Have you reseated the edge connector on the board or checked the ground wire on the micro switch is actually connecting to ground? Check the switch input wire from the switch to the board for continuity. There could be a bad connection somewhere. Some of those cheap wiring harnesses can be faulty. I found a bad ground wire when I built my 412 in 1.
