Low compression is not so much of a issue anymore as long as detonation is kept in check. Its still better to run the highest compression you can with he lowest boost rather than high boost low compression.
The only reason i brought it up is stock ls1 are in the 13's. You have a stroked crank so i didnt know if you had dished pistons put in or if you raised the deck height.
Boost numbers are irrelevant to me. I love it when Honda guys talk about running 25psi blah blah in the their b18, well 25 psi out of a td05 can be achieved with 8psi with a gt35-40
I would have to research what brand of injector flowrate duty cycle and then see your tune to determine pwm cycles to say for sure how maxed that injector is. I am not doubting you. I dont think anyone is. Lot's of ways down the track so to speak different methods for different people.
Lots of it has to due with how much meth you are subbing for fuel as well. SO if your running direct injection meth at 200cc per chamber that makes up for lots of fuel.
Still kinda vague on what form of meth injection you are running or if its just something like a Snow kit spraying down the charge pipe.
So from your last statement i take it you didn't build it then rather take it to a power sports shop for the build correct?
I still think you are going to be better off sellign it first. There has been a slew of folks lately in the last month alone trying to trade cars for pins. It just makes more sense to sell it first. The Chance someone on here is going to say offer you a Theater of magic and 16 grand are very slim.
