(Topic ID: 290180)
A philosophical pinball repair question
By undrdog
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by undrdog
    #1 3 years ago
    A set of 3 switch stacks on a motor on an old machine is really giving me troubles. I have a sister machine and could switch out the stacks. If those stacks are ok, my job is done. Probably.
    Or is it nobler to keep trouble shooting the fool thing? I'm bound to figure out the problem sooner or later. (This is strictly for me as a hobby, its not a machine on a route that needs to be up and running.)
    #2 3 years ago
    If the other game works I wouldn't mess with it. Switches don't fail unless they break or contacts burn up,you should be able to verify switch operation by testing continuity across switch
    #3 3 years ago
    Not all luck good . Swap parts old machine might make it mad and neither work . Buy new parts and be done with it.
    Shane
    #4 3 years ago
    What problems are the old switch stacks giving you ?
    If they seem to lose electrical contact when still closed. Repeen the rivet/contact point on the end or solder it to the leaf blade.
    #5 3 years ago
    The sister machine is just for parts, so I wouldn’t be ruining a good machine by switching out.
    The contacts seem good, although I haven’t taken them off the machine to check. There's a contact somewhere that is confusing the logic on what needs to be happening in which order on an old Bingo style machine.
    And the one that I keep bending but it only stays bent long enough for me to think I fixed that one particular sub- issue.
    #6 3 years ago
    Tighten the screws on switch stacks first, before doing any adjustments or repairs!
    #7 3 years ago
    I have a Space Invaders that was having a volume issue with its sound board, and issues with its lamp board. Both boards were original with the original serial number stickers on them. I also have a spare Space Invaders backbox in my "wall of backboxes" purely for decoration, that happened to have all its boards still in it. I swapped out both original boards for the ones in the spare, and now my SI is running perfectly. Kinda bothers me that the SI now has non-original boards, but when I teach myself how to solder and desolder on these ancient boards, I'll see if I can get the originals working again. But the important thing is that the game is now working.
    #8 3 years ago
    jibmums i had bought some old plasma displays for Mystic. One came dead.
    I have only basic understanding of circuitry, but I know a burned resistor when I see one. Switched out some resistors, resoldered some traces, and got a nicely working display for player 4.
    This page was printed from https://pinside.com/pinball/forum/topic/a-philosophical-pinball-repair-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
