2 years ago
  • 1,341 posts
  • 174 Pinsiders participating
  • Latest reply 7 hours ago by LateCenturyMods
  • Topic is favorited by 238 Pinsiders
    There are 1,341 posts in this topic. You are on page 22 of 27.
    #1051 56 days ago
    Quoted from swinks:
    Is this what you want - will hold 6 balls
    That would work well I believe.
    #1052 56 days ago
    Quoted from Kevin_LHeureux:
    I don't use thingiverse but keep all my models at Shapeways and a small range as a free download. Just register a Shapeways account and then use this link and you will see my range of free models. Only took a few minutes to print up - not to be on sold but print and enjoy for yourself or a mate.
    https://www.shapeways.com/marketplace?q=swinksdownload&sort=newest
    ignore the price that is if someone wants to buy one and that is mostly shapeways fee, it is a long part about 171mm long x 33mm wide x 20mm high. Share a picture if it worked for you.
    under the description is a Download Product - which allows you to download the STL file.
    #1053 56 days ago
    oops, double post!
    #1054 56 days ago
    Basically, yes. I started playing around in Tinkercad as well but for some reason I can’t find the void tool. Lol.
    Right in front of you!
    #1055 56 days ago
    I truly appreciate that swinks! I’ve been on Shapeways in the past and know their process. I will download and print for myself. Thank you again!
    #1056 56 days ago
    Right in front of you! [quoted image]
    I did use that and figured it was a void tool. Why call it a hole though? Dumb. Honestly, I played around with it for a few minutes I had available today.
    #1057 56 days ago
    made a simple subway for my homebrew.
    2 parts easily welded together with a 3d pen
    files available on thingiverse: https://www.thingiverse.com/thing:4983824
    If you need any other of my 3d printed parts from my homebrew just ask
    homebrew topic: https://pinside.com/pinball/forum/topic/stargateseries-homebrew-pnp-pinball
    2021-09-27 16.25.31 - Copy (resized).jpg2021-09-27 16.26.16 - Copy (resized).jpg
    #1058 56 days ago
    Has anyone made a simple ball holder that can be place on a flat surface to hold pinballs while you're working on it? Those things are like soap.
    I looked on Thingivierse but didn't see anything.
    Like this?
    https://pinside.com/pinball/forum/topic/ball-holders#post-3731175
    #1059 55 days ago
    Quoted from Rdoyle1978:
    Tantrum to the rescue! Not exactly what you’re looking for but it will definitely work
    https://www.thingiverse.com/thing:3269881
    Funny, I was about to post the link - thanks for doing it for me.
    I also like this: https://pinside.com/pinball/forum/topic/3d-printing-sharing-thread-lets-better-the-hobby/page/21#post-6537603
    Also, the post above is great.
    Post a question in the 3D thread, get a dozen different ways to solve your challenge.
    #1060 55 days ago
    This was what I came up with yesterday when I first looked at TC for a few minutes. From here I would add some inclusions to remove material between the round sections to remove unnecessary material. I am printing swinks model now and will share that here when done.
    #1061 55 days ago
    Quoted from swinks:
    Thank you swinks! Printed your model and it works great. I used PLA 10% infill, probably could've gone 0 infill to save some time. Took approx. 2hrs to print. So much better than using a rag! I'll stick some thin adhesive-backed foam on the bottom for placing on glass and likely try one in TPU next.
    #1062 55 days ago
    Suddenly having some weird lifting issues on my Prusa. Any suggestions? I do not print using an enclosure (that may need to change)
    I sanded the factory plate with 220 to scratch it up in a circular motion. Never had a single adhesion issue since, the slightly rough texture helps hold the filament.
    #1063 55 days ago
    great to hear, thanks for sharing
    #1064 55 days ago
    Are you not removing the glass when taking the balls out?
    I also printed it, I taped mine to the coinbox, need to print them now in Silver for a better match. Maybe tape it to the inside of the coindoor.
    #1065 55 days ago
    Quoted from PeterG:
    I also printed it, I taped mine to the coinbox, need to print them now in Silver for a better match. Maybe tape it to the inside of the coindoor. [quoted image]
    awesome good to see it is being used, great idea to put on the coin box
    #1066 55 days ago
    Woot!
    #1067 55 days ago
    Quoted from gdonovan:
    Woot!
    Now get ready for a long learning process! Nothing by itself is hard, but just a million settings that any single one can cause issues, LOL. But it's a fun hobby. Frustrating at times tho. You'll get the hang of it, plus a lot of experience in this thread for help if needed.
    #1068 54 days ago
    Don't be discouraged about the long learning process either. My first benchy right out of the box printed wonderfully. I'm still learning tips and tricks all the time but you can get good prints right out of the box too!
    #1069 54 days ago
    Quoted from PeterG:
    If I ever figure out a way to remove the balls without removing the glass I’ll let you know. I usually place the balls on the game next to it or a countertop. I just ordered a roll of TPU to test a print as well which will keep it from sliding on surfaces.
    I like your idea of placing it on the coin box as well.
    #1070 54 days ago
    Just an opinion but for this application TPU would be way overkill and tough to print with the model printer you posted. TPU really needs a dual drive feed system and enclosure to pull off decent parts. For a simple ball holder a cheap PLA would be the way to go as it doesn't need to be flexible.
    #1071 54 days ago
    I would just add a small lip to the base of that holder so it tucks under the lockbar.
    #1072 54 days ago
    Quoted from Yelobird:
    Thanks Yelo. Lot's of people print just fine with TPU on the Vyper. I've seen many posts on the Vyper groups about it. I'll give it a shot and see.
    Quoted from mattosborn:
    Good idea
    #1073 52 days ago
    Needed a flash bulb holder for my Monday Night Football. Just gonna bend the leads to make contract.
    https://www.thingiverse.com/thing:5009241
    5A51AF97-990A-4628-AC69-BA3D1470A5D6 (resized).jpegBBB77597-6205-4CBB-9031-EE832F1BD88E (resized).jpeg
    #1074 52 days ago
    I have an Ender 3 Pro and my hot end was failing and leaking. I have purchased an E3D V6 hot end and will be installing it with a Klemco bracket. All the pictures I see show it mounted with 2 50 X 15 fans, one on each side. The V6 comes with a fan mounted on a shroud installed on the heat sink. I'm currently only printing with PLA. Is this adequate for PLA or should I be upgrading to the larger fans on each side?
    #1075 51 days ago
    I have remixed the Williams Pinball Opto Interrupter file in Thingiverse https://www.thingiverse.com/thing:2597274 to work with the Judge Dredd left side flipper opto. https://www.thingiverse.com/thing:5013982/files
    #1076 45 days ago
    Well as I’ve been working on pins since I bought my first High Speed in high school 1989 it’s always been a pain dropping balls off lockbars. You tell the, to stay but they don’t always listen. I’d like to have a reasonable solution. Thinking of using TPU would be the way to go on this as well.
    Ahh, OK. Looking at your other posts, you needed a place to rest the balls on the pin after taking the glass off, but putting the lock bar in place?
    #1077 43 days ago
    In case anyone is interested I printed one out with flexible TPU and it is the way to go. Really nice and rigid but with some malleability and will not scratch anything around it or break if it fell. I used a Vyper members Prusa TPU profile but still need to play around with retraction to make it flawless. Really though its a functional part so it is great as-is.
    I printed some TPU glass protectors which also turned out great. I highly recommend printing both for your toolbox.
    #1078 43 days ago
    Anyone have a file for a clear nut for stern flipper buttons? I see one on thingiverse for a gottlieb, but not sure it will work. The metal one blocks too much light for lighted flipper buttons.
    #1079 42 days ago
    Quoted from Lermods:
    Please PM me to discuss.
    #1080 42 days ago
    Not putting the bar back on. Simply placing the ball holder on the game next to it for safe storage while working.
    #1081 42 days ago
    I have one here that I've used with stern buttons from pinball life: https://www.thingiverse.com/thing:3715237/files. All the flipper buttons use the same nut.
    #1082 42 days ago
    Thx, mr. tantrum helped me out.
    Quoted from latenite04:
    #1083 42 days ago
    Quoted from epeabs:
    The fan that comes with the hot end is only to cool the heatsink to prevent heat creep past the heatbreak. You'll still need a part cooling fan, especially with PLA. Bridges and such will be lousy without one.
    #1084 39 days ago
    Score motor coupler for Midway rifle games
    https://www.thingiverse.com/thing:5028646
    #1085 37 days ago
    First print, any suggestions?
    20211025_182131 (resized).jpg20211025_182142 (resized).jpg20211025_183813 (resized).jpg
    #1086 37 days ago
    Measure it with a calipers, make sure what you're printing is accurate.
    #1087 37 days ago
    What are you concerned about specifically? Is there a little lifting on the corners (not sure)? Or are you a little worried about this area being a little rough?
    Looks pretty good for a first print.
    #1088 37 days ago
    I have upgraded my Ender Pro with a new E3D V6 hotend since the original hotend started leaking. I've had a couple decent prints, but still seem to be having possibly an extruder issue. I had upgraded to the aluminum extruder early on and really didn't have any issues. My extruder now sometimes seems to be either not catching up with the hotend or is over supplying the hotend. It seems sometimes to "kick back" while extruding. Any thoughts? When I checked on the print that the two photos are of, the machine was still "printing" a bit above the surface, but not adhering and balling up. I am thinking this is more of an extruder issue?
    #1089 37 days ago
    Quoted from epeabs:
    I wonder if the new hot end actually runs a bit cooler than your old one. If so, try upping the temperature in 5 degree steps to see if you get improvement.
    I would also say try checking for clogs, but it’s a new nozzle isn’t it?
    #1091 37 days ago
    Quoted from Nokoro:
    Brand new genuine hotend. I will try that. It can't hurt. I had no issues so to speak with the stock hotend until it started leaking. I may also need to change "parameters" with the new hot end. I am printing items on my card that were printing fine with the stock hotend. Thanks Mark
    #1092 37 days ago
    Probably a high six figure printer required to produce those, but they are cool.
    #1093 37 days ago
    Quoted from epeabs:
    Sure sounds like it's plugged up. What type of filament are your running and have been swapping types? Is the fan on the heat break running as expected? There are specific assembly instructions to make sure the nozzle seats correctly. Did you have any trouble there?
    #1094 37 days ago
    Quoted from epeabs:
    Did you tune your PID? https://3dprintbeginner.com/hotend-and-heatbed-pid-tuning/
    #1095 37 days ago
    Just surprised that area was a little rough.
    Thank you, its gratifying to see something you drew on the screen come to life even if it is a simple box in a box.
    #1096 37 days ago
    Had not thought of that, will do. Not that it matters for this particular part but could for others I'm brewing in my head.
    #1097 37 days ago
    Checked, pretty much spot on.
    #1098 36 days ago
    Making a cat and replacement plastic for my Batman 66. First pieces printed this morning. Lots of work to do but so far I like it.
    #1099 36 days ago
    It does look like those flange areas lifted a bit, and that will cause the rough top surface. What does your first layer look like? The bottom of your print should be smooth, with all the little strings stuck together into one sheet, but not squished so much that the separate lines are crowded and wavy. Get that first layer dialed in, and I bet the top surface will look better.
    Of course, if your first layer is already good, you might have a bed adhesion issue. I'm assuming you're using PLA filament?
    #1100 36 days ago
    Quoted from RobF:
    I don't believe it is plugged up. I'm running Hatchbox PLA which I've had very good luck with. The fan on the heat sink is working just fine. I did the proper set up with the hot end by heating prior to tightening, etc.
    I will check out this guide for tuning. I know I did not update any software on my Ender after installation
