Quoted from HoakyPoaky:
Wow I would have never thought of using tape. If you say it works I will def try it. Sounds much easier than using aluminium sheets.
What about really small areas (like a half inch) where there is a small chip along an edge? Do you use the epoxy in such a small spot or do you use Bondo filler? I would think the bondo would be easier to manage & sand along an edge. The epoxy is just for larger areas like corners where more strength is needed right?
I'll almost done sanding the original paint so this is my next step, hopefully this weekend.
I use the fiberglass epoxy on pretty much everything. Occasionally I'll use some of this stuff, but it doesn't seem set up as hard as the epoxy. This filler I use mostly on flat areas to fill in wood grain areas.
Here are some shots of some of the smaller areas have done with the fiberglass epoxy
156417570052072741234 (resized).jpg15641757650971022651441 (resized).jpg1564175894917697694735 (resized).jpg
I have some hand sanding to do inside the cabinet that my sander won't get to but I'm about ready to start spraying primer maybe this weekend.
