New! Dark mode!
(Topic ID: 226442)
A not so bad SINBAD rebuid
By wolffcub
2 years ago
  • 132 posts
  • 26 Pinsiders participating
  • Latest reply 1 year ago by BorgDog
  • Topic is favorited by 21 Pinsiders
Topic poll
“What to do with the playfield? ”
  • Clean up playfield and reclear with 2k 6 votes
    30%
  • Repaint entire playfield and clear 3 votes
    15%
  • Go get a taco? 11 votes
    55%
(20 votes)
There have been 174 images uploaded to this topic. (View topic image gallery).
There are 132 posts in this topic. You are on page 1 of 3.
#1 2 years ago
Got my feet wet with my Lectronamo and think I'm going to start this one fairly soon. Got it In august and it looks like a fun little rebuild and a eye pleasing design. The cabinet is in not bad shape. Minor damage and separating on the bottom. The cabinet end of it will be left till next spring when I can do the sanding and repainting in the outside. Never know if I am super bored I will find a way to sake it to the paint shop at work and possibly do the cabinet there. I like the bright colours and think that alone will look nice next to the bright Lectronamo.
I have already started to try to get it working but the main board is shot and damaged. Im not sure what state the driver board is at as I could not get it to boot. The power board seems to be indicating the correct power at the terminals. I decided to get the ball rolling and already ordered a new all in one PI-1/X4 board from Flippp. This will be a easy start by replacing all the boards with this unit I hope.
The back cabinet has minor damage but the glass is almost perfect. It has no flaking at all but only has one small scratch on the back. Not sure what state the score displays are in yet but will know when the new board shows up. I do know the lights all work as when I was trying to boot it they all lit up but i have started to already remove them
Playfield is in WAY better shape than the Lectronamo was. This one has some planking going on and what appears to be normal minor wear. No areas are missing wood layers. The inserts are slightly sunk but don't appear to be all that bad. The Mylar is peeling under the pop bumpers. Rubbers are 100% shot and the plastics, lane guides are cracked and damaged in areas. Flipper assemblies need to be rebuilt and new flippers would not hurt. The drop down targets are replacement over the years so I think a new set will look better. I HATE the plastic spinner so much. I like the satisfaction of hitting that puppy dead on and watching it flip for miles. Think I might entertain the idea of doing a spinner on the cnc that looks the same but has some weight behind it.
Not sure what direction I should take on the playfield just yet.
Option 1 - Clean it up with a very, very light sand and possibly mr. clean pad then level the inserts with clear then shoot it with a few coats of clear keeping the original art on it.......or
Option 2 - Remove all inserts give it a better sanding and shoot a thin clear. Then proceed to re airbrush the full thing like I did the stern. Artwork looks nice and easy when it comes to the base colours but the black outlines looks like a handful. New inserts then the final clear to finish it off. The natural wood areas are also in good shape as they are so no staining is required.
The underside is not that bad but appears to have some surface corrosion on metal areas. Think this time around i will either replace all lamp sockets or very thoroughly clean all as I never did this on the stern and had some minor lamp issues after reassembly.
#2 2 years ago
The 3 amigos!
#3 2 years ago
I’d go the repaint reclear method. If I had the skills. Good luck
#4 2 years ago
Sinbad says "Taco time."
#5 2 years ago
Following along, I'm in the middle of a sinbad reassembly/build (got as fully disassembled restore wip).
On the spinner somewhere I have post bookmarked about drilling and adding weight to them, if I find it I'll post it up. That said in the one's i've had if they are properly adjusted with a tiny amount of lube they spin pretty good.
#6 2 years ago
Decided to repaint the play field like the last go around. This time this one is not blistering or raised in areas sure to damage. It has planking and the thin layer of paint and possibly some very thin wood is lifting with it.
Ok got what I think is a valid question about fixing “ planking “ as you can see in the pics it’s happening and I want to address it and my head is thinking all over the place. I read spraying clear on the top locks it but that questionable is it not ? Granted the clear will bond to the top but if taped over later for painting and then peeled back later I’m going to assume the clear and what’s under can still possibly lift if what below is not secure.
My proposed solution is this. Because I’m repainting and don’t mind giving the surface a light sand I might try to use thin CA adheasive over theses areas. This goes back to my Rc building days. Using thin ca glue actually penetrated the wood (balsa,bass and ply) and would lock down delaminating areas in seconds. It would actually soak in then harden and then you could sand and repair. It hardly if never actually lifted the grain. It’s so thin it actually won’t work as a filler but that would be the next step.
I’m thinking of possibly lightly sanding the areas, blowing out the dust, pouring the ca on the area, trowel quickly with a 3” stainless putty knife and let it work it’s magic. I know it will cause possible hazing of adjacent areas due to it evaporating but in a garage or outside that has direct moving air on the play field it won’t happen. I’m going to sand again and fill after anyways.
Thoughts ?
#7 2 years ago
This is what I used for the plane build and fixes.
#8 2 years ago
Playfield is all stripped now. Removing the harness on the underside was easy this time after know what to do after the other machine. Gave it 2 washes in the dishwasher.
Got myself a tumbler for this go around. Glad i got it... it sure cleans up parts realy nice.
#9 2 years ago
Got this in the mail yesterday!!!!
#10 2 years ago
Lookin good
#11 2 years ago
Best video showing off this game.
I scored big yesterday. Will post some pics later of my haul.
#12 2 years ago
Today was a good day. I removed the old boards from the back cabinet and installed the new FLIPPP board. I replaced all the connector ends to be sure everything was getting good contact.
Did my first power up and everything looked good on the board with the LED indicators. The score display was only working on player 2 for some reason and the credit showing partial numbers. A little bit of contact cleaning for the displays and now player 1 and 2 work. PLayer 3 and 4 displays for some reason are missing chips from them. I am not sure why but they are removed. Any tips for possibly finding these so I can try to solder some back in?
Trying to access the new FLIPPP menus was not working out for me so i had to did deeper. I found that the actual coin door switch itself was bad and not making contact. Temporarily I will use a spare arcade switch I have to get it working.
So yesterday i got a message from another Pinsider telling me a Sinbad Playfield was for sale con KIJIJI. It was a fully populated and look in decent shape and the seller accepted $100. This got me all excited as with a second playfield I could possibly play the game and work out some other kinks while I repaint the old playfield that came with my machine. All the mechanical / electric under this second unit looks like it a day one release. Its missing a few bulbs but I was not going to let that slow me down.
I slapped it on the cabinet, replaced a missing fuse and powered up the machine. The new playfield works! I can actually play the game! The left roll overs are not working but I think they need adjusting, and bulbs are required. All switches and flippers seem to work perfect. Im going to now install the new rubbers i have on hand and install the bulbs and go smash out some first time high scores!
Also got this yesterday. Its another back glass that I will make a frame for and hang up.
#13 2 years ago
Best new guy thread ever.
#14 2 years ago
Bowen makes any game look fun. I actually played the crap out of Sinbad a couple years ago at Zapcon. Fun and challenging game. I'm looking forward to seeing what you can do with it.
#15 2 years ago
Quoted from Gryszzz:
not sure if i should be slightly offended or say thanks lol
#16 2 years ago
Quoted from Squeakman:
Bowen is awesome!
#17 2 years ago
A link to the UDN6118A chips:
ebay.com link
#18 2 years ago
Sindbad is a fantastic fun game. IMO one of the best Sys 1s. A point to consider: If you add weight to the spinner, the game may become a one-shot-pony, as spins add to bonus, which you can collect while the ball is in play.
Good luck with the restore.
#19 2 years ago
Got the old play field all cleaned up and scanned it. Scan file all stitched up is 8 gig lol. You want to see all the wood grains? this is the file you need then lol. Going to now remove the rest of the inserts and its almost ready for a clear coat to lock everything down.
IMG_1642 (resized).JPGScreenshot 2018-10-21 22.37.19 (resized).pngScreenshot 2018-10-21 22.38.26 (resized).pngScreenshot 2018-10-21 22.38.47 (resized).pngScreenshot 2018-10-21 22.39.06 (resized).png
#20 2 years ago
Took out the inserts and bar sanded the field. Confirmed what my hands were feeling prior to the sand. Sanding fixed the issues.
Sanded and also primed the bottom. Need to now fix and fill 2 deep damaged areas then next weekend it will get the 2K clear to give me a nice level and smooth surface to start painting on.
I think this field also might need the tinted coverage I did on the Lectronamo to help blend / cover the wood damaged areas. Looking into colour options for that now.
74F32FF1-7D33-4691-83E2-E4729CEFA4AD (resized).jpeg9E255E04-1A4A-474E-A70D-E288CE8FF203 (resized).jpeg
#21 1 year ago
Need to get my rear in gear! Used the same transparent grey I used on the Lectronamo but this time instead of 3 coats i just did a light single one. It covered up the faded and discolored areas nicely.
My new display chips came in so I soldered them to the two displays that came with my machine that had them missing. One of the displays now work and the other one keeps blowing in fuse when i plug it in. I read that if the glass corners are white this generally indicates the display is shot for good so i will look for another unit.
3 of 4 now working!
Marco order should be in next week so I can glue in all the new inserts and do my first insert leveling clear coat and then start the airbrush work.
3 weeks later
#22 1 year ago
Question about the diodes used. I have a listing here of parts 1n4004 and 1n270. I can get the 4004 ones easily but it seems harder to get the 270 ones. Is there a alternate that works for the 270.
Look in on Ebay i see a few listings with the hits of 1n270 but they look different.
Ones like these ok?
ebay.com link » 50pcs 1n270 Germanium Diode Tv Fm Am Radio Detection
#23 1 year ago
I got some from Jameco a while back. somewhat more expensive than the ones you listed. Image does not match the item I recieved on the Jameco listing. Don't know about the ebay ones, if they are what they say they are they should work.
https://www.jameco.com/z/1N270-Major-Brands-Germanium-Diode-Vf-1-Volt-200Ma-2-Pin-Do-7_35941.html
1 month later
#24 1 year ago
Time to get my butt in gear. Slow but still progress.
3AD094D7-3D7C-486C-A0FD-DC843724DBDA (resized).jpegD243DCF0-A857-41EA-9F50-E8E86D61CB39 (resized).jpegF43D4DDA-1AFE-4B49-B8E4-3902EE6B848B (resized).jpeg
#25 1 year ago
looks good, how did you layout the artwork while having the playfield sanded down like that?
#26 1 year ago
A combination of things were done. I did a proper playfield scan so i was able to redraw lots of things and cut out the masking with my vinyl cutter. Some other areas are masked and the redrawn by hand then cut tout and peeled out. If the playfield was not so bad to begin with i would not of had those sanded down high spots.
#27 1 year ago
Looool
28948DD0-E17B-4873-B3B7-96B7483FC1A4 (resized).jpegA091116A-BB83-4884-9882-E4D064A65532 (resized).jpeg
#28 1 year ago
Locking in the colours. Black, text and final touches are next. As you can see I fell back to my method I used on Lectronamo to cover the damaged natural playfiekd areas. Granted I went darker then I wanted but I think it’s ok.
I changed the sword a bit as you can see. The yellow was cool but no sword is yellow! Going to change the Handel of it to gold when doing the black lines. I also changed the pendant on his turbin to gold and the gem will be a metallic green like what’s in the sword Handel now.
46B1CC0E-9F68-4826-9283-DA4F4C84FE95 (resized).jpeg98E08BCA-A429-487E-B53A-CC0A9040E9FF (resized).jpeg
#29 1 year ago
And it begins!
#30 1 year ago
This is going to take forever lol
#31 1 year ago
Looking good.
#32 1 year ago
I’m going to just fee ball it and make up my own black line designs / layouts. It’s not going to be a perfect copy of all the black lines on the original silkscreen but I’m sure it will still look good.
#33 1 year ago
#34 1 year ago
#35 1 year ago
Thanks for the process photos. That’s gonna be a true one-of-a-kind game.
#36 1 year ago
Keep it up man can’t wait to see the custom work.
#37 1 year ago
Bit of a colour change today. There was not enough contrast between the blade and quillions / pommel. I changed them to gold and kept the grip the leather brown. I’m feeling better about it now.
EC3C9C77-74D4-4FC1-AF6E-4B2FB3943026 (resized).jpegD071AEE4-0DF6-4BE8-AAE1-BCDC1B8E6E17 (resized).jpeg2F29E06C-B4D9-4E0B-81DB-830FB150014E (resized).jpeg6A570051-D55A-4C67-82BA-6109946C21A5 (resized).jpegCCA3E78F-DCC8-422D-8224-68BB3BE8AA84 (resized).jpegB74AA875-5792-4712-B234-56C6A865DAC6 (resized).jpeg
#38 1 year ago
Outstanding work. This is really turning out nice!
#39 1 year ago
Lol so the gold was too gold for my liking. It looked pasted on and fake, so I ghosted it with black to make it look tarnished. Think I went a tad too dark. Might re-mask and lighten it up. I like the bright random outlines from intentionally offsetting the mask and I don’t want to lose that.
#40 1 year ago
I think I will finish the rest of the board outlines then clear prior to doing the text. I can then lighten up the sword and if I mess it up I just need to remove the paint on the last clear coat.
#41 1 year ago
wow, that looks amazing, I love how that handle looks. may need to get me one of those cricut things.
#42 1 year ago
Im also going to change the font on the playfield to reflect the theme a bit closer. I'm liking #3 so far.
#43 1 year ago
A bit more done. Lots to still do before the end of April.
269E9DF2-59C0-4904-8EA0-2D64C1C48262 (resized).jpeg3ADF5103-A54F-41E1-93CE-0D1485797228 (resized).jpeg8AB84D28-DABD-49E7-9D57-DC7B357363D5 (resized).jpeg67310620-84E1-4C9B-9D2C-A145697364CA (resized).jpeg
#44 1 year ago
Bit more.
#45 1 year ago
Man that’s looking awesome
#46 1 year ago
Should have it ready to clear again tomorrow. After that dries is a sand and all text and final touch ups then off to final clear.
2D4A0683-775B-4221-A9AE-258653559C8C (resized).jpeg5594559D-E8BB-4080-92BC-6A36E1FA2421 (resized).jpeg
#47 1 year ago
Should have it ready to clear again tomorrow after I finish up some black outlines and shaded areas. After that dries its a quick sand then all text and final touch ups then off to final clear.
909FCDB0-2342-4003-9F56-409D10487459 (resized).jpegF9B4539F-15DA-4E7A-9946-E926415F4A1B (resized).jpeg
#48 1 year ago
Stunning, one of a kind. Can’t wait to see the finished product.
#49 1 year ago
Still lots to do but I was getting paranoid so I wanted to lock everything down.
AF4F1349-4EBB-4AD7-8347-0F83E0E5F9CA (resized).jpeg0CB48DCF-71E7-4A2A-80B0-EB4F8B171723 (resized).jpeg
#50 1 year ago
I'll admit when this thread started I wasn't a fan. However as you progressed it's really grown on me. I can't wait to see it finished. Great job!
$ 289.00
$ 49.00
$ 40.00
Arcade Arts
Apparel - Unisex
Pinball Wheezer
$ 20.50
The MOD Couple
$ 99.99
$ 86.00
The MOD Couple
$ 150.00
Playfield - Plastics
Ramp-O-Matic
$ 29.00
Filament Printing
$ 29.50
$ 76.95
Hardware
Filament Printing
$ 64.99
Comet Pinball
$ 29.00
$ 85.00
Loop Combo Pinball
$ 68.50
$ 9.99
$ 29.95
$ 11.95
$ 34.00
The MOD Couple
