Hi All-
Just got a Star Pool. I was told "works great". LOL! I discovered any time the 10 point relay is activated either by (2) kicker switches, spinner relay, and the 50 point relay. it stays pulled in and on. This also holds the medium chime coil on as well.(bad) The 10 point coil will also stay pulled when I just activate the relay in the backbox separately. When this is pulsed on and holds, it does not pulse the 10 point score reel on any of the 4 players for some reason. When it is open, I can get the chime to pulse and the pulse to the 100 point reel by jumping those contacts in the relay (when the 9th position switch on the 10 point drum unit is in que). However I can't get the 10 point score wheel relay to pulse by jumping the contacts
Also a similar issue happens when the spinner relay pulls in. It stays in. As an aside this relay pulses the 10 point as well causing the aforementioned issue too.
I have looked at everything closely and am stumped at the moment. I understand the pulse from the 10 point relay goes through the player unit. That seems to look OK. But we all know looks are deceiving!.
Any direction you folks can point me would help. I do have the schematics as well as the instruction manual.
