an hour so far.
    *totally* get it now. What an incredible game. Super excited for this. If you'd like to share it when you feel complete on our pages, I'd be happy to spread the word
    #64 66 days ago
    That's a very nice offer and I will definitely take you up on that! Now the pressure is really on.
    Playfield wiring is almost done. Remaining:
    - 2 flashers
    - GI
    - Power to trough optos
    After that, cabinet and backbox wiring remain. The moment that this thing comes alive again will be a beautiful moment.
    I think I will have to cut the "Genocide" / "Neutral" story branches prior to the show, as they will both add another layer of rule complexity. As long as you can complete a "Pacifist" run, I will consider it good enough for a first show.
    #65 66 days ago
    Tonight I pulled the playfield again, ideally for the last time. Finished up a few wiring bits - GI from plug to relay to socket - and tidied up the wiring harness coming off the back - which I believe is done!
    For playfield, all that remains are two things. The first is ball trough opto power, which requires two resistors I forgot to order. Yay. The other is the GI harness, which definitely warranted the removal of the playfield. I removed all GI sockets, dropped them into this pile, and have been working on removing the old solder and remnants of wire.
    Once all the terminal holes are opened up, I can reinstall the sockets and get them wired up properly.
    Then the next order of business is cabinet wiring.
    #66 64 days ago
    Playfield wiring is done, and every connection tested.
    The only thing left unattached is the power for trough optos, for reasons already specified. Having finished the wiring up, I moved on to the cabinet. First order of business was cleaning it out, since I had pretty much been using the bottom of the cabinet as a giant trash can for the old wires and bits of solder. Rather than further mess with the flipper button switches, and live with switch blade bounce, I dug through the parts bin and installed something much better.
    The Start button will get proper wires and plugs when all is said and done. Speaking of that button, I never did fix the decal around the outside, leaving a ratty edge where I didn't quite cut it into a perfect circle. Finally it is fixed! I removed the button, cut a smoother edge, then sanded the edge and fixed the paint. I think it looks much neater now.
    #67 58 days ago
    Cabinet, this is Playfield. I believe you've met before?
    Got the ground strap routing done throughout cabinet and backbox, and although it's not as neat as some, it should serve its purpose. Inside the backbox, I ran the playfield cables through one of the access holes and snapped the Molex connectors into their mates. This way I could guarantee I had enough connectors and will be crimping the correct wires into the correct housings.
    And then, a package arrived at my door. Could it be... the rest of the supplies needed for the cabinet wiring???
    (Yes.)
    #68 57 days ago
    Two down, one to go; cabinet wiring is done. For sure this time. Definitely.
    Well, almost done - next order from PBL will include a coin door interlock switch, and that'll be the end of the loose wires you can see in the front left corner. All wiring harnesses have been tested for tightness; it is safe to raise the playfield and lower the backbox without tugging any wires too hard.
    So now all that remains is to connect all THIS stuff:
    Definitely a lot less spaghetti-like than it used to be, although I suppose this would disappoint Papyrus. I have a backbox wiring diagram to go by for this. However, I'll need to be careful as I ended up tweaking the number and arrangement of plugs when I did the cabinet wiring.
    Meanwhile, the 6V wall wart that I tapped into the GI circuit is telling me my playfield is showing signs of life again!
    #69 48 days ago
    Solenoids work.
    Today, while testing the game (missing reflex control and controlled lamps but otherwise coming together nicely), I earned a replay. Finally, at long last, hearing that knocker fire as I hit 500,000 points was the sweetest sound I've heard this week.
    Some VERY weird issues cropped up this time around, but thankfully nothing that crashes the game. Left flippers bizarrely seem to be linked to the ball trough optos, and when a ball is served, they fire. And, given that they stay up for 0.8 seconds, they are somehow being triggered in software to fire at that time. The left flipper also flips itself when the m-o-n-s-t-e-r "N" target is hit, and when the ball lands in the Ruins scoop. And turning reflex devices on (slingshots and jet bumper) makes everything go insane. So yes, bugs to fix in the new software.
    Oh yeah, that thing about the ball trough optos? Other than the weird bug, they work perfectly. I don't know what I did wrong that first time around, but it's working great now.
    And speaking of optos: Fliptronic opto switch boards work flawlessly with basic logic switch systems with absolutely no modifications or accommodations necessary. This discovery was one of my most exciting moments of this project. The flipper action is SO smooth and precise now!
    Remaining:
    - Solenoid driver bug fixes
    - Lamp interconnect harness.
    Since I am still using prototype breadboards and didn't have many options as far as connectors, I terminated the playfield wiring with Molex Mini-Fit connectors, and will make up the difference (one more foot of wiring for each row/column/flasher) with a short bundle ending in 0.1" circuit board header plugs. Better board design next time!
    #70 44 days ago
    Two months (and three days) remain.
    The clock might be ticking, but it now ticks much slower and quieter.
    We are BACK IN ACTION!
    Some minor software bugs to work out, some related to the rewiring and some left over from before. Also swapped out the flipper buttons. White matches the cabinet logo and also the color of the flippers themselves.
    Gameplay video coming soon, following the next batch of code improvements!
    And goatdan - Yep, at this point it's pretty much confirmed that I will be bringing this one to the MGC.
    #71 39 days ago
    And now that the wiring is back in action... here's a gameplay video! At long last!
    Seeing as my last video didn't even have the ramps installed yet, there is a LOT that has changed since then. Content warning: The end of this video contains a software crash. Segfault while trying to award a Tem Shop bonus. Will have to go back and debug. The game probably did it on purpose to avoid spoiling the wizard modes for you guys just yet... shame because I was so close!
    (Perhaps a bit ironic given the quote above. But at least this is an issue in software, not in hardware.)
    Some notes:
    - Yes, the feature lights are a bit dim and pulsey. Need to investigate how to bring the lamp matrix more power.
    - Alphys's mode (the first one started in this video) is clearly unfinished, as you're instructed to "shoot lit arrows" and there are obviously no lit arrows. I might tweak the rules of this particular mode as it's very similar to Undyne ("Shoot lit shots to dodge my SPEAR OF JUSTICE, punk!") but without multiball.
    - A few feature light bugs still need addressing. Collected Undyne shots stay flashing (which is why I ignore the flashing scoop after hitting it once), and Muffet's light doesn't immediately come on after collecting the Spider Donut. The orange bulb by the library scoop seems to have a connection problem as it flickers in and out of life.
    - Collected Dog Residue during Toriel's mode (target bashing) and managed to score about 260,000 points in target hits. This mode is epically exploitable if you can manage a multiball at the same time. I don't think I'm going to change this. In fact, I might make the Tem Shop more likely to award this feature during that mode.
    - REPLAY!!! at precisely the 3:30 mark. It's still awesome to hear the knocker working properly after all this time.
    - Left inlane might need some tweaking as balls get stuck between slingshot and wall now and then.
    - Mettaton EX's mode is pretty fun. In the original Undertale, Mettaton is known for his fabulous and deadly moves on his TV show. So in Underpin, his mode revolves around making combo shots - and it keeps going as long as you can keep making combos.
    - Yes, requirements to hit the CORE shot will have to go. During Undyne, I make multiple desperate rejected attempts to shoot for the lit VUK and never manage it.
    #72 39 days ago
    This is amazing. What did you use to program control the board? Fast, p-roc with python ?
    Seriously if the game was in production I would be interested for sure to buy it. What A GREAT project ... congrat.
    #73 39 days ago
    Outstanding! Congratulations!
    #74 39 days ago
    looking great!
    excited to play it at MGC!!!
    #75 39 days ago
    Quoted from noitbe1:
    This revision of the game electronics is controlled by a Teensy 3.5 and a Teensy LC, two very capable dev boards programmed with the Arduino IDE. The game program itself is in C++, with the sound and graphics powered by the Allegro video game libraries. All pinball-related code, both on the PC and in the board firmware, was written completely from scratch.
    #76 37 days ago
    If you want to give MPF (https://missionpinball.org/) a try let me know and I will help you to get your boards supported as platform (http://docs.missionpinball.org/en/dev/hardware/index.html) in MPF.
    #77 37 days ago
    jabdoa Thanks for the offer! The software is pretty much figured out for this one, but MPF is a very attractive looking system that I will definitely be considering for future projects.
    #78 26 days ago
    The rules are finally good enough to print out rule cards!
    Pretty generic styling, but I think it gets the job done. Made a "FREE PLAY" card for the other side, derived from the custom pricing cards I use on route.
    #79 26 days ago
    I was myself (and still) a C++ addict but now since I had to learn and practice Python for my own project, I have to say that it’s much more easier and you can focus more on the content than the memory release kindof things, arch, derivations...Anyway congrat for your project, it should have been a lot of work but great result at the end.
    3 weeks later
    #80 3 days ago
    Well, I REALLY did it. This time for sure.
    The software is essentially done. Or at least as done as it's going to be before the show. And the wiring is done.
    IMG_20190310_123551319 (resized).jpgIMG_20190310_123910008 (resized).jpgIMG_20190310_123839805 (resized).jpg
    The sound works, the lights work (feature lights are still dim, but... live with it!), the display works.
    And the playfield is done.
    Recorded a gameplay video this evening, which runs all the way through the final boss and ends with a score of 3.5 million. I'll post it here once it uploads.
    I hosted a couple of three-player matches after dinner today, with only minor notes taken and no software crashes.
    And in three weeks, some of you will be playing this!
    #81 3 days ago
    I've been watching your progress for a while. And it inspired me to play the game! (Switch) love it! Stoked to see the final product and maybe play it someday. Good work. Always awesome to see new cool titles getting enjoyed by others!
    #82 3 days ago
    look forward to the video, looks great
    #83 2 days ago
    Aaaaaand the video.
    Contains boss fight spoilers; be warned. Also, contains a fanfare stolen DIRECTLY from a certain System 11 game. Don't hate me, I needed a way to transition back into normal gameplay! Maybe after the show I'll make my own sound effect.
    Also, I actually did really bad on the modes. Missed most of the good shots!
    #84 2 days ago
    Aaaaaand the video.
    Amazing
    #85 2 days ago
    Thanks for posting that video. I love to see projects progress, and find it informative as I too am starting a homebrew project.
    A few observations. That cabinet art/color is not my favorite. I know it is a result of the theme, but that brown just falls flat.
    The playfield, however, is quite stunning. Excellent use of colors and and is visually appealing. Just wish it extended to the cabinet/backglass.
    After having watched many, many, MANY videos of homebrews in action, I can honestly say that I have never observed a better shooting game than yours. The geometry of shots is nearly spot on. Great flow with the ramps, ability to make the same shot with multiple flippers, and each flipper flows the ball with more than one shot. It is refreshing to see very few clunk shots. I am extremely impressed with how this pin shoots. You nailed it!!
    If I can get even close to your results, I will be happy.
    Excellent job!
    #86 2 days ago
    If this is not the one game that I get to play at the show for the year, I will be really, really sad. What an AWESOME job!
    #87 2 days ago
    great video and a nice shooter and like the use of the upper flippers, awesome job
    #88 1 day ago
    Quoted from Beechwood:
    A few observations.
    This was one of the most detailed reviews I've gotten. Much appreciated!
    The cabinet art is taken from the game's intro cards, and although I did feel like they fit very nicely in the sizes and shapes of cabinet panels, I suppose I can agree about the colors. I could've tweaked them or gone with more black/green grid based art. The thing is... my talents are not in the field of art!
    I'm glad to see that you guys are liking my shots and layout. Looks like all the time I've spent studying pinball layouts has paid off! I never really had much of a whitewood for this game - this early version was the closest it ever got:
    Only the bottom flippers worked at all. This was really just for testing object scale and basically sanity checking the build. In hindsight, I probably should have built a fully flipping whitewood as this would have made me notice the rejecting saucer shots, but oh well.
    I think dropping two of the three bumpers was a mistake. Next time I build something, I am posting everything here, start to finish, and getting some proper peer review. Incidentally, anybody want me to post the rest of my early photos here? They're in the Imgur link on the first page but that's not exactly convenient to access as compared with Pinside's attachments.
    I'm still tweaking the software. There is a card table set up next to the game with a notebook and pencil, and every time I see something I don't like, I write it down. When I finish playing, I bring the notebook to my work station, update the code, and apply the changes. Latest improvements include some boss fight fixes ("WARNING!" is now shown properly, for instance) and a new "Shoot Again" message that calls attention to it better.
    #89 1 day ago
    Here's the thing. Shots are #1. Period. You have got that down.
    Code can always be updated/changed.
    Shots is the foundation upon which everything else is built. And you have that.
    Keep the ball in play. That is rule # 1
    Make it fun to keep the ball in play, that is rule #2
    Keep it going, You are doing great.
    Cheers!
    #91 14 hours ago
    This is incredible, one of the most impressive homebrew pins I've seen! I wish I were going to MGC.
    $ 8,500.00
    Classic Game Rooms
    $ 229.99
    $ 24.99
    Lee's Parts
    $ 16.95
    $ 16.00
    Yorktown Parts and Equip
    $ 27.99
    Lee's Parts
    $ 5.00
    Doc's Pinball Shop
    $ 75.00
    DBC Pinball
    $ 65.00
    Cabinet - (Alt) Translites
    Bright Lights Pinball
    $ 4.95
    Apparel - Unisex
    $ 99.99
    $ 7.95
    Various Novelties
    Pinball Wheezer
    liorillusion
    $ 69.95
    Pinball Pimp
    3D MODS
    $ 84.95
    $ 9.99
    $ 26.99
    Lee's Parts
    $ 9.99
    Third Coast Pinball
    $ 11.95
