  • 6,582 posts
  • 437 Pinsiders participating
  • Latest reply 2 hours ago by jrcmlc
  • Topic is favorited by 497 Pinsiders
There are 6,582 posts in this topic. You are on page 24 of 132.
#1151 2 years ago
Hi
Does anyone have a template for pinball accents/custom lockdown bar art?
Similar to below for Stern and happy for it to be blank.
Cheers
#1152 2 years ago
Quoted from Deafman013:
Hi
Cheers[quoted image]
Not like that, but I did prototype a guns n roses lockdown bar art
lockdown_bar_button_guns-n-roses (resized).jpeglockdown_bar_button_guns-n-roses (resized).jpeg
#1153 2 years ago
Good afternoon everyone
Would anyone have designed an adapter plate for spike 2 4" (pro and premium) to 5.5" speaker (LE)?
These adapter plates are super expensive and I don't see why it could not be printed
Cheers
#1154 2 years ago
Quoted from Ashram56:
Cheers
Option 1: Purchase a speaker light kit and you can get a pair for $25 - http://www.speakerlightkits.com/5.25-SPIKE-2-Speaker-Plates.html
Option 2: Purchase a set alone for $50 (or for whatever price others are selling them for)
Option 3: 3D printed version - I'm not too sure about this. The plates are quite thin (maybe could be thicker) but my main concern are the welded posts that extend up on the inner side of them for mounting the speakers. I just don't know if a 3D printed part would have enough strength in these stress areas for the weight of the speaker, especially over time as the speaker panel gets opened and closed. Theoretically, the posts could be 3D printed, but they would snap like a dead tree branch with very little force. If you mounted metal studs, I still think they would snap the thin supporting plastic around them.
One of the axioms I've adopted over the few years I've been doing 3D design and printing is, "Just because you can, that doesn't mean you should." I'm afraid this may be one of those instances, but I'm always happy to be proven wrong. BTW, my other 3D printing axiom is, "Just because you can design it, that doesn't mean you can print it."
#1155 2 years ago
Thanks, but I'm a DIY kind of guy. Plus I live in Europe, so shipment and tax will put the whole kit way higher than what I'd like.
I also have access to metal part manufacturing if needs be, although if I can I'd prefer the 3d printing route. I'll see how I can design one for my purpose.
#1156 2 years ago
Yes, shipping can be a bear from US. 3D design for these would be pretty simple, but you would probably need a pattern for all of the holes (maybe the current ones you have will serve as a pattern and you just need to make the center hole larger.
#1158 2 years ago
Cheers
Just a little side note: I never really heard any improvement upgrading the backbox speakers to something like a two way (coaxial) speaker. Just guessing, some of the companies must really compress the audio (Stern, in my case). Not sure about the the higher freqs, but I just don't think there's much there for the tweeter to do any good. Did it for Aerosmith and AC/DC. Maybe a couple of others, but not sure. Granted, my ears pretty much suck above 10KHz.
I designed some for the Spike 2 and SAM pins, but the biggest bang for the audio was an external sub. Perhaps every pin is different, depending the quality of the sound track and the guy doing the audio tracks.
#1159 2 years ago
Not quite what you were looking for, but I made these for 4x6 sized replacements.
PXL_20210209_045831050 (resized).jpgPXL_20210209_045831050 (resized).jpgPXL_20210209_012833010 (resized).jpgPXL_20210209_012833010 (resized).jpgPXL_20210209_013139076 (resized).jpgPXL_20210209_013139076 (resized).jpg
#1160 2 years ago
Quoted from RobF:
Those are good and the reinforced mounting points should work quite well. If anyone replicates they just need to be aware of their speaker depth given the extra thickness (would hate to print and install everything only for the speaker panel to not close due to clearance issues).
BTW, how about a photo from the front with everything put back together?
#1161 2 years ago
Yeah, the offset was needed to give enough clearance for the extra driver. That will vary a bit speaker to speaker.
It's pretty boring from the front.
#1162 2 years ago
I pulled it apart since you were going to ask anyway . You can refrain from comment on my hobo captive nut workmanship thank you very much! Haha.
16361277095016137280468982565323 (resized).jpg16361277095016137280468982565323 (resized).jpg
What it would look like without the foam.
16361279535176399757111627752152 (resized).jpg16361279535176399757111627752152 (resized).jpg
#1163 2 years ago
Quoted from RobF:
That still looks pretty great!
I've never looked into it, but I'm curious - does the oval shaped speaker offer better performance than a round one? Or is it just form factor?
#1164 2 years ago
Quoted from RobF:
Paint those nuts black or 3D print a cap (maybe even go red to match your speaker coloring) and you're all set even w/o the foam insert. Well done.
BTW, since you mentioned it, I do notice the plastic stressing a little around the nut in your close-up (not really noticeable in your install pic). What infill did you use on the print? In Prusa Slicer (and I'm sure other slicers) you can add modifiers where you set a different percent infill. I do this on my mods that use screws where I may print the object at a lower infill, but have a fairly thick tube area around the screw holes and/or a block at the hole bases that are 100% infill.
Here is an example pre-sliced. The model is set at 25% infill but wherever the green blocks intersect will be printed at 100% infill (i.e. where my screw holes are).
Here is the sliced version below the bottom infill modifier where you can see the standard 25% infill.
Here is the sliced version at the modifier where the intersect area is 100% infill, but the rest of the model is still 25% infill.
#1165 2 years ago
Quoted from Rdoyle1978:
While not universal, in general round speakers of the same specifications and of similar size offer better quality, but on a pinball machine I doubt you can hear the difference even with a product like PinSound installed. I think the oval speakers were originally designed for depth limitations behind the backseat in cars, as you could install a speaker with a larger cone even if depth is limited by making it wider. Additionally, oval speakers give more area in the case of a 2-way or 3-way speaker to integrate all of the components, where it would take a much larger round speaker to fit the same elements inside of it.
When it comes to use in a pinball machine, I actually like the unique look of what RobF has done by going oval. The vertical mounting of them looks natural with the vertical rectangle speaker grill. He could have even gone a little larger, but I'm sure speaker depth was a consideration.
#1166 2 years ago
Quoted from mjenison:
Anyone have a design for a vertical up kicker?
I saw this one, which is supposed to be part of America's Most Haunted, but it's not in their open source 3D print download.
https://pinballmakers.com/wiki/index.php?title=File:3d-7.jpg
Bump..still interested in an upkicker model if someone has one.
#1167 2 years ago
It was form factor reasons. I was thinking the shape of the speaker grill allowed for more speaker drive area with oval speakers. I picked the cheapest ok speakers I could find and hedged a little smaller (4x6 vs. 5x10) to see how they actually fit. If I were to do it again, I probably would go round. I think they are sonically better. This was more a thought experiment. These are the ones I picked if anybody is curious; https://www.amazon.com/gp/product/B06XBFM6CW/ref=ppx_yo_dt_b_search_asin_title
Do you know which is the off the shelf equivalent for the Stern upgraded speakers?
Yeah thanks for the thoughts. These are all great techniques. I am familiar with them and how to apply them with PrusaSlicer. What you see was a first quick and dirty print just to see if I got the critical dimensions right. The captive nut holes came out a wee bit undersized and full of overhang garbage so the nuts didn't really fit well. I sort of cheesed the fit by hard pressing and overtorquing to draw the nut in as much as possible. That's why you see the stress and distortion. In the end, it all fit fine and aesthetically didn't look any worse with the foam in there, so I didn't bother redoing it. I didn't make to sell (or even to show?). This is what lazy functional 3d parts look like. I did ask you to ignore the hobo job, haha.
After seeing how they look without the foam, I might try to print some prettied up versions. Like you suggested I could print a cap or face plate to the hide the hardware. My preference would probably be to print a solid bottom, then space for the hex nut, pause print, drop in a nut and finish the print around it, making it completely captured. I also wonder what it would look like if I gave the base a pattern instead of a solid face.
#1168 2 years ago
Oh and I should also add, I have had pretty good results by increasing perimeters around screw holes as an alternative to adding a ton of fill. I think it could be a good tradeoff of reinforced strength versus excess print material and time.
#1169 2 years ago
Very interesting. I like the look too! Even despite upgrading the speakers and receivers, most of my machines don't exactly sound like audiophile stereos, so I doubt I'd notice.. lol
#1170 2 years ago
Quoted from RobF:
The increased perimeters technique is an option, and I've used it on a variety of models (I'm sure it may very well work on your speaker plates). However, the particular model I showed was more of an industrial application and partial fill and even additional perimeters just didn't provide the same strength as the solid fill. These particular items are designed to be secured around a bar, and before I went to solid fill in the stress areas I kept cracking them when trying to get them tight enough to remain in a fixed position on the poles they were mounted to.
#1171 2 years ago
Yeah I agree, always more that one way to print a cat. Specific tricks used are very design specific. Lots of good stuff shared here!
#1172 2 years ago
Quoted from RobF:
...Do you know which is the off the shelf equivalent for the Stern upgraded speakers?...
Head over to PartsExpress and look up a 4" mid/full range driver. 4" inch speaker link: https://www.parts-express.com/speaker-components/hi-fi-woofers-subwoofers-midranges-tweeters/midrange-midbass-drivers-full-range-speakers/nominaldiameter/4
They should have something that tickles your fancy. I bought some before, but I'd have to look it up. One thing you need to be aware of is quite often the 'front' of the replacement speaker protrudes out the front of the speaker frame and would hit the grill. I could have printed a spacer (which I have done)...but last time I just ordered some hex posts. Screwed those on the speaker grill frame screws, set the speaker on the posts, then secured the speaker w/screws into the hex post. Didn't bother about the seal between the front and back - it still sounded OK. But wouldn't take much to print a spacer if you want it sealed. But at least the screw now no longer needs to be mounted in the spacer since the hex post does that. The spacer is just that - a spacer, but it a heck of a lot easier to design if you don't need to add screws, just clearance for posts.
Something like this for the posts (not the right ones).
Sorry, I don't have all the part numbers in front of me, only have a few min to spare.
Added over 2 years ago:
Edit: Whatever speaker you get, double check the mounting holes to make sure they line up w/the original speaker.
#1174 2 years ago
#1175 2 years ago
Ben touting it for a couple of years, but my go to slicer is PrusaSlicer. I was a diehard Cura fan, but turned to PrusaSlicer when it was still Slic3r and haven't looked back or regretted it once. BTW, you don't have to be printing on a Prusa printer to utilize it.
https://www.prusa3d.com/prusaslicer
I'm trying this on the shop machine now, generated its first file and doing a 16 hour print.
#1176 2 years ago
I thought the upgraded LE speakers were 5 1/4" or something like that?
#1177 2 years ago
Quoted from RobF:
Oh, you're right RobF- sorry to the poster asking. I only had a few minutes to find the links and type a couple of comments before heading out and was thinking he wanted an upgrade to the standard speaker (same size). PartsExpress link is still useful tho, just need to look up the LE speaker style instead.
#1178 2 years ago
Hey all. I did a hard look thru thingiverse and came up empty. But I have a few things I need for a Shaq Attaq pinball.
I need the cam for the vari target unit.
I also need one of the gears for the basketball hoop motor.
And while I could probably buy something… need the speaker grill plate for the 8” speaking in the bottom cabinet.
Anything like that out there? I struggle to believe that vari target gear isn’t out there somewhere as it seems like an easy thing to scan and print.
Thx
#1179 2 years ago
Quoted from Pauz21:
Thx
Unless someone has the game I don't know how someone would even begin to help you, the gottlieb manuals aren't even available to reference what you're talking about because of IP. I've 3d modeled many parts from games because someone needed a replacement. Scanning a pinball part isn't the right way to go about it.
#1180 2 years ago
here is the vari-target diagram, you are missing the cam on the arm or yours is broken Pauz21 ? got a pic to show us what you have.
#1181 2 years ago
Quoted from BorgDog:
here is the vari-target diagram, you are missing the cam on the arm or yours is broken Pauz21 ? got a pic to show us what you have.[quoted image]
It’s part 11535 from that diagram. The arm is there. It’s the cam (protractor looking gear) that’s broken in half. That’s what I need.
#1182 2 years ago
Quoted from Pauz21:
#1183 2 years ago
If it’s true size (scale ) in the book scan it draw the lines in 2D and convert it to 3D set the sizes and print it
#1184 2 years ago
We have several of the vari-targets that we bought as samples and I would be happy to send you one. We had to manufacture our own using a neat downward gravity twist on the mech. We might sell them next year, since no one that we know is presently manufacturing them. They would replace any of the old ones. Just pm me on what you need. Happy to help.
#1185 2 years ago
Quoted from Pauz21:
I have a good ME work buddy that has a CNC machine in his garage. Not the kind that's a glorified toy...but the kind that takes up the entire 3rd bay in his 3 car garage (and costs a lot more than a car)! Just bought it new a couple of years ago.
If you ever get to the point of having a decent file that can used for 3D printing, I know he would be happy to CNC one at a very reasonable price. Doing little stuff like this keeps his skills up using the software, plus he just likes to tinker. Is this just a a flat piece?
If someone that has one that they could measure the hole(s) distance, maybe you could scale the drawing and redraw in CAD software. That would assume the drawing is to scale. Edit: Just noticed you have the part, it's just broken.
Another option might be to get a CNC-3018 for less than $200 and make one yourself out of aluminum?
#1186 2 years ago
With cad file could also use a service like sendcutsend to laser cut it for you. I just had some parts done by them, fast, clean and fairly cheap, and lots of materials to choose from.
#1187 2 years ago
this.. i have a waterjet vendor i use. that part wouldnt cost more than $15 if you made a few sparea. ive used oshcut.com which is cheaper but because they torch cut you might have to sand off some burn marks.
#1188 2 years ago
Wow, they even cut titanium!
#1189 2 years ago
Quoted from Pauz21:
I could draw it up, put you would have to send the broken parts to me.
PM if interested.
#1190 2 years ago
Anyone know someone who can make a small run (say 10-20) custom plastic ramps?
This is replacing a steel subway ramp with plastic one.
Thx
#1191 2 years ago
Quoted from Pauz21:
Is the original piece plastic?
#1192 2 years ago
Thx
For TBL? I would so ist but i'm to gar away.
#1193 2 years ago
Quoted from MightyGrave:
Never to far away
Looking for someone to make for the community.
#1194 2 years ago
First print with ABS and glass plate, ABS likes it hot! Love the flat surface.
255C and 105C settings. Lifted 15 minutes into program both times off the PIE surface. Flipped plate to textured side and didn't stick at all. Got a ball of plastic string for my trouble.
Going inside to watch Dune.
#1195 2 years ago
Did some reading, going to up the plate temp higher and cut the print speed in half to see if I get better adhesion. Do you recommend an enclosure for printing with ABS? My buddy swears by his.
#1196 2 years ago
Quoted from gdonovan:
It's pretty much required. The chamber also needs to be between 60-70C to prevent warping. Sometimes the bed is enough to heat up a chamber, sometimes you need to add heat.
#1197 2 years ago
This. Also make sure your print fan is off.
#1198 2 years ago
Quoted from RobF:
Print fan is off.
#1199 2 years ago
Made a chamber, still doing it. Current print temps are 250/105C. Moved head up, moved head down.
Only thing that seemed to help was abrading the PEI sheep with 600 grit wet/dry paper and recleaning with alcohol. On attempt #6.
#1200 2 years ago
yea always sand PEI following with alcohol whenever things stop sticking. I sometimes go down to 200 grit because 600 grit doesn't always have enough bite.
4,995 (OBO)
Dunakeszi
$ 69.00
Pinball Pimp
$ 35.00
UpKick Pinball
$ 53.99
Fort Lauderdale, FL
UpKick Pinball
$ 15.00
RobTune
$ 15.00
Pinball Haus
$ 35.99
$ 12.00
UpKick Pinball
$ 15.00
RobTune
Red Oak, TX
6,500
Orange, CA
$ 18.00
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/3d-printing-sharing-thread-lets-better-the-hobby/page/24 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
