(Topic ID: 242433)
A Pecos Puzzler: Diagnosing EM Pin Problems
By Pecos
2 years ago
  • 169 posts
  • 22 Pinsiders participating
  • Latest reply 2 years ago by pinballdaveh
  • Topic is favorited by 40 Pinsiders
There are 169 posts in this topic. You are on page 1 of 4.
#1 2 years ago
Have an interesting diagnosis that you want to share? Want to bone up on your diagnosing skills? If so, then this is the thread for you.
Post all pertinent information and clues that are needed to solve the puzzle, but DON'T provide the answer. DO please let a respondent know if he or she has the right answer. You can provide more clues if answers are not forthcoming. If no one gets the answer, please DO provide it so we can all learn from your experience!
DO please link your game to this topic so others may find it more easily.
Please DO NOT post specific EM problems that you may have here.
Please DO quote the original question in your post so others will know which question you are answering.
If you are trying to figure out the solution, you may ask questions, but the OP may or may not answer your question - DON'T want to make it too easy!
I know quite a bit about EMs, but I certainly don't know it all. If I get something wrong or you want to clarify a murky answer, please chime in!
I know Williams and Bally pins from the 70s the most and those will be the machines I use as examples. Gottliebs are different and since I know squat about Gottlieb pins, please help me out if you find an answer that is appropriate for Williams/Bally but incorrect for Gottieb.
Here is a fairly easy one, but with a twist!
Problem: A 1976 Williams EM Grand Prix was not advancing the ball count. The player could play ball one over and over. If you tilted the game, the ball count would advance when the ball reached the outhole. If the ball went up the left lane to the top, the game would tilt and ball count would advance when the ball reached the outhole. Where do you look first when trying to fix this problem?
#2 2 years ago
I'd look at the Ball Index relay to see if the E position switch was stuck closed.
I don't think this is the whole problem just part of it
#3 2 years ago
Quoted from Cheddar:
I'll give you a 'You are correct sir' for your answer.*
In short, I'd first look to see if the Ball Index Relay was energized or not after the ball was put into play and points scored.
In this case, the Ball Index Relay was NOT energized! Bingo!
Quoted from Pecos:
You get this exact behaviour if the Ball Index Relay is not energized when the pinball reaches the Outhole.
But why wasn't the Ball Index Relay energized when the pinball was put into play?
The Ball Index Relay energizes when the game is tilted or when points are scored. If you look at the schematic for Grand Prix, as I did, you will find that ANY points, 10, 100, 1,000 or 10,000 points, will energize the Ball Index Relay. When I tested switches on the playfield that scored each one of these types of points, I found that the Ball Index remained NOT energized! I had to look elsewhere for the problem as it was extremely unlikely that switches on all four point relays, found in the backbox, were mis-adjusted.
The twist on Grand Prix is that it is one of only three games, Grand Prix, Liberty Bell and Hot Tip, that have a rollover switch in the left return lane that, when closed before any points are scored, will tilt the game. This is called a Tilt Rollover
It is interesting to note, for some of us EM nerds, that not all games work alike. OXO, for example, will energize the Ball Index Relay ONLY when 1,000 points is scored. This is because the pinball MUST come through a top rollover switch that scores 1,000 points. Unlike Grand Prix, the 10 and 100 point relays will NOT energize the Ball Index Relay.
* The manual shows switch E as normally closed (the Ball Index Relay was not energized), so Cheddar's answer is correct.
#4 2 years ago
Oh cool! I don’t have any questions or answers right now, but think this should prove to be a very interesting thread. I shall be following along hoping to absorb some knowledge!
-Brian
#5 2 years ago
Problem: The player one 1,000 point score reel on a 1973 Williams OXO is stuck on '0'. You can hear the solenoid buzzing. You turn off the machine so you won't fry the solenoid to a crispy critter. You take off the backbox door and lift up the playfield to look for what might be the problem. List in order of most likely to least likely all of the reasons why this 1,000 point score reel solenoid is 'stuck on'. Bonus points for suggesting ways to narrow down the culprit.
#6 2 years ago
Quoted from Pecos:
Wow! Cool. Great idea, Pecos. Following, FER SHER!
Quoted from Pecos:
Grand Prix is...one of only three games...that have a rollover switch in the left return lane that, when closed before any points are scored, will tilt the game.
Wait, wha--? Why?! *LOL*
Quoted from Pecos:
Most likely(? Please correct me, I'm here to learn.):
1) Stuck 1,000 pt switch on the PF, find, and adjust? Narrow it down by looking only at the 1,000 pt targets first?
2) Look at the schematic to see if there is a related switch in the path having problems down the line?
3) Beyond my skill level, pray that kind Pinsiders can help (maybe this should be most likely on my personal list).
Awesome thread, @pecos !
#7 2 years ago
Quoted from Pecos:
Quoted from RyanClaytor:
Could also be faulty wiring or arching on the lugs on the 1,000 point score reel coil in the backbox, or an issue with the leaf switches on the 1,000 point relay under the PF.
If it was a stuck switch on the playfield, the score reel wouldn’t stay at zero. It would tally points automatically once a game is initiated.
#8 2 years ago
Great! That is the idea of the thread. As a professor you will know that the teacher often learns more than the students. So, I'm right there with you Ryan!
You are correct sir! This is the first place I would look on the playfield, but with a caveat that I will describe later.
That's a very good answer if you don't know the answer! A schematic is an excellent place to go looking for 'where might the problem be.' You should start by finding the stuck-on solenoid on the schematic, and then following the circuit back to look for what might be causing the solenoid to lock on.
Quoted from Colsond3:
I don't know what you mean by 'arching.' If you mean that the two lugs on the 1,000 point score reel solenoid were touching, then wouldn't that cause a short and blow a fuse when the 1,000 point relay was energized? But I'm not gonna test that theory out!
Actually, it would. At least that is how OXO behaves. Other pins might work as you say. The stuck switch on the playfield would energize the 1,000 point relay and it would stay energized as long as the playfield switch remained closed. The 1,000 point relay would close the switch that energizes the 1,000 point solenoid and it, too, would stay energized until either the playfield switch is opened or that relay switch is opened. The energized 1,000 point solenoid would pull the plunger in but the score reel would not move from zero to one until the solenoid was de-energized and the plunger released.
...an issue with the leaf switches on the 1,000 point relay...
Ding, ding, ding, ding! We have a winner!
The 1,000 point relay is actually the first place I would look. Why? If the 1,000 point relay coil is stuck-on, then I know that it is a playfield problem and I would then follow Ryan's advice and look at all 1,000 point switches on the playfield. If it wasn't stuck-on, then I would look for the switch on the 1,000 point relay that energized the 1,000 point score reel solenoid. According to the OXO manual, a very handy reference, the switch that "Pulses 1,000 point drum units, thru player unit disc" is switch 1C. If that switch is closed, the 1,000 point score reel solenoid will stay energized and we don't want that! If that switch is adjusted properly, then I have to look elsewhere for the offender.
There is one more, less well known reason left, gang!
So, ladies and gents, for those of you keeping score, so far we have:
1.
2:
#9 2 years ago
Neat thread idea Pecos!
Here's a fun one:
Bally Circus Queen
Red and yellow rollover relays trip simultaneously when either should be awarded individually.
There are only a few potential trouble spots, but those without bingo familiarity might not get it without looking at a schematic.
Or, another easier one on Grand Prix:
Alternating lamps at top do not alternate. Easiest to hardest.
Ryan, that switch exists to prevent cheating - magnet would hold up the orbit instead and prevent the ball index from changing state until you got a flip in. Would also increment the left bonus unit, which could make a difference if you were close to a replay threshold.
#10 2 years ago
Lamps, Lamps, Lamps! There are always a few #44 or #47 bayonet lamps that are always flickering, dim or just not working at all. Unless the lamp is burned out, it's usually the lamp socket that it the problem. A lamp socket looks so simple! But it's only been in the last few months that I have been able to turn one of these old lamp sockets into a reliable performer.
Problem: A lamp is flickering on a 1975 Bally Wizard! playfield. Another appears to be dead, even after testing the lamp and finding it to be good. Yet another goes from dim to off. What are the points of failure on a lamp socket and how do you remedy them?
#11 2 years ago
Corrosion (dull grey) on the outer socket or on the center nub. Poor connection between center nub and the tab that the wires attach to. Weak spring on center nub, or fatigued metal not securely holding the lamp if you have those cheap style sockets...
Remedy is usually replace, unless you are super cheap and have more time than you know what to do with.
#12 2 years ago
I watched a tech at the MoP in Banning solder buttons to tabs and barrels to mounts on an old em. He pulled the playfield and did all.of them at once. Machine lit up bright and beautiful after that.
#13 2 years ago
Quoted from Pecos:
I agree Pecos...flickery bulbs make a nice game look like ass...
Almost always a poor internal connection in the socket itself. Once the bulb has been ruled out as the problem, I do this:
First attempt: Twist the metal tab the wire attaches to - this tightens up the connection between the plate and the socket itself, and often is enough for it to work fine after that.
Second attempt(s): Solder the socket to the base as Cheddar describes, and/or resolder wire from tab to nub on the underside of the socket
Third attempt: Replace socket
#14 2 years ago
A hint:
The six failure points on a typical EM pinball lamp socket - To filament in blue and from filament in red
And, under the hood, a spring!
#15 2 years ago
As I was thinking about the points of failure on a lamp and lamp socket, I realized that I didn't know the name of all of the parts. I went looking for them and found a few, but not all of them. So, please help me and the pinball world out and name the 'proper' parts of a #44/#47 lamp and 'bayonet' lamp socket.
Oh, one point of note. The pinball world is full of parts with different names. Pop bumpers have been called Jet Bumpers, Thumper Bumpers and, of course, Pop Bumpers. 'Thumper Bumpers' is a cute name but for some reason every time I hear it I think of rabbits and not bumpers that go thump. All of this to say that there may be more than one answer for any part name! So, don't be shy to name these parts. There are lots of 'correct' answers, and we can determine later which part names we deem to be 'proper.'
#16 2 years ago
Quoted from Pecos:
The correct answers so far:
1.
Quoted from Colsond3:an issue with the leaf switches on the 1,000 point relay
2.
Quoted from RyanClaytor:Stuck 1,000 pt switch on the PF, find, and adjust?
And now for those of you eagerly awaiting the third common cause:
3. If the normally closed Score Reel Unit Solenoid End of Stroke Switch (SRUSEOSS), let's call it EOS switch for short, does not open when the solenoid is energized, the solenoid will stay energized and 'stuck-on!' Not a good thing at all. Stop and turn off OXO!
Please note that on Williams and Bally pins in the 70s, the far leftmost score reel does not have this EOS switch.
#17 2 years ago
Look ma! No SRUSEOSS (Score Reel Unit Solenoid End of Stroke Switch)!
Question: Why does the leftmost score reel unit on OXO, and other pins from this era, not have an EOS switch like the other score reels?
The leftmost score reel can be:
  • The 100,000 score reel on a game that goes to 999,999
  • The 10,000 score reel on a game that goes to 99,999
  • The 1,000 score reel on a game that goes to 9,999
#18 2 years ago
Because it doesn't have a relay either? Probably only works by rolling over the previous digit, so they assume that the prior completing its stroke will mean the highest does too
#19 2 years ago
Quoted from zacaj:
Because it doesn't have a relay either? Probably only works by rolling over the precious digit, so they assume that the prior completing its stroke will mean the highest does too
Excellent, if by 'precious digit' you mean what I think you mean! OXO has no 10,000 point relay. The only way the 10,000 score reel can advance is when the 1,000 point score reel goes from 9 to 0. The 1,000 point relay and a switch on the 1,000 point score reel handles the energizing/de-energizing of the 10,000 point score reel solenoid.
#20 2 years ago
Quoted from Pecos:
Technically active bumpers also, as opposed to passive (such as mushroom bumpers).
#21 2 years ago
Hi everybody
I refer to the posts -10 to -15 --- bajonet lamps, sockets. Here is a good topic https://pinside.com/pinball/forum/topic/flaky-bulb-sockets-solder-question#post-1241868 , in post-26 I wrote about using a copper brush. Here in another good topic https://pinside.com/pinball/forum/topic/crappy-bally-light-sockets#post-3856406 I show a link - well, lately in an Bonus-Ladder (the lights below the playfield) - a lamp did still not light up after thorogh cleaning with an steel brush - I do not like the "put a drop of solder there" solution so I used a thin copper-cable (we always call just wire) --- two windings to fill that gap / chap then secured the ends of the cable by wrapping --- and from then on the lamp works. Greetings Rolf
#22 2 years ago
Very ingenious, thanks Rolf!
#23 2 years ago
Beautiful diagram Rolf and Welcome! Thanks for posting it. I want you to know how sad I was when I heard of your medical issues. I am heartened to see you back in the game and posting again.
We seem to have, independently, come up with similar solutions.
Quoted from Pecos:
Quoted from RocketFromTombs:
All good answers. I forgot about a weak spring and not securely holding the lamp answers so you get extra bonus points!
This is an alternate solution that I don't like, but may be perfect for you. There is almost always more than one way to fix a problem and if you like the solder method, gopher it!
Quoted from Stoomer:
I forgot about the solution of last resort, replace the lamp socket! I have done this more than once. Bonus points for a solution that I had forgotten about.
Cleaning the lamp and lamp socket is the solution for oxidized metal. Perhaps you have seen this oxidation. It is a white coating on the lamp socket and is the enemy of proper electrical connections. There can also be corrosion and dirt, your basic 'grunge', on the connection points.
I use 91% Isopropyl alcohol and NicoVolta's Magic Brush. The Magic Brush is a Dremel tool and a #443 wire brush and it is the best method I have found for cleaning corroded and oxidized EM parts.
First, use a Q-Tip soaked in Isopropyl alcohol to clean. Then use the Magic brush to polish. Then, again use a Q-Tip and Isopropyl alcohol but drier this time. I am going to call this the IPI cleaning method, Isopropyl, Polish and Isopropyl.
Connection points 2, 3, 4 and 5 get the IPI treatment. Point 2 is best cleaned by pushing down on the lamp socket 'center post,' (still need the name of these parts), just as Rolf shows.
I used a little bit of solder wire, tightly tied, as a last resort if the connection was still bad, but a good polishing should give you a good electrical connection. If you must use a wire, Rolf's copper wire is a much better solution than solder wire. Solder wire melts too easily and is too 'fat!' Like you Rolf, I do NOT like using solder on my lamp sockets.
I was working on a Capt. Fantastic and The Brown Dirt Cowboy when I discovered that the lamp contacts were badly oxidized, a good reason why most of these bonus lamps weren't lighting. I usually just replace all lamps with new lamps, so I had not seen this problem before. A quick polishing of connection points 3 solved the problem.
The Harlem Globetrotters On Tour I was restoring had a 'dead' lamp on the GI lamps. After a lot of consternation, I discovered that the 'from transformer - hot?' 6 Volt wires had been soldered to BOTH points 1 and 6! Electricity will not flow through that type of connection!
Here is a summary of how to fix the six failure points on a lamp and lamp socket:
Connection Point 1: Look for loose wires. Check to make sure there is a solid solder joint. Verify that the 'from transformer' 6 Volt AC wire is connected and NOT the 'to transformer - neutral?' usually bare wire. Please, someone, correct me if I have those wire names wrong.
Connection Points 2, 3, 4 and 5: Gets the Q-Tip soaked in Isopropyl alcohol, Magic Brush to polish and Q-Tip and Isopropyl alcohol, (IPI), treatment. Be sure to thoroughly clean and polish connection points 4 where the bayonet nubs attach to the socket! This point of electrical connection is often overlooked but just as important as the other connection points.
Just look at all of the corrosion and oxidation on these lamp socket parts! After you are done with IPI cleaning, these parts should be gleaming!
Connection Point 6: Similar to Connection Point 1. Look for loose wires. Check to make sure there is a solid solder joint. Verify that the 'to transformer - neutral?' 6 Volt AC usually bare wire is connected and NOT the 'from transformer - hot?' wire.
A lamp in a lamp socket looks like such a simple bit of pinball engineering. But, I hope that you now realize how complex it really is and how to best get those EM incandescent lamps of yours shining brightly, once again.
#24 2 years ago
Following......Great idea Pecos!
#25 2 years ago
Quoted from Pecos:
I use 91% Isopropyl alcohol and nicovolta's Magic Brush. The Magic Brush is a Dremel tool and a #443 wire brush and it is the best method I have found for cleaning corroded and oxidized EM parts.
Wow!!! Those we're stellar visuals and descriptions, Pecos! I read and looked at this real methodically and feel like I understand lamp connections much better! Thank you!
#26 2 years ago
Quoted from rolf_martin_062:
Will have to try that idea; I also don't like the solder the wire directly to the tip, just looks bad.
I've replaced a lot of bulb sockets as I feel this really detracts from game play.
#27 2 years ago
I’m following this thread too. I’m here to learn and pick up tips instead of calling my EM buddies all the time. I’ve had a little taste of success on the last two issues and I’m excited to improve more.
Tiger woods says you have to have confidence to win.
BUT it’s easy to have confidence when you win all the time. You have to wins some to have confidence. Pinball repair wise.
#28 2 years ago
I think that Williams space mission also has the tilt rollover.
#29 2 years ago
When I bring a 'new' Project Pin into Pecos' Palatial Pinball Parlour, it is almost a certainty that at least one of the score reels will not be working properly. On OXO, there are three switches on each of the 10 Point, 100 Point and !000 Point Score Reel Units. The 10,000 Point Score Reel Unit has only two. It's good to know how these switches work and what they do when trying to debug Score Reel issues.
Question #1: Why does the 10,000 Point Score Reel Unit have only two switches?
Let's go back to our, now infamous, OXO 1000 Point Score Reel Unit.
In these pictures you can see these three switches. These switches can be in one of three states:
State 1:
Top switch Open.
Middle switch Open
Bottom switch Open
State 2:
Top switch Closed
Middle switch Closed
Bottom switch Open
State 3:
Top switch Closed
Bottom switch Closed
Question #2: What number(s) will you see on the Score Reel when the switches are in State 1?
Question #3: What number(s) will you see on the Score Reel when the switches are in State 2?
Question #4: What number(s) will you see on the Score Reel when the switches are in State 3?
#30 2 years ago
Quoted from Pecos:
Wow, clean contacts. Your photos remind me of this drawing from Williams' Introduction to Coin Operated Amusement Games (with the answers cropped out):
/Mark
#31 2 years ago
It's time to tally up the points! Oh goody!
Generally speaking, a correct answer will earn you 100 points. Answers to easy question earn 50 points. Bonus points are either 25 or 50 points, depending on the quality of the answer and the complexity of the issue.
Special points will be awarded for special posts, like 250 points for rolf_martin_062's informative diagram and for a tip to help fix lamp socket issues.
Asking a question earns you 50 points. Answering/grading your own question earns you 100 points, but please give Pinsiders a few days to answer before you do.
I reserve the right to modify the rules of this 'just for fun' point system.
Pecos is disqualified from earning points!
rolf_martin_062 - 250 Points
RocketFromTombs - 200 Points
RyanClaytor - 175 Points
zacaj - 150 Points
Stoomer - 150 Points
Cheddar - 150 Points
bingopodcast - 150 Points
Colsond3 - 100 Points
#32 2 years ago
Question #1 score reel does not have a 9th position carry over.
Question #2 score reel at zero position.
Question #3 score reel at any number 1-8 position.
Question #4 score reel at 9th position.
#33 2 years ago
Hi everybody
Awesome Rolf...thanks! I'll have to try this one...
Sean
#34 2 years ago
A note of caution: I have worked on several games with this fix done, and while it works, if not properly secured it is prone to movement from the constant vibration of the playfield, which can cause shorts. In one instance, the wire had fallen off of the socket completely and down onto the motor board.
#35 2 years ago
Quoted from bingopodcast:
This is a bingo question, but the question itself is applicable to any game that uses trip relays. In this particular instance, there are two separate trip relays, red and yellow. Depending on which function is lit on the backglass, if the ball rolls over the appropriate playfield button (red or yellow), the red or yellow relay will trip.
In any given game, only one of the two buttons *could* be active. This means that there is no possible way for both the red rollover trip relay and the yellow rollover trip relay to trip simultaneously.
Checking the circuit itself is pretty straightforward:
1) Look for any wires touching on the back of the relays - Bally used clear tubing to protect the solder tabs from touching. If they are not intact, make sure the solder tabs aren't near to each other.
2) Check for mechanical issues with the trip - if you manually trip one of the relays, does the other trip (mechanically) with the power to the game off?
3) Follow the circuit back up the game - in this instance, the signal from the playfield rollovers is routed through the "selection feature" unit (or the time tree). For the machine in question, I pulled apart the unit to inspect the spaghetti (wiring) side of the stepper. There was a clean break between rivets, the unit was clean, and adjusted properly. Current could not pass through the unit or jump the gap between the red ro trip activator and the yellow ro trip activator circuits.
So where does that leave you? A short in the massive wiring bundle running from the head to the back door. One of the most difficult items to trace. A quick thing to check is anywhere where wires are routed around a bend - any exposed wiring through the cladding visible? Remove the cable clamps and examine under there. If everything looks good, you can use a small tool to poke around and see if you can see any breaks in the cladding. If not, unfortunately, the solution is to run new wires (and note your manual and schematic if changing wire colors!).
Now the same problem can happen in any game with trips (most games). The circuits for tripping the relays are typically pretty straightforward. Most of the time the solutions to problems are also straightforward (clean the signalling switch, etc), but sometimes, the problem requires a bit of out of the box thinking to resolve.
#36 2 years ago
I'd like to bump this one because I'm a newbie and interested in the answer.
I would start by seeing if the alternator relay is firing, and cleaning the switches/observing contact on the relay.
#37 2 years ago
Quoted from Flamingo43:
Good answer - that gets you part of the way there. What controls firing the alternator relay? It's the most likely thing to fail in Grand Prix's case.
Easiest is checking the switches on the playfield - there is one mounted on either side of the kickout at the top of the playfield.
Then checking the alternator relay, however, as stated above - that relay is controlled by something else.
#38 2 years ago
The alternator relay is controlled by a blade switch that is cam controlled on the 00-90 match unit stepper.
#39 2 years ago
Quoted from pinballdaveh:
Yes. That switch is prone to fouling from constant action and misadjustment from overzealous techs. It is by far the most common culprit in the Grand Prixs that I have worked on.
#40 2 years ago
A more advanced question
In what 3 applications does a AC relay not use the full coil voltage supplied by the transformer.
Hint: mostly found in gottlieb machines
#41 2 years ago
When there's a resistor in line?
When there's two coils in line?
#42 2 years ago
I thought about the resistor as a correct answer, but it isn’t 1 of the 3.
You are close on the second, can you explain more about it?
#43 2 years ago
We are working our way through Score Reels, how they work and what their parts do.
Three of the four OXO's Score Reels for player one have PCBs (Printed Circuit Boards). One does not.
Again with the infamous OXO 1000 Point Score Reel! An example of the PCB
Question 1: The 10's Score Reel does have a PCB. Why is it there / what does it do?
Question 2: The 100's Score Reel does NOT have a PCB. Why not?
Question 3: The 1000's Score Reel does have a PCB. Why is it there / what does it do?
Question 4: The 10,000's Score Reel does have a PCB. Why is it there / what does it do?
#44 2 years ago
Winner! Winner! Chicken Dinner!
And the reason the 10,000 Point Score Reel Unit does not have a 9th position carry over switch is because OXO has no 100,000 Point Score Reel.
pinballdaveh, you have earned 200 points for your answers!
This is a bingo question, but the question itself is applicable to any game that uses trip relays. In this particular instance, there are two separate trip relays, red and yellow. Depending on which function is lit on the backglass, if the ball rolls over the appropriate playfield button (red or yellow), the red or yellow relay will trip. (and lots more!)
Wow! Very and informative and thorough answer. This earns you 100 points for the answer and 50 special points for thoroughness.
Your answer awards you 50 points for the answer and 50 special points for (trying to) answer your own question.
This is exactly how it should be done - let the person answering the question know that there is more to the answer. For such an excellent reply you earn 200 points!
Perfect answer! 100% correct. You earn 100 points
100 more points! I am glad that you guys answered the No. Match Unit question, or the Mini-Match as I like to call it. I have spent more than two days trying to fix one of these PITA units on an Aztec and I never did get it working. I would have written a long rant about how much I hate these things and how I tried to fix it and how I spent three more days restoring the backbox on another Aztec only because it had a working Mini-Match unit! I better stop now. I'm headed to that small dark place...
Good to see that someone who knows Gottliebs is asking Gottlieb questions! I know very little to nothing about Gottlieb pinballs.
You earn 100 points for the question and another 50 special points for helping me out with Gottlieb Q's and A's.
Quoted from zacaj:
75 points for the answers and 25 bonus points for answers that you aren't 100% sure of.
Another good reply to the answerer! 150 Points awarded!
P.S. I'm pretty sure that I made that word up.
I'm not always going to be detailing how I award points. I wanted you to see the strange and bizarre thought processes that go through my abused brain when trying to best award points.
#45 2 years ago
Wow a chicken dinner. I want it from HFC (Hillary fried chicken) where the chicken dinner contains 2 small breasts, 2 large thighs, and a bunch of left wings.
#46 2 years ago
Answers to your 4 questions
#1 10’s score reel pcb is needed for the match circuit.
#2 100’s score reel doesn’t need a pcb. No circuit used to use one.
#3&4 1000’s and 10,000’s score reels needed for replay circuit . Both boards increase combinations for a replay setting.
#47 2 years ago
Absolutely correct sir! To your total, 200 points will be added.
It is interesting that you should note the additional combinations by using the 1000 Point Score Reel. I haves seen games with PCBs on only the 10's and 10,000 Score Reels. I think it was a 70s Williams single player.
#48 2 years ago
It's time to tally up the points again! Oh goody goody gumdrops!
pinballdaveh - 800 Points
bingopodcast - 600 Points
zacaj - 250 Points
Flamingo43 - 100 Points
#49 2 years ago
Ugh I'm dropping in the rankings. I'll catch up after Golden State this weekend.
Here's one that stumped me. On a Chicago Coin Deluxe world series pitch and bat player 1 would go straight to game over after strike 2 about 90% of the time. What could it be?
#50 2 years ago
Check the player control & outs unit for advancing and resetting correctly.
Does it advance when it shouldn’t?
How does it function on a 2 player game?
