I'll do this in 3 posts here.
I finally had the chance to try these 3 repair techniques on one game. Somehow they all 3 worked great the first time, no problems.
Solarez:
I had read previous posts about using Solrez for insert leveling, some worked out and others didn't. I bought the variety pack of Solarez so I could choose the best one with lowest viscosity.
The inserts were lightly scuffed up and cleaned with alcohol before using the Solarez. It was applied by slowly drizzling it onto the insert in a jellyroll pattern from inside out. A toothpick was used to convince it to cover all the insert near the edges; surface tension had to be overcome. The 1 insert had a tall meniscus while the 2 insert had a flatter meniscus.
A UV flashlight was used for 3 minutes, moving it around and up and down for even coverage.
The result was a hard, dry surface that looked great. Just to be sure I put them out in the sun for 15 minutes but I don't think it was needed.
The inserts were then wet sanded gently and final coated with Future Polish for the final shine and protection.
That was the quickest insert leveling I had ever done and saved the original graphics.
