A softwarebug has recently been discovered that when the rug is in the last position and a ball hit is detected it will move a little backwards to show it was hit as usual but WITHOUT checking if the end switch was active. Than it can happen the rug moves passed the end switch without seeing it and ending in the position I see on this picture.
Programmer has already fixed this for a next release. Till now only had one other case happening this so was seen as very rare thus no urgency.
When you read the above, can this be the same with you??
