Quoted from cottonm4:I could not stand the shaker. The pin shook like a car with an unbalanced wheel at 60 mph. I recently played a WOZ; It had a nice shaker that was much softer but I cannot see what all the buzz with shakers is.
Just put one of your Stern shaker arms at a 90 degree angle and it will tone down stern shaker to more of the low feel of WOZ shaker motor. Or you can turn it even lower by relocating the other side arm to be exactly opposite and you will create even less shaker action, without needing to adjust frequency in the game menu.
Munsters shaker setup properly, really adds dimension to the game.
Here is the “how to” I wrote up some time ago for same issue on Batman:
Uninstalled Batman 66 shaker, because the motor literally shook the right flipper solder joint apart. I’ve now solved the issue and can again enjoy the shaker motor without fear of my motor ruining my game elsewhere. Here are the steps:
Removed shaker motor from the machine by removing two top case screws. Then remove four bolts holding unit to table cabinet base.
Next tried using an Allen wrench, only to strip it. Attempted torque wrench and broke head. Wishing I hadn’t started this project, lol. Used Vise Grip Pliers to finally loosen 1/32nd screw nib. Destroyed screw nib getting it off. Purchased new screw and reinstalled at the 90 degree angle hole, then retightened.
90 degree position offset as opposed to the other side weight. Putting only a drop of lock tight on the screw before re-inserting.
Real issue with original screw is that it had tons of lock tight, so it was not coming off without brute force. Had to finally clamp screw nib into bench vice and then used a screw driver inserted through weight hole to turn entire weight till it came off all the way.
Now at 90 degree offset position to opposite side weight, it works perfectly as a shaker motor and doesn’t shake the table glass any longer, but keeps the fun effect of the shaker motor intact. I left the other side untouched. You could move it 90 degrees also, but then they’d be 180 degrees opposite of each other and diminish shaker effect too much.
I’ve included photos below to see exactly how I positioned weights and where screws were placed. Have fun adjusting! It would have been a simple process without the heavy dose of lock tight. It is worth the effort as now shaker motor adds to the experience instead of being too violent.
9908FE14-17A3-483E-A66A-E928FB1D13FF (resized).jpegFDE6D3FF-7E76-4D20-A001-082035DC86EE (resized).jpeg
