Hi all,
I have a few issues remaining on my Gottlieb Fun Land.
Instead of listing them at once. I'd like to tackle them in order of importance (to me).
1st issue: when the spinners stop on 500 or 50 points, everything is good, however when it stops on 5 pts, the 1pt relay fires and the correct score is added but the 0-9 unit does not move, hence no bell is sounded. If any 1pt switch is activated, the 0-9 unit rotates and the bell is heard. If I manually close the 1pt relay, the 0-9 unit rotates and the bell is heard. I thought that maybe the 1pt relay if firing too quickly to close the switch that controls the 0-9 unit properly, but I cleaned and gapped that switch as closely as possible and it still doesn't work, not even once out of the five pulses.
any thoughts?
2nd issues has to do with 3 or 5 ball play, I'll get to that one later.
