Quoted from sublime90803:Can anyone with a premium tell me if their apron lights up? It appears there is wire going under there with an led, but I've never seen them come on.
Yes they do, both sides.
Quoted from sublime90803:Are the apron lights on all the time, or are they tied to a certain mode I haven't seen?
They seem to be tied in with the GI and on all the time
Quoted from HarrieD:Why didn’t you remove those fugly washers?
Not sure really, maybe just left it for the added barrier of protection.........
Quoted from DeathHimself:Here are a few shots of the Little Shop of Games protectors on the premium leaving all of the original hardware installed as well
Thanks very much for doing that. You're a great photographer! Answered my questions. On order
Quoted from DeathHimself:Not sure really, maybe just left it for the added barrier of protection.........
Yeah, just protect them protectors.....
Quoted from lschmidlin:Thanks very much for doing that. You're a great photographer! Answered my questions. On order
Ordered as well.....
Quoted from DeathHimself:cottonm4: Did you grab a Premium?
Well, I lied. I did not buy a Premium.
Someone was tired of their LE so I snapped it up. My neighbor is at work and i need help to unload. Plus it has been raining while I was away and today it is overcast with light sprinkles. The rain could let loose anytime. Hoping the sun shines tomorrow.
And, yes, this is my first "new" pin. I'm sure I will have some questions once I get up and running.
Here is a peek.
Quoted from jfh:As others have said this is old news. And a big fat fail as you say.
There is another option to consider if you can’t get to the switch — plug the game into a Wemo or Alexa outlet and control the power with your phone/voice. I do something similar with all my pins (I use Control4 which is overkill if that’s all you’re going to do).
Quoted from JMCFAN:$12 easy fix...
https://www.amazon.com/Wireless-Fosmon-Electrical-Weatherproof-Included/dp/B072F9DGRL/ref=sr_1_6
OK. I'll have to go this route. I don't know anything about remotes. Looks like I'm going to learn. Something else to buy. And a remote control to lose
Quoted from cottonm4:Well, I lied. I did not buy a Premium.
Here is a peek.
Wow an LE, very nice brother!
You are going to love it Cotton.
Quoted from cottonm4:amazon.com link »
Yes... Remotes can be intimidating.
Here is a peek.
Dude good move perfect time to buy
Here is a peek.
Congratulations and welcome to the club!
Here is a peek.
Congrats!!! while the premium is gorgeous, I have zero regrets, and personally prefer the LE. Find myself just staring at it sometimes...looks that good to me....
Quoted from cottonm4:OK. I'll have to go this route. I don't know anything about remotes. Looks like I'm going to learn. Something else to buy. And a remote control to lose
I didn’t go the remote route because it’s one more thing to lose. I always have my phone or voice with me though ...
But a remote is better than nothing.
Well Stern sent me a Herman replacement plastic very quickly, and I just installed the last of the nine piece green plastic protector set. Thank you very much to Death Himself who talked me through the process over two days! They are all installed correctly, however I broke my Herman spotlight and have to order one from Stern now.
Quoted from kcZ:Yes... Remotes can be intimidating.
I also use Alexa Smart Plugs to turn on and off all my game room equipment. Works great.
Quoted from jfh:I didn’t go the remote route because it’s one more thing to lose. I always have my phone or voice with me though ...
Quoted from GamerRick:I also use Alexa Smart Plugs to turn on and off all my game room equipment. Works great.
I'm guessing to use these Alexa plugs I have to buy an Amazon Alexa? Correct?
K.I.S.S Engineering
https://en.wikipedia.org/wiki/KISS_principle
"The principle is best exemplified by the story of Johnson handing a team of design engineers a handful of tools, with the challenge that the jet aircraft they were designing must be repairable by an average mechanic in the field under combat conditions with only these tools. "
The engineering that replaced a nice solid lockdown bar with a couple spring straps I would call cost cutting engineering. Instead of a Cadillac you now have a Yugo. It works but it could be better; Be more robust.
This switch being moved to an inaccessible location, ostensibly to cut costs, is something I would qualify as stick-it-to-your-customer type engineering. The equivalent would be to remove the starter from your car and replace it with a Model T hand crank. It is a step backwards.
Don't get me wrong. I am going to enjoy this game. I'm not sorry I bought it, but this unnecessary switch movement business pisses me off.
Quoted from cottonm4:I'm guessing to use these Alexa plugs I have to buy an Amazon Alexa? Correct?
K.I.S.S Engineering
Model Ts had an electric starter beginning in 1919. They tried to improve and add features over time until the last one rolled off the line in 1927.
But I digress.
Yes. But you can get an Echo Dot for like 20 bucks works the same it’s all Alexa
K.I.S.S Engineering
So.... all ya do is .....
Buy a smartplug.
Plug it in to power point.
Install some phone app ?
Connect to Wifi.
Use phone app to turn game one.
Rinse, repeat for each machine?
If all above is correct, can you also name/ label each machine in the app ?
And, you don't need Google Home at all up to that point BUT if you do Google Home and run Alexa you can then further add voice command...." Alexa , turn on Munsters" as an example?
Or am I dreaming?
Quoted from Wotto:GamerRick
Buy a smartplug.
Connect to Wifi.
Or am I dreaming?
You are not dreaming. I have 15 pins all on Wemo switches (I chose Wemo because it works with both Alexa and my iPhone homekit which allows me more flexibility for the future if necessary, but I digress). Each smart switch is labeled with the pin name.
Anyway, I can walk into my gameroom and say "Alexa turn on Munsters"... or "Alexa, let's play pinball"... for the latter, Alexa runs through a routine I setup that turns each switch on individually (so as not to overload the circuits by turning them all on at once). When I chose the routine to turn on all pinball, alexa announces the name of each game, sometimes with a commentary. Like, when she turns on Gorgar, she says "and now for one of my personal favorites, Gorgar". I haven't yet, but I can setup routines to say "Alexa, turn on my 3 favorite pins" and have her turn on just those. Or, "Alexa, turn on the 90's pins"... the possibilities are endless.
If you're a trekkie, you can actually put the Echo dot into a simulated star trek Enterprise computer mockup and change the wake word for Alexa to "Computer"... then you can say "Computer, prepare for warp speed!!"
Total cost for all of this was about the same as one colordmd, but can be done a bit cheaper if you choose some of the cheap switches on Amazon that only work with alexa.
K.I.S.S Engineering
I dont know why but i love the lockdown bars now compared to the older games. Im kinda weird though sometimes.
Quoted from Who-Dey:I dont know why but i love the lockdown bars now compared to the older games. Im kinda weird though sometimes.
It’s honestly weird if you prefer the old style. The current design is SO much better. So much more secure, and I don’t know how it would ever break. And if it did, the fix is super cheap.
Quoted from chuckwurt:It’s honestly weird if you prefer the old style. The current design is SO much better. So much more secure, and I don’t know how it would ever break. And if it did, the fix is super cheap.
I actually like the old style as well, but in use, the new one is fine.....
zero issues for me w power switch location on Spike games. Engineering change put the power supply in the backbox, not cabinet bottom. Extremely accessible now from a service standpoint..no biggie. Still enjoy flipping the switch to turn my games on and off analog.
Used to laugh when people talked to Siri on their phone and actually thought they were talking directly to their device. No thanks. My info is shared enough w my phone and computer, I choose to keep my house activities out of it.
Quoted from ramegoom:Added a Munsters Premium to my lineup tonight.
Side drains are about to get modded. They are embarrassing. Looks like a simple, but fun game. We shall see...
Your floor is amazing. Haha
Quoted from Pinzap:You are not dreaming. I have 15 pins all on Wemo switches (I chose Wemo because it works with both Alexa and my iPhone homekit which allows me more flexibility for the future if necessary, but I digress). Each smart switch is labeled with the pin name.
Many thanks for explanation of all that
Buy a smartplug.
Connect to Wifi.
Or am I dreaming?
If you use Alexa, you need the app at least one Alexa device then your name your device and it will be controlled by the name you give it by voice commands. You can also set up a group, and have multiple things turned on at the same time.
Not to derail the Alexia conversation lol, I wonder if putting a 1/2" by 1.5" long strip of the softer side of Velcro around the top curve of the extra time ramp in the lower PF, will it slow it down enough to register most of the times.
Buy a smartplug.
Connect to Wifi.
Or am I dreaming?
I don’t think I was clear enough on your question. You don’t need Google to do it. Google is just an alternative home control system. You can use either, I like Alexa. So all you need is a single Alexa device, one Alexa smart plug for each device you want to control, and then you just find the plug on your Wi-Fi and name it and if you want you can set up a group to control more than one thing at the same time it’s all pretty straightforward. I have one command to turn on all my game room equipment, my lights, and my game room sign. But that’s just the group command, you can also control each item individually as long as you give different names.
Here is a peek.
It is raining again, today. I'd like to be able to unload and set up before the excitement wears off
Weather forecast is as follows
Friday: Rain
SAt: Sunny
Sun: partially cloudy
Mon: Rain
Tues: Rain
Wed: Rain
Looks like Saturday might be my only chance.
Quoted from cottonm4:It is raining again, today. I'd like to be able to unload and set up before the excitement wears off
Friday: Rain
SAt: Sunny
Mon: Rain
Tues: Rain
Wed: Rain
Put a blanket on that beast
Quoted from cottonm4:I'd like to be able to unload and set up before the excitement wears off
You could always wait until the new code drops
Quoted from Spacemanratso09:Put a blanket on that beast
exactly, or a cheap painters plastic tarp and move it in.
Quoted from DeathHimself:You could always wait until the new code drops
Yeah... It won't melt. Despite what that other thread says... It's not made of shit.
Quoted from kcZ:Despite what that other thread says... It's not made of shit.
Exactly, only the code is made of shit, not the actual game.
Quoted from Who-Dey:Exactly, only the code is made of shit, not the actual game.
LoL.. You must have read that other thread. I made the mistake of posting in it, only to realize that was not a constructive thread.
Quoted from kcZ:only to realize that was not a constructive thread
Well if Stern did indeed tell Dwight to revisit and rework the code, then it was constructive....by accident lol.
Quoted from kcZ:LoL.. You must have read that other thread. I made the mistake of posting in it, only to realize that was not a constructive thread.
Yeah thats what i was talking about, all the haters over there. I played a few games last nite and had a great time, bad code and all.
Quoted from DeathHimself:Well if Stern did indeed tell Dwight to revisit and rework the code, then it was constructive....by accident lol.
We will probably get some more i have a feeling. I still love the game the way it is now but a little more would be the icing on the cake. Then ALL of the haters would if course rush out and buy this game.......yeah right!
Feels good after a day of fighting granpa's lab to hit 2 or more shots let alone the mystery. Then coming back and blowing up the lab collecting the super jackpot.. plus the zap and mystery jackpots. Gotta get all them granpa shots guys.
I'm sure most of you have had the issue with the Static Electricity and lower playfield attracting dust like a magnet.
A few post back I recall reading more details about this but haven't seen anything about it lately. Nor have I seen
anything on Stern's website about it.
Anyone have any ideas? How to cure this.
Quoted from Who-Dey:We will probably get some more i have a feeling. I still love the game the way it is now but a little more would be the icing on the cake. Then ALL of the haters would if course rush out and buy this game.......yeah right!
Haters gonna hate, is what it is.....thing could make $1 bills, and someone would complain "why aren't they $5's?"
Has never had an effect on how I choose my games....last time I checked, it's me buying for me. If someone wants to contribute, then maybe I'd pay more attention.
Both hate and fanboy threads are fun (sometimes), until they start attacking "people" for liking a game they don't ("poor player", "must be rich", etc.). That's when it gets a bit irritating, but whatever.....
Quoted from TechnicalSteam:I'm sure most of you have had the issue with the Static Electricity and lower playfield attracting dust like a magnet.
I took off the plastic cover last week and cleaned the lower playfield, so far the dust hasn't come back.
Quoted from MK6PIN:("poor player", "must be rich", etc.).
That and "you guys just keep on buying this crap that they keep putting out there. They wont stop making shitty games as long as everyone keeps buying them" "You guys are ruining the hobby"
Quoted from Who-Dey:That and "you guys just keep on buying this crap that they keep putting out there. They wont stop making shitty games as long as everyone keeps buying them" "You guys are ruining the hobby"
Forgot those...hmmm..Getting inspired to start a new thread..
Quoted from Redfield0009:I took off the plastic cover last week and cleaned the lower playfield, so far the dust hasn't come back.
Doing the same as soon as my protectors show up... going in once.... lol
This page was printed from https://pinside.com/pinball/forum/topic/1313-mockingbird-lane-munsters-club/page/71 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
