Thank you for your continued help, TomDK , Rensh and cpr9999 .
Quoted from TomDK:Maybe you should report this to your dealer and ask for a replacement or a visit of a technician.
This with the bowling area looks like a mechanical problem to me.
On the flipperfingers, switch the coil, check the mechanic, play around with the settings (for me setting to "STRONG" solved my problem).
I would ask the seller for help ! He is responsible, not only making some money on pushing boxes trough the states.
EDIT: On the video it seems like the ball is stuck in the mechanismen. The ball will not be pushed out, it just fells out when the little hook diapperas. Check mechanic !!
I have now requested a technician specially because I can't even lift the playfield anymore (EDIT- Not reliably but was able to finally get it to lock today). I've asked my dealer to schedule an appointment with someone soon after I receive the parts from DP. I believe the visit will be covered. A new machine doesn't appear to be a viable option. I'm told I would have to wait at the back of the pre-order line if I went that route and it took me almost 1.5 years since pre-ordering to receive the one I have. So I'm very apprehensive to do so.
Quoted from Rensh:Dear Timlah,
Sorry to read about your continuing new issues , you are one unlucky dude .
As follows:
Bowling up-down post
I am guessing the post is rubbing against the playfield causing friction causing it to only go down slowly. Would be good to see a video without a ball as the ball is blocking the view on this post. You can test it in the coil menu. You can 'bent' the coilmechanisme a little to 'free' this post. See attached picture circled to show what I mean. Move it manually by hand up-down to see if it runs freely. See also FAQ attached
I've consulted the FAQ but like I mentioned in test I see the coil pin moving up and down freely with or without the ball and always dropping to the same position. It is not rubbing or getting caught on the playfield whatsoever. I will also say that the coil pin has quite an amount of "give" though. It doesn't always go up in a perfectly straight direction but also I *never* see it get stuck or rubbing the PF. Also bending the bracket doesn't help.
EDIT: I was able to get the playfield up thankfully and took a closer look in test. I can get the issue to occur in test now. After close inspection to pictures in the FAQ vs my alley, it appears that the real cause is the level at which the bowling arm is mounted. It's mounted too low or has somehow "sunken" since I got the game. I can clearly tell that the plastic of the arm is below the threshold of the alley's circular cutout. Therefore, regardless if the coil pin is all the way down, the ball will rest within that circular cutout. I must have been getting lucky while it was working before, maybe the pin was going down just ever so low enough to encourage/lift the ball out of the hole. Maybe now it goes too far down. The stepper motor/arm bracket is tight and not sinking at all BTW.
How do I adjust the height of the arm plastic? I see mention of using a 2.5mm alan wrench to adjust the arm's inner screw but no matter what size I tried I could not get in there to loosen it. I also don't know if that screw will even allow the plastic to be lifted up/down at all or if it only allows L/R adjustment.
Here's a new video from a different angle:
Quoted from Rensh:Right flipper
Its correct that in solenoid test the hold coil is not activated. Programmer made a note to correct this bug in a next release. You can test it in regular gameplay. Just remove the glass, press flipperbutton and see if you can push down the flipper. Try this left and right to see if there is any difference.
Also its correct that the upper flipper is wired different. Your bottom flippers are wired correctly.
Normally I would say something is wrong in the hold part of the coil, eg coil needs to be replaced (a standard Pinball Life purchased part). What we just dont understand is your comment that it ONLY happens when a ball comes from the scoop. This makes it really puzzling.
Tomorrow an express shipment will come your way and a complete right flipper assy will be included. For now my advise would be to let it rest a few days till you get the shipment. Take a short TBL holiday, otherwise you will get only to much frustrated and loose the joy in playing.
Thank you for confirming the wiring is correct. As I mentioned in my post, I already tried manually making the flipper fail in this manner. It does not. ONLY when the ball is ejected from the scoop. If I hold the R flipper as the ball ejects, the hold is lost. During the loss of hold power I can manually move the flipper up and down with ease as I hold the flipper button. Release and press the button again and the flipper is back to life without any hold issue. Also only the right flipper has the issue. I can eject the ball from the scoop, hold the left flipper and try to push it down and it holds just fine. Also as I mentioned I have completely swapped the L&R coils, aka the L coil is now on the R flipper and the issue persists. So if it is something about the assembly, what else could it be besides the coil? I've already ruled out the coils themselves by swapping it out with the L one (specifically -- putting the L flipper's coil and coil stop on the R flipper and vice versa). I'm doubtful a new assembly is going to resolve the issue but I will try that when it arrives.
One other interesting thing I noticed is it seems like the strength setting for the scoop eject has no effect. I can put it all the way to the lowest or highest setting and to me the ball ejects at the same velocity. I'm mentioning this because back to my suspicion about voltage going to the scoop vs. the flipper when the issue occurs. I am apprehensive to use my multimeter with the machine on, especially with 48V enabled otherwise I may be able to get some readings. This will have to be done by the technician.
Rensh Can you please work with your technician to see about a possible voltage drop in this scoop eject vs. right flipper hold scenario? I wonder if this could be another PCB issue.
Here's an in depth, general all things flipper troubleshooting guide I found. Any of these issues ring a bell? https://pinside.com/pinball/forum/topic/jurassic-park-flipper-hold-issue#post-2150726
Thanks again for all your guys' help. I'm trying to remain as positive as possible it's just getting more difficult day to day.
