(Topic ID: 342433)
Pinballs on Godzilla pro getting stuck in flipper lanes
By brodyjaws
10 months ago
  • 9 posts
  • 8 Pinsiders participating
  • Latest reply 10 months ago by Octomodz
#1 10 months ago
Anyone else getting balls stuck above the roll overs in flipper lanes and Godzilla. Mines a pro if that matters. It’s like the wire rollovers need some grease. It’s both sides and only slow moving balls.
#2 10 months ago
Quoted from brodyjaws:
It's like you need to adjust the switch arm down a little so it doesn't trap balls but still works.
#3 10 months ago
Quoted from LTG:
Can that be bent or can the whole switch be moved down?
#4 10 months ago
Perhaps the cliffys protector isn't helping ?
#5 10 months ago
DO NOT GREASE! Never put any lubricants on a switch. First make sure the table incline angle is correct.
Looks like the ball is past the edge of the Cliffy so I don’t think it’s that.
Easy fix if you do what Lloyd suggested. Gently bend the switch arm and retest with rolling a ball across it in switch test mode to make sure it registers.
This is very common. When people talk about “dialing in a new pin” it’s adjustments like this that often need to be performed. Nothing wrong with the game. Just needs a little adjustment.
#6 10 months ago
Quoted from lftwng4:
Can that be bent
Yes but be careful not to effect the switch from working.
If it's on a plastic bracket under the playfield, yes a spacer between bracket and playfield can work. I've found fiberboard spacers from leaf blade switches work great. Same spacing as screws holding bracket to playfield.
#7 10 months ago
The balls are magnetized and sticking to the cliffys. The same thing will happen on my Metallica, that's when I know it's time to change balls. Try carbon core balls, not as pretty but takes longer for this to happen again.
#8 10 months ago
I think you are safe removing the protectors there. Put down a little bit of mylar if you are concerned. The ramps don't drop right onto the switch, they drop a bit above where there is a piece of mylar already.
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 135.00
Performance Pinball
$ 90.00
1031 Studios
€ 50.00
Pino Pinball Mods Shop
$ 65.00
Blood Lords Miniatures
6,450 (OBO)
Westland, MI
$ 6,999.00
Maine Home Recreation
$ 69.99
Inscribed Solutions
$ 74.00
Hookedonpinball.com
$ 320.00
Diddy's Pinball Mods
€ 168.00
Lighting - Backbox
Watssapen shop
arcade-cabinets.com
$ 6,999.00
The Pinball Place
5,700
Schwenksville, PA
6,300 (OBO)
Fairfax, VA
$ 18.95
$ 29.99
Cento Creations
BomberMods
$ 45.00
Inscribed Solutions
$ 999.99
Paradise Distribution
$ 69.99
Inscribed Solutions
$ 24.95
Discos Pinball Mod Shop
$ 259.99
6,250
Chicago, IL
The Electric Playground
Great pinball charity
Pinball Edu
