Can capacitors fail intermittently over time? I've got an old Bally sound board on a Xenon I'm trying to get working. After messing with it for a while, and playing the game - I started to hear a couple sounds. Then, a few more, then - everything worked! ...and would continue to work as long as I played it. If I powered it off, it would revert to no sounds...or only a few repeated sounds.
So I'm guessing I need to replace all the old capacitors (and GPE has a kit). However, before I go through that effort, I'd like some confirmation that bad or failing capacitors could cause this behavior. Can they 'sometimes' work after warming up a while?
