(Topic ID: 161885)
A bit disappointed with new plastics
By redundor
  • 23 posts
  • 13 Pinsiders participating
  • Latest reply 3 years ago by
#1 3 years ago
I got a set of new plastics for my demolition man from plantetary pinball to replace my beat up set, and I am wondering if I am being a bit to picky. Maybe I was expecting to much. My main complaint is that just like the original, the black keyline around the plastics isn't a consistent thickness. In various spots it isn't even left after being cut out. I has always assumed that the reason the older games were like this was because of the manufacturing limitations at the time they were made, and that new plastics would be properly centered to ensure that they look the best.
However, I bet there are people out there who value authenticity and would be unhappy with re-centered and cleaned up plastics since it isn't true to the original game.
Anyway, here is a scan showing what I mean
#2 3 years ago
Edit: never mind, misread post.
#3 3 years ago
#4 3 years ago
You have a valid point, but if Planetary used original films to reproduce them, well..............
It is kind of irksome, no doubt. But if that's all you can currently get, then i's better than broken or nothing, yes?
I don't think Rick would spend time or money modifying original films or scans to make plastics aesthetically perfect, and if he did that for one machine, he would most likely have to do that for all of them.
For those of us who have been in the hobby for awhile, I think I can safely say that authenticity/originality is still appreciated.
Greg
#5 3 years ago
Quoted from redundor:
Be happy that if it carries the PPS Williams hologram that it is anything close to the original.
#6 3 years ago
Quoted from o-din:
You'd think there would be standards.... nope.
#7 3 years ago
Quoted from lordloss:
And expecting improvements over original Williams parts is really asking a lot.
#8 3 years ago
Quoted from o-din:
Maybe not improvements, but getting the colours to match a bit closer to original would go a long way.
#9 3 years ago
Quoted from pinsanity:
Nah. You are supposed to change the whole set and then you won't notice.
#10 3 years ago
Quoted from o-din:
The perfect marketing strategy. Why let them spend only $15 when you can make them spend $159.
#11 3 years ago
Yes! And you also end up with the individual plastics you purchased before you figured that out..... as spares!
#12 3 years ago
Quoted from pinsanity:The perfect marketing strategy. Why let them spend only $15 when you can make them spend $159.
If I could have bought just the pieces I needed I would have, but I have enough with damage that it made sense to just get the whole set. And I must say, it can with a lot more pieces than I was expecting. Every single piece of flat plastic in the game was included including the clear ones, the ones that are installed vertically beneath the ramps and even the key fob! Even though I am not overly impressed by the alignment, overall it's definitely worth the asking price.
Quoted from swanng:
Greg
Yup, definitely better than broken/cracked/missing. I don't know what the original files look like, but I can't image that it would take all that much time to tweak them to align better. Do some test prints on paper showing the graphic and the cut lines and it should at least be better than it was.
#13 3 years ago
that's because they are interested in $$$$$$$ and sending warnings out rather than making reproduction parts 100%
#14 3 years ago
least you even have these options. Not so long ago, it was only A list games you could get anything for, and even then, most stuff wasn't available. The only way you got your game looking complete without broken stuff, was going to a lot of trade shows, and sifting through vendor tables looking for the pieces you needed.
#15 3 years ago
Quoted from CaptainNeo:only A list games you could get anything for
So much has changed.
#16 3 years ago
You'd be surprised how hard it is to get printed artwork to be cut accurately when it is a large sheet comprised of complex shapes, like a plastics set.
For my JP scoop light icon mod (www.loopcombo.com) I've spent lots of time and money doing R&D with various printing and cutting processes to get a good alignment of artwork and cutting.
Plastics artwork like DM that has a key line or a border really highlights any variation in thickness/distance from the edge. For my mod artwork I foolishly designed a circle inside a cut circle. SUPER easy to see any misalignment. Anything more than 1mm misalignment looks bad and I have to throw out the part. That I paid for printing, adhering to acrylic, shipping to laser cutter, cutting and shipping to me. For my first few suppliers my yield was below 50% which is terrible!
The main problem is that both wide format printing and laser cutting paths suffer from 'drift' across a large area. Which is when the proportions of printed/plotted data changes over the physical length of the job. So even if the laser cutter is 100% accurate and has no drift, if the wide format printer had even minute variation in feed speed throughout the job, some parts will be out of alignment to the cutting path when it gets laser cut.
The only way I've found to solve it is to find a supplier operating a modern high-end laser cutter that is less susceptible to drift, and is also willing to babysit the entire cutting job, adjusting the laser as the cutting job progresses to account for any drifting. It is expensive but I get probably 90% yield now.
TL:DR; Cutting large artwork is very hard to get right and misalignment is super noticeable. I've gone through many printing and laser cutting suppliers to get it right myself. Pinball plastics are historically horrendously misaligned so there's no incentive to go to the effort to make new ones that are cut better.
#17 3 years ago
Quoted from o-din:
Actually I did pickup the full set first off. Just making an observation on the colour distortion from original which were part of this complete repro set using a couple of examples from it.
It wouldn't bother me if they were $300 a set as long as they were accurate to original.
#19 3 years ago
Quoted from accidental:
I have actually done some plastics ad well for my x-men through a local print shop and they turned out really nice on the first try. I guess I got lucky, or the fact that they could print and cut in house meant that everything lined up properly.
#20 3 years ago
Your results might be different if they did a couple hundred sets. I guarantee they won't all be perfect.
#21 3 years ago
Those were made using my original films and using the original manufacturer who makes all the 90s plastics for Williams
Colours may vary when you have pms colours and 12 different colours and screens
You can't match 20 year old plastics colors, inks today don't have the cancer proven chemicals in them, pigments vary
Very hard.
#22 3 years ago
Quoted from Bryan_Kelly:
I like how CPR offers gold, silver, bronze gradings so you have some idea of what you're buying.
#23 3 years ago
Ballypinball is correct. The inks used for the original factory manufacturing run are not the same inks (for the most part) used today.
Besides, NO reproduction will be identical to an original.
Gweem's Mods
$ 159.99
$ 99.00
Pinball Sales
