Quoted from Pin-it:I also have a 2 chute coin door w/ red wire ,just checked it too and it looks like the factory tucked it in to the cloth loom and not connected to anything. #3 chute seems to be the consensus.
Quoted from Mk1Mod0:Affirmative.
Great, Thanks Guys. Red wire with mine has been disconnected as well and yellow wire reconnected to the correct lug on the coin switch.
Unfortuantly the machine will still not start puching the credit (start) button, I have to hit the Reset Relay to start a game.
This game has had more problems popping up even after a full shopout then any other Mulitplayer I have worked on before, which to say is not making me merry before Christmas.
So fixed the coin door deal, then a wire broke off the Score Motor mid way down in the middle stack so I had to take that apart and solder it.
A Kickout Hole switch was jammed closed because a looped wire got in the way and I did not see that right off so that was not fun as it seems like something is always in the way of something else as there is just too much stuff crammed together under the Playfield. Even changing a light bulb is a PITA.
Had to flip flop the right flipper wires as 2 were soldered backwards.. my fault there but both Flippers work fine now.
I still seem to have a short somewhere. The Playfield right pop bumper does not work neither do the spinners or the kickout holes. Rollovers work and stand up targets so the mystery continues.
Well tomorrow is another day to try again.................Not sure now if this will be up and running for Christmas as the clock is ticking down fast.
Ken
