(Topic ID: 217437)
A lotta ins.. a lotta outs - TBL maintenance thread
By sd_tom
  • 1,895 posts
  • 184 Pinsiders participating
  • Latest reply 2 days ago by justyn
  • Topic is favorited by 147 Pinsiders
13 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 1,895 posts in this topic. You are on page 29 of 38.
#1401 7 months ago
Hello, when I do the bowling skill shot at launch, I'm starting to see the ball roll back to the launcher and not register for it to go up into the alley. Any suggestions? Thanks all
#1402 7 months ago
Quoted from insight75:
Very cool Rens. Glad this was resolved and the issue was found. I checked my board and indeed no continuity between the pins noted.
Good to read, thanks. You can now fix it and so have a spare pcb
#1403 7 months ago
Quoted from CALencio:
I don't know much about that component, but maybe your launcher isn't powerful enough?
I think you can adjust the coil strength of your ball launcher. Check in the settings.
#1404 7 months ago
Which fuse controls the three motors please?
#1405 7 months ago
Quoted from Dan1733:
F06. It’s silk printed on the pcb below playfield with ‘12V steppers’.
#1406 7 months ago
Quoted from Rensh:
Thank you Rens. As always. do you have the part number for the fuse? My apologies, as I believe you provided it once earlier.
Thank you again
Dan
#1407 7 months ago
Thank you again
Dan
Page 12 service faq
https://www.pinballlife.com/20mm-slow-blow-fuses.html
Value you need is 1A slow blow. I see however that 1A is not present at the moment at PL. But, it’s a standard commercial available fuse 5x20 mm slow blow so you should be able to get it at many places.
I would advice to get all the values while you are at it. The values used can be found in the service faq or silk printed on the pcb.
#1408 7 months ago
Quoted from Rensh:
Page 12 service faq
thank you again!
#1409 7 months ago
Quoted from Rensh:
Remember the MPF issue, eg leds and switches with several users stopped working? Replacing the MPF PCB did the job and we got one PCB back and diagnosed it and found the cause
Wrote a service bulletin on it. A redesign for new to make pcb's has implemented when new batch is made. For now a wire is making sure connection is always there. Step 7 is the most interesting in the bulletin for those wanna see what happened
So, in the end a simple fix. Just a matter of the PCB manufacturer making the PCB just a bit smaller as they used to. And yes, there was room for improvement in the design . Every day we learn.
What serial numbers are affected by this newer style pcb?
#1410 7 months ago
I'm having an issue with my TLB that I can figure out.
I've had my TBL for about a year and a half and this is a new recent problem. I have the latest software update installed.
During most games now, the upper flipper will turn on when no ball has even been in the upper playfield. Once this happens, I can hear the VUK for the upper playfield firing off every so often. The upper flipper will sometimes turn on and off as the VUK fires off.
Another symptom is that the VUK is sometimes having issues pushing the ball into the upper playfield. I also have an issue with the VUK for the shooter ball. It sometimes won't pop a new ball out for the shooter lane. It will try a few times then just fail to produce a ball. It some how thinks a ball is ready to be launched but its not.
Any idea what is causing this flipper VUK issue?
#1411 7 months ago
If you go into switch test, I wonder if the switch associated with the vuk is being activated. Sounds like it.
#1412 7 months ago
Quoted from SDAmusements:
We don’t know exactly but a wild personal guess would be 700-750. Had only 3 or 4 pcs of this issue and all of them popped up within weeks after being delivered and where from 1 batch I think. So, I suspect all others are safe. Would not worry much about it.
It was just a matter of the pcb manufacturer cutting some the pcb just to small.
#1413 7 months ago
Quoted from el_duderino:
I would put tbl in switch test and hammer with your fist on the playfield to see if a switch will fire. As pinball coop suggests I think to its a switch issue.
For ball sometimes not coming up to the mpf via VUK see page 95 of current service faq.
Shooterlane coil. See if it is properly fixed and play with coil strength.
#1414 7 months ago
I talked with Robin and got the right to make a post a key post. This for all TBL threads.
So, if you have a post which you think should be a key post shoot me a direct message.
Most important rule is to only keypost those posts that are factual and, as such, free of opinions etc.
#1415 7 months ago
For anyone else having the problem of the ball blowing past the release pin on the bowling mech after it's launched, I may have a fix. I first made sure all surrounding parts were tightened and in place and experimented with the software settings, but still had the issue periodically. What worked for me was to cut a piece of Lexan polycarbonate to the same size as the top flat part of the release pin and glue it on top with Gorilla clear grip (dries totally clear). I added a small piece of mylar directly on top of the release pin to make removal easier if necessary. The bit of extra height has totally stopped the ball from rolling over the pin when it is launched, and the mech seems to work perfectly--at least after the last five games or so. It is also barely noticeable.
#1416 7 months ago
Has anyone tried titan slings bands? My left sling gets pummeled on the lower post near the trough, and the rubber wears thin very fast. Have to rotate it every week or so. Figure the titans material will hold up better, but don’t want to mess with the flow of the game either. Could look good in orange, too.
Oh well, either way, normal white sling rubbers are dirt cheap.
#1417 7 months ago
Quoted from Spelunk71:
Do you perhaps have a picture so I can better understand what you did? Thanks.
#1418 7 months ago
Quoted from Rensh:
Sure. Here it is. The tiny piece of clear Lexan sits on top of the flat rectangular part of the release pin.
#1419 7 months ago
I'm still confused by your problem/solution here. Are you saying the pin wasn't raising far enough and so the ball wasn't sticking in the cradle correctly after having the ball fed to the orange cradle? So you effectively raised the height of the release pin to try to make it more effective to block the ball? Are you sure the pin was actually extracting correctly and not simply binding?
Your solution doesn't look durable to me.. and if the problem was the pin's height, I would focus more on the physical assembly as something must be amiss. I'd try to modify the pin plunger itself to try to adjust it's travel as the last resort. Trying to glue stuff to steel to adjust it's shape isn't going to hold.
#1420 7 months ago
Quoted from flynnibus:
Yes, that's correct.
It seems to be extracting correctly with no issues.
I'm open to ideas but am not sure what else to try. I can't see anything awry with the physical assembly. I tried to bend the pin so it sits higher but was not successful. You may be right that the solution is not durable. I guess we'll see.
#1421 7 months ago
Simply look at the pin when it fails to hold the ball. In many cases the pin is binding and simply not raising enough to hold the ball. It fails to return completely to the raised position. The correct fix for the binding pin is adding a bushing like I outlined here https://pinside.com/pinball/forum/topic/a-lotta-ins-a-lotta-outs-tbl-maintenance-thread/page/27#post-7036761
The binding can be intermittent and work fine in test, but fail in game play. So I encourage you to check out the pin's position in the game during a failure vs just testing with the coil test or by hand.
If it holds the ball fine during a test, or after manual reset.. but fails during play to hold the ball.. it is almost certainly just binding against the bowling alley and not returning to it's full upright position. The bushing fixes that by ensuring the pin stays centered in the hole.
#1422 7 months ago
Thanks for the explanation and detailed instructions of your fix. It does sound like that’s my issue. Unfortunately, getting the bushing in there sounds pretty time-consuming. If my ghetto fix fails at some point, I will go that route next.
Now if anyone has ideas of how to stop my Jesus ramp from rejecting balls on hard shots I’d be grateful. I tried adding dead drop foam and bending the bracket slightly, but those things didn’t help (foam made it worse).
#1423 7 months ago
Does your tbl still has the extra part in place as you can see in attached pictures? If yes, remove it. After removing it Can be in very rare cases your ball stops in that place, reason why the part is there, but is very rare and a nudge will free it. Current builts don’t have that part anymore.
2715BBFC-C5FA-4DBE-A64F-6A8A877633CA (resized).jpegA0CB6ED2-46B1-4038-9E29-8C29615127D1 (resized).jpeg
#1424 7 months ago
I placed a rubber "wedge" along the sidewall on the left (looking up the lane) of the Jesus lane right at the back. This kicks the ball slightly right and towards the VUK. I've had nearly no shots coming back down the lane ever since. If it didn't work, I was going to pull out the part that Rens posted above but I haven't had to so far. Good luck
#1425 7 months ago
Quoted from Rensh:
Does your tbl still has the extra part in place as you can see in attached pictures? If yes, remove it. After removing it Can be in very rare cases your ball stops in that place, reason why the part is there, but is very rare and a nudge will free it. Current builts don’t have that part anymore. [quoted image][quoted image]
I’m not sure but will check. Thanks for the info and pictures.
#1426 6 months ago
We needed to remove the MPF to do basic service and were hesitant to de-couple the shaft that goes thru the playfield. We are not sure if the stepper motor has a home position and then keeps track of its rotations thru a feedback signal, or if it is just a two way motor with switches? Any thoughts? Anyone know the procedure for this?
#1427 6 months ago
Quoted from Fordiesel69:
It’s a stepper motor but acts like a two way motor with switches. So, no worries there.
Instructions on how-to are in the service faq.
#1428 6 months ago
Quoted from Rensh:
Is there a way you can KEY the service FAQ and other such important documents?
They are brought up a lot and while I have them bookmarked now, they were hard to find originally.
#1429 6 months ago
I'm struggling keeping balls held.
After watching this video, I wonder if Papa Pinball guy has his table set correctly and mine is off? See this tutorial here:
In this video, there are two things this guy can do that my table does not let me do at all:
1. Hit Jesus backhand from a held ball. There's no way I have the power in a backhand to do this.
2. If during a multi ball scenario and there is a ball held in the right flipper, if there is a ball coming down the exit ramp from the upper playfield, he's able to hold both balls after the ball from the upper playfield falls into the held ball. In mine, the ball exiting the upper playfield will push the ball off the flipper.
I'm certain I'm at 6.5 degrees because I drew up in CAD a 6.5 degree wedge, 3d printed it, and used a standard bubble level to get level.
Does this guy have different flipper settings and/or incline? TBH, watching him play, the game plays a little easier than mine. He's definitely able to do some things that makes for easier play.
Chris
#1430 6 months ago
Quoted from ThePinballCo-op:
I did get last week the right from Robin pinside to mark key posts. Just not have the time yet to go through all pages.
If you could PM the links I am more than happy to key them.
#1431 6 months ago
Quoted from Rensh:
Just keying any post with the link to the service FAQ would be great. Or just make a new post with the link. That doc is super helpful.
#1432 6 months ago
Chris
On mine with the front leg bolts all the way in and the back leg bolts almost all the way out I think it was about 6.7. I've since put the back legs at about the half way point and it seems to play a lot better. I don't know what it is now 6.2-6.3 maybe. Is it "correct" that way? Probably not, but it is the highest I can put it where I can backhand both Jesus and the Dude, and make it up the Walter ramp most of the time from the left flipper, with the flippers at default power.
#1433 6 months ago
Both of my rails came dented from the backbox. Is there an easier way to remove the rails than to stand over them for 2 hours with a hair drier? I didn’t realize that they were glued in… but after nearly 30 minutes with a hair drier I realize that they are REALLY glued in.
#1434 6 months ago
Quoted from Wulftown:
Done.
And happy to see the document is helping you. A lot of personal time-effort went into making it after all.
#1435 6 months ago
Quoted from NC_Pin:
Usually a rounded, plastic putty knife works though I haven't had to do it on TBL. Just work up carefully a small section at a time. The heat can soften the glue but I still find you need a putty knife to separate them. You often don't even need heat if you're careful just go easy on the decals where you'll be able to see them. Good luck!
#1436 6 months ago
Quoted from KSP1138:
I adjusted mine tonight and think it plays better at 6.2 versus 6.6.
I usually like a steeper pitch but 6.2 seems better on my TBL.
I can back hand the Jesus shot, but need to follow the instructions above to ensure it doesn’t brick out.
#1437 6 months ago
Quoted from mac2444:
Any chance you snapped a pic of that wedge installed in your machine? Would be helpful to see what you did.
If not, could you possible circle on the pic Rens provided to indicate where you installed it?
#1438 6 months ago
Quoted from per3per3:
Don't have a photo, sorry. It's just about a 1.5" piece of adhesive rubber I trimmed into a wedge. Stuck it on the back left side of the metal wall so any shots riding near the wall get pushed towards the hole that's over on the right. It's worked really well ever since.
#1439 6 months ago
I tried this based on your advice (I used some self adhesive dead drop foam) and it has been a big improvement. Thanks! Occasionally, a hard direct shot will end up in the shooter lane, but rejects are now pretty rare.
#1440 6 months ago
Any chance you were able to do it without removing the upper playfield? Perhaps with just removing the back panel? I had just removed and replaced the upper playfield to resolve another issue and don't really want to do it again
#1441 6 months ago
I hear you. Unfortunately, I think it would be extremely difficult to do without removing the upper playfield, especially since you’d probably want to experiment with placement while rolling the ball up the ramp. I used it as an excuse to clean and wax those areas, but too bad it’s kind of a PIA.
#1442 6 months ago
If you have a version with stepper motor connected to the MPF it’s really not a PIA. Think removing it is like a 15 minutes job. No horror stories there.
#1443 6 months ago
Thanks KSP and Cyber Ninja. This is good guidance. There is no way that I can hit Lebowski or Jesus backhand. I am a bit concerned however about the Maude loop through Donny and Donny Loop through Maude because the balls almost make SDTM at current incline. Less incline will likely bring the ball even close to SDTM.
I feel like there needs to be something in the manual that suggests -
"When setting up the machine, the following should or shouldn't be possible from regular shots through backhand and forehand" - Functional based abilities driving game setup.
I find that 6.5 is too vague and may provide outcomes that are undesirable.
Is anyone aware of a post around that?
#1444 6 months ago
Quoted from Rensh:
I would imagine replacing the screw which acts as a coilstop with a slightly longer one could do the trick.
Did you try to loosen the two nuts securing the upper part sticking in the ramp to the plunger to see if they have some play allowing the upper part to get a little higher?
Can also be that the ramp is installed a little to high. It has a holder stand at the back where it goes to the left. Check if that isn’t under stress .
Quoted from ezatnova:
See a few posts above. This happened to me the other night. It’s the two small screws and lock nuts that hold the curved diverter to the post, and you can find them just below the clear ramp piece.
Loosen them up a bit more, adjust the diverter so it’s in the correct position (it has wiggle movement when loose) then crank down on those lock nuts. Fixed it right up for me.
Thanks for both of these suggestions however still no luck even with a longer bolt at the coil stop, and messing with the diverter locknuts/ramp connection points. I also had a local tech look at it and we're thinking its actually the bracket below the playfield was manufactured just a little bit off, allowing the diverter to drop down and 'twist'. Sometimes I'm able to fix it to work during coil test, but then during play it drops with more force and twists under the ramp...
Think a new bracket here might work?
#1445 6 months ago
Quoted from ZedMcGlunk:
Think a new bracket here might work? [quoted image]
I think the bracket on the top side of playfield is adjustable?
#1446 6 months ago
I’ve owned a ton of pinball machines and have found having the right pitch is crucial. I have my TBL set now in the 6.2 range, which feels really good. I can backhand the Jesus shot (I find backhand rarely bounces out where the shot from the left flipper can bounce out. I need to adjust this as there are notes above on doing this). I can also backhand the dude shot and can even get it to the top when lock is lit. This also seems “safer” to me to backhand, as missing this shot with the right flipper seems to equal trouble for me.
I am absolutely loving the game, but also find it challenging and haven’t had very many good scoring games recently. Play better!!
#1447 6 months ago
Quoted from CyberNinja24:
Great advice thank you.
#1448 6 months ago
I think I've finally had enough airballs from the Jesus/Maude rubber post split that the spot light has finally quit on me. No more jiggling has got it working. Any pointers on fixing it or replacement parts? Could it be a loose wire at the light itself?
#1449 6 months ago
I assume you tried replacing the bulb? If so, I think the spotlight is a relatively standard part you can replace.
#1450 6 months ago
No I actually didn’t know it was replaceable. How does it work maybe it’s just a bad bulb I thought it was just an all in one integrated part that had to be replace.
Men
15,000 (OBO)
Greensboro, NC
Gweem's Mods
Sound/Speakers
$ 299.95
Pin Stadium Pinball Mods
Led
$ 22.50
Magazines/books
Pinball Magazine
Magazines/books
$ 44.50
The MOD Couple
Toys/Add-ons
$ 259.99
Toppers
$ 49.99
Toppers
16,000
This page was printed from https://pinside.com/pinball/forum/topic/a-lotta-ins-a-lotta-outs-tbl-maintenance-thread/page/29 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
