I have cleaned the playfield from the A-Go-Go and had the issue that a switch was giving a short at the nr 1 drum off player 1. After the help received here the problem was solved......But, then the right flipper is giving another issue. See the pictures attached.
Left picture is with the right flipper button pushed.
Right picture is with the left flipper button pushed.
I did replace the coil for a new(er) one and checked if it is working. No problem with the coil. Then the steel shaft ( do not know the name for this piece ) replaced but no improvement.
Does any one know about this problem or have had the same issue. What could it be. HELP...HELP
Thx , Hans
