The circuit that powers just the Hole Eject Solenoid is highlighted in red below.
Both the Outhole Kicker Solenoid (which pushes the ball out to the shooter lane to start the game) and the Hole Eject Solenoid (which is the one you are talking about) use the same Motor switch 7B to fire.
If the ball is pushed into the shooter lane to start the game, then the Motor switch 7B is probably working. You only have one switch on the Hole Relay and the Hole Eject Solenoid itself (and the wiring connecting them) to check.
If your Hole Relay switch isn't closing, you might have to work backwards and figure out why that is....is the Hole Relay energizing when the ball sits in the hole? If not, why not? If so, then is something wrong with just that particular switch on the Hole Relay?
