Noticed the sling plastics are different on the premium/le from the pro. Also looks like more lightning in the return lanes on the le.
Quoted from MK6PIN:The game has a lot going for it!!!
Will now rest and then play for a bit...Initial take... couldn't be happier!!
Beautiful game MK and it looks great by that Munsters clock!
Quoted from Puffdanny:Exactly my sediments Big D right about 100 games....
Sediments?
Quoted from Who-Dey:Beautiful game MK and it looks great by that Munsters clock!
And under the stairs...
Quoted from bigd1979:Noticed the sling plastics are different on the premium/le from the pro. Also looks like more lightning in the return lanes on the le.
Those sling plastics with Lily and Herman look spectacular from what i can see on the LE/Premium. Can you get some close up pics? Going to be another month or so until they arrive in Australia.
Hey Who-Dey picking up now from the fed ex plant
You said I am gonna shit when I get this thing so I wore my brown dickies to work today haha
Quoted from DylanFan71:Had to refuse mine.
Fork right through the cardboard and scraped the plywood and part of the decal.
Oh, that sucks....you wait and wait and then this happens. Good luck on getting a replacement soon.
Quoted from bigd1979:Agreed 7.2 seems like a good setting from my experience. I love the lighting effects and i play in darkness... sometimes its really difficult to see anything during certain modes but it makes things very interesting lol.
Yeah there are several times where you really can't see the playfield during certain modes. Spot and Dragula kickout are especially dark, I pretty well have to play it with a light on in pin room.
@ Thunderbird: Grandpa’s lower pf Lab is nice in the photos and stunning in person.
The lighting is perfect and the art is spot on.
It’s very multi-dimensional and adds a truly layered look to the game.
Quoted from Ven:Yeah there are several times where you really can't see the playfield during certain modes. Spot and Dragula kickout are especially dark, I pretty well have to play it with a light on in pin room.
Dragula isnt to bad as the lights are usually back on by time it reaches the right orbit... spot is a fun mode but difficult to c at some points for sure
Really like the clock on the wall next to the machine, looks great MK6PIN. My clock and lamp should arrive tomorrow hopefuĺly. Congrats, looks great!
Quoted from JMK:Congrats Spaceman!
Thank you!
Quoted from Who-Dey:Are you going to be able to set it up tonight Spaceman?
Gonna try
I have never followed a new pin thread closely, was never interested in getting one so please excuse me for my ignorance. I know it is normally Pro them premium and LE. I have not read every single post about Munsters but have read a LOT of them. I have not seen one premium delivered or seen any timeline on them. are they going to be produced after the LE? I am only asking because I am interested in a premium but would at least like to see some reviews in peoples house (or better play one on location). anyone have any information on this?
Quoted from Paul1478:I know it is normally Pro them premium and LE.
Actually, from what I've seen it's Pro, LE, then the Premium bringing up the rear.
Quoted from MK6PIN:More
[quoted image][quoted image][quoted image][quoted image][quoted image]
MK6PIN. Can you tell me how wo get playfied to the vertical position.... my 1st Pin...and I am nervous....
They do a small overseas run of pros. Then a small domestic pro run for stern army/locations with the few extras going to homes. Then 50-80 domestic le are ran and then the overseas le are ran. Then back to the rest of the domestic le . Finally the premiums are made. They are running a few weeks behind bc of whatever the delay was at the factory.
Quoted from JMCFAN:MK6PIN. Can you tell me how wo get playfied to the vertical position.... my 1st Pin...and I am nervous....
Hi JMCFAN, I hear ya, don't want to hurt anything. Remove the glass, then raise the playfield up and out slightly and rest it on the support rails and the upper area of where the lockdown bar would be. Remove all the balls by manually kicking them out using the upkicker plunger. Once all the balls are removed you can then lift the playfield up slightly and then slide it out until it contacts the stops. Then raise the playfield to vertical keeping watch at rear support rail area (left and right) within the cabinet to make sure the playfield stays against the stops so that when you raise it all the way you can rest it against the back box and it will then be slightly past its pivot center line, that will prevent the playfield from falling back down unexpectedly.
I do not own an LE, so not sure about the lower playfield balls, they might have to be removed as well to prevent them from escaping and damaging anything. Hope this helps you out.
Quoted from 1956PINHEAD:Hi JMCFAN, I hear ya, don't want to hurt anything. Remove the glass, then raise the playfield up and out slightly and rest it on the support rails and the upper area of where the lockdown bar would be. Remove all the balls by manually kicking them out using the upkicker plunger. Once all the balls are removed you can then lift the playfield up slightly and then slide it out until it contacts the stops. Then raise the playfield to vertical keeping watch at rear support rail area (left and right) within the cabinet to make sure the playfield stays against the stops so that when you raise it all the way you can rest it against the back box and it will then be slightly past its pivot center line, that will prevent the playfield from falling back down unexpectedly.
Yes thanks!! Thats why I need to raise it.... install the lower playfield balls...
@1956PINHEAD covered it...lower playfield balls are loaded by removing 2 screws for lower trough, putting the balls in, then putting the trough back in...they pretty much stay put, even when you lift the hood....
As w any game w blade art, just be really careful to pull and lift the playfield straight (not pulling one side more than the other), as it can get a bit sideways and scratch the art. This machine appears to have plenty of room, but some don't...enjoy!!!
Quoted from Spacemanratso09:Anybody else have this? Looks like X marks the spot
Looks like Stern will be sending you a blade to replace the one that should never have made it into production. contact your distro and they will get it coordinated with you.....uggghhhhh
Yikes...No...
Will that wipe off with a mild cleaner? Very odd.
I gotta say these Munsters LE machines do look gorgeous. They have to be one of the best looking pinball machines I've ever seen (IMO of course).
Jeez man somebody is drinking. Pay attention, people!
drink.gifQuoted from RobertWinter:Has anyone installed Tilt Graphics GameBlades on their Pro? I really like the design and am interested to see how well the caricature portraits mesh with the artwork on the playfield. Plus, they don't have a big black X over them! (sorry Spacemanratso09)
Hahahaha i am sure they will remedy it
Seriously though unboxed it last night flipped a few with the wife the game is overwhelmingly beautiful and the lights and sound is insane couldn’t handle it in a good way of course
Quoted from Spacemanratso09:Ha ha I am going to try and magic erase it possibly waiting to hear back from my guy he’s on it
I've used isopropyl alcohol to remove permanent marker.
Looks like a quality control mark so production doesn’t accidentally install it on a game. Must be something wrong with it in the first place.
Quoted from cooked71:Looks like a quality control mark so production doesn’t accidentally install it on a game. Must be something wrong with it in the first place.
Ya I didn’t really inspect it too much
Not sweating it not the distributor’s fault
He will get me a new one I am sure
Problem is I don’t even know how to remove them never have only stuck them on ha ha
Joined the club today. I was on the fence after reading all of the reviews. Glad I went though with the purchase. Game looks completely different in person. Way more depth than the pictures show. This one will be sticking around. A big thanks to everyone at pinballs.com.
4F69DA2D-60E3-4C08-9776-782C8009447D (resized).jpeg94863F8F-04CB-4907-84B3-14D3C0EE5B25 (resized).jpegMy LE is arriving to my home in frozen, snowbound Wisconsin tomorrow. Going to have to take it into the house via the garage and then go down the stairs rather than through walkout basement entrance due to all of the snow. Is the box 40" wide? If so won't fit through any of my doors or basement stairwell, so will have to uncrate it upstairs and then dolly it wrapped up down the stairs. Excited but hope I don't get any dings.
Quoted from adborto:Joined the club today.
Your dog has that "Oh great, another pinball machine" look!
Finally getting some play in the wife and I
This is what pinball is about this game right here for real
Quoted from Flippingr8:My LE is arriving to my home in frozen, snowbound Wisconsin tomorrow. Going to have to take it into the house via the garage and then go down the stairs rather than through walkout basement entrance due to all of the snow. Is the box 40" wide? If so won't fit through any of my doors or basement stairwell, so will have to uncrate it upstairs and then dolly it wrapped up down the stairs. Excited but hope I don't get any dings.
Will fit through a 36” door in the box.
It’s fun,exciting,has adrenaline rush,
Makes me laugh ,has heart felt moments,some things are easy and some are tough
Lights and sound somebody should get a raise for that shit
Really digging this 90s mixed with new
Favorite shot the orbit obviously like WD this one is better
Quoted from adborto:Joined the club today. I was on the fence after reading all of the reviews. Glad I went though with the purchase. Game looks completely different in person. Way more depth than the pictures show. This one will be sticking around. A big thanks to everyone at pinballs.com.
Congrats man your gonna love it
Nice, number 8 of 600...did you request that low number?
Quoted from Spacemanratso09:This is what pinball is about this game right here for real
So would it be safe to say that you are happy with your purchase Spaceman?
This page was printed from https://pinside.com/pinball/forum/topic/1313-mockingbird-lane-munsters-club/page/23 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
