First, even with the power switch off, assume there is 120 vac on this board so unplug the game from the wall before working on it. I’m guessing your transformer is fine. Try unpluging the big connector (J3) on the rectifier board. If the fuse blows, you most likely have a shorted diode at CR1, CR2,CR3 or CR4.
