When you have limited space - hanging from the ceiling doubles your pin capactiy
Seriously though - apparently the browser on my work laptop doesn't like the picture editing tools. Clicking the middle makes the whole photo disappear, so I'll be loading them then fixing them with my mobile. I saw it was upside down, but #Dadlife was calling and I had to run. Go figure - The four on this post are loading no problem.
Anyway... I tore down most of the playfield and did an initial clean to get most of the junk off. I found three separate mylar-like pieces of plastic glued to the playfield. It felt far too thick of mylar, but removed relatively cleanly using the freeze method (one in the upper arch mark, two covering the damaged bonus multiplier area). Unfortunately, the pop bumpers didn't fare as well, as there was a different glue used to adhere these. This felt far too thin and stretchy to be mylar, but was solid glued to the playfield. I used a hair dryer to get them up relatively easily - but unlike the cold freeze, the underneath paint suffered a bit.
I tried my initial clean with Novus 2 - but the field was far too dirty. I'm now a firm believer in ME and alcohol. I took a little paint off at the bottom unfortunately, but there was a solid line of gunk built up over the years on the apron that was stuck to the playfield. I'd best describe it as solid grease and it wasn't coming off with Novus, plastic razor, etc.
Next up - I'm going to pry up/tap out the wireforms (Got the nylon prys from Harbor Freight over the weekend) and give it a deep clean. The ME/91% cleaned it up well (The girl doesn't look like the robot gave her a shiner anymore), but I can still see a haze over large patches that needs a second go over, plus the dirt left behind around the pops that likely need another go of goo gone too. (Not to mention the areas around wire/switches once I drop those below the field) I'll look into sanding out the arch line and the shooter lane while I'm at it, then replace the bulbs and begin masking underneath. I also bought the stuff to build my rotisserie - so I'll be getting that together too.
One thing I wanted to ask (and admittedly, I just haven't done my research yet and may be jumping the gun on this question so far). What's the best way to tackle the star inserts before clearing? Pop the star completely? How do you mask it/keep it open without it?
