(Topic ID: 214856)
50v Fuse
By ClintP
63 days ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 62 days ago by ClintP
One image has been uploaded to this topic. (View topic image gallery).
#1 63 days ago
Does the 50v fuse ever randomly blow or does it always point at an issue? I had it blow today while testing functionality on the machine. I have run many balls through the machine without blowing the fuse and after replacing it ran quite a few more through trying to reproduce the problem. It blew on an extra ball just when the ball went through the gate switch.
#2 63 days ago
#3 63 days ago
the filament breaking from vibration or jolting happens - usually at a cap where you can't see an issue.
if the filament vaporized, you have a problem.
the ball gate switch is NC and causes the lifter start relay to lose power when it opens.
the lifter start relay is on manual page … not. Typically, the LSR has three switches:
1] hold in switch to keep itself powered until the ball gate switch opens
2] switch in selector lock trip relay circuits
3] switch in ball lift motor circuit
if another ball wasn't enabled to raise, the most likely place to look is the [2] circuit. If the problem only happens when select before 5th is enabled, that's another clue and you'd want to check the plug connections for wires 98-4 and 23-8, trough switch #3 and the loose wires around the trough that go to meters that likely aren't in the game.
#4 62 days ago
I couldn't see the break in the fuse as it looked good visually but was open with a meter. I'll continue to watch for a repeat of the problem but hope it was just vibration and a coincidence that it seemed to happen when it went through the gate. I appreciate the help.
$ 48.00
$ 159.00
$ 99.99
Lighting - Other
$ 180.00
Pinball Customs
$ 99.99
$ 259.99
$ 5,699.00
Little Shop Of Games
$ 90.00
Lighting - Under Cabinet
Rock Custom Pinball
$ 239.00
$ 114.00
Lighting - Backbox
$ 48.00
$ 24.99
Lighting - Interactive
Lee's Parts
$ 12.95
$ 495.00
MI Pinball Refinery
$ 5,599.00
Operation Pinball
$ 4.95
Apparel - Unisex
$ 109.00
