I have a couple of insert bulbs that I noticed were burning out quickly and very bright. I checked the voltage last night on them and they are 12 volts +. Some of the other lamps are more like 4 volts. The two that are at 12 + volts are on the same column. Either they are incorrectly wired or I have a wire touching that circuit that shouldn't be.
Does the GI circuit run at 12 volts?
