Quoted from per3per3:I had mentioned that I have a newer build, but my serial number is DP-01-00595. I will unfortunately disassemble the MPF and check the optos and their wiring more closely. I have already checked their alignment and they look perfectly centered and in position. I was wondering if perhaps something came loose on the PCB under the playfield which I'll only be able to see once the thing is removed.
The flat cable is firmly seated on both sides and I did reseat both sides but that didn't solve the issue.
I'll take pics of these components and provide via the support email if I'm still unable to solve the issue.
Attached is a picture where you can clearly see the opto pair. In this build the wires for the opto’s go below playfield and have a connector there.
I think in yours already they go to the MPF and from there inside the flatcable to the bottom. Otherwise you should see a green and blue wire running through the same hole as the flatcable.
