Hi guys, I posted this over in "Seeking Parts" but thought I'd try here too, as it's probably more appropriate as its own thread.
Two questions related to fixing an AS Relay (the mini-stepper) on my 1972 Gottlieb Jungle: One question is about proper function of a part, and the other is about seeking a different part:
1. Any guidance on the function and position the "override stop" (part A-8738)? Is it supposed to hold up the ratchet spring (which would mean the override stop would be at an angle when you screw it in, I think), or is it supposed to limit the movement of the armature (in which case I would think it would be straight up and down (perpendicular to the armature plate)?
Essentially, I'm trying to figure out if it's supposed to sit essentially perpendicular to the armature, or if it's suppose to be at an angle so as to limit movement of the ratchet spring.
2. Anybody have a good condition (part #8740) ratchet spring (new or used?) for the AS Relay? The one I have is all bent up and I need another one if you can source it.
