To Add: Are the displays supposed to be help up with an adhesive like tape? One of ours is slouching a bit. Thanks!
I bet if you look at your power board, the top right connector is probably burnt. (Cant remember what number it is). Redo the connector. I think its 9 pin idc.
Quoted from amkoepfer:
Ah, it doesn't appear burnt but it is unplugged, should I just plug it in?
Im at work so i cant get you a pic right now, but it should have a key in it so it should only go one way. Check the g.i. fuses too if that doesnt fix it, if those blow, you probably have a short
Awesome, thanks a bunch. I don't think this connector has a key, I'm afraid I'll get it wrong haha. Thanks again man
No problem. I can take a look in the morning and tell you which way it goes
Thanks you so much, man
Theres a pic. Please ignore my burnt connector. I just bought one to replace it and havent done it yet
Great! Thanks a bunch
