Hello Everyone, my name is David Hoffman and I'm the owner/operator of NeoLoch, LLC.
I've just released a new product that many of you will find interesting, a simple easy to use RAM IC tester for the 5101 and 6264 RAM ICs. You can learn more about the tester at the following link:
http://www.neoloch.com/products/NLT-28P-12LED-5S.php
The simple design of this tester makes it a breeze to use. Just put in the IC, select what RAM type you're testing and press the the enter button. The tester will then display a series of red and green LEDs indicating if specific memory ranges are good or bad.
Once a test is complete, the ZIF socket is completely powered down for safe removal and insertion of additional ICs to be tested.
If you have any questions, I'm more than happy to answer them.
Thank you,
David
